VWVortex.com - Shallow, thin door weather stripping causing excessive wind noise, weak door close seal???
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 76
    Thread: Shallow, thin door weather stripping causing excessive wind noise, weak door close seal???
    1. Semi-n00b
      Mar 25th, 2012
      Ft Lauderdale, FL
      Candy white 2012 Passat TDi SE w sunroof
      04-07-2012 01:03 PM #1
      First off let me say I love my TDi for everything I bought it for...fuel economy, space, ride comfort.
      I've noticed the wind noise before but had never taken a drive more than 30 minutes.I just took my first 300 mile road trip and REALLY noticed the EXCESSIVE wind noise.
      I traded a 2010 GTI and its weather stripping was more full and produced a much better closed door seal and I never once had problems with wind noise in the 2 years that I owned.
      Id say this is definitely an area where costs may of been cut.
      Is anybody else having this problem and if so is there any remedy that is currently available?? Anyone visit a dealer about this problem and get resolved from them reapplying new stripping or add more insulation??
      Thanks for any advice or feedback!
      Apr 2nd, 2012
      San Jose
      2012 Passat SEL 3.6 // 2010 Chevy Equinox 2LT
      04-07-2012 02:20 PM #2
      Next time you're at highway speed, roll down the window to see if it's the mirror causing the wind noise. I thought the same thing with my Equinox, but it turned out it was my luggage rack cross member causing the whistling.
    3. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      04-07-2012 03:49 PM #3
      I compared my old Passat to my new one, the 2012 is missing a layer of weatherstripping around the door, so yes they did cut it out. The old Passat has 3 layers at the top of the door, and two around the frame and the door. This only has one around the frame, and two at the top. Nothing really you can do about it really. I also do notice most of the wind noise does appear to be coming from the mirrors.
      It go down in the DM
    4. Member Turbonium20V's Avatar
      Jun 30th, 2002
      Virginia
      2015 GTI SE 4Dr DSG
      04-07-2012 09:38 PM #4
      Quote Originally Posted by vwbrvr6 View Post
      The CC, Golf, GTi, Jetta, Beetle, Eos and Passat all share the same exact mirrors so that's not the problem. The problem is the weatherstripping.
    5. 04-08-2012 05:45 AM #5
      I take mine thru the car wash several time weekly. When this water jet that does the lower sides and wheels goes thru the car makes ALOT OF NOISE! The other day I came back home and took my wife's MB R350 thru and there was no noise at all. While I understand there's no comparison... it was just amazing the difference. I will goto the dealership to see what if ANYTHING I can have done to dampen the cars excessive noise. ANY TIPS ON DAMPENING NOISE LEVELS PLEASE REPLY.
    6. Semi-n00b
      Mar 25th, 2012
      Ft Lauderdale, FL
      04-08-2012 08:53 AM #6
      Thanks for sharing and feedback.
      I'm confident there will be some type of resolution in the near future.
      BTW I listened to see if it was side views creating most the noise, and even folded them in while driving and the noise never subsided or decreased.
      I gotta say when I shut the doors its almost as if they have a slight bounce back but fall short of re-opening. Maybe Ill put strips of velcro all along the seams to enhance the look and seal .
      I might experiment with some type of strategically placed gasket strips, and or stripping materials. If I figure a better solution I will post for all to see.
    7. 04-08-2012 07:52 PM #7
      In tried taping up the entire rear view mirror, so that no air could get into it and found no difference with the wind noise. I've also taped up the enitre window and don't believe the problem is with the window seals.
      I posted this in anoer thread, but this is certainly an issue across the boas with the passat. After talking to my dealer about it we took another one, brand new just delivered (4 months newer than mine) and the noise was the very same.
      I do hope they come out with a service bulletin in this! If not I'll start trying to solve it myself...perhaps starting with some thicker/taller door seals to get a better compression on them. Perhaps even some of the weather stripping foam for the house till I figure out the problem area.
    8. Member Turbonium20V's Avatar
      Jun 30th, 2002
      Virginia
      2015 GTI SE 4Dr DSG
      04-08-2012 08:08 PM #8
      I believe the door lock mechanism can be adjusted to create more compression on the rubber seals. Somebody can try this and see if there's any difference. I know for a fact that on my previous VWs the doors were harder to close because of the heavy seals.
      Feb 17th, 2012
      Dallas, TX
      04-10-2012 11:07 AM #9
      We've had our B7 for nearly a month now, and taken a few 45-min trips on the freeway, and have noticed no unusual-sounding wind or other noise... This is coming from an '07 Saab 9-3 wagon to this car. We both feel like we got a bargain-priced luxury car!
      Partner: 2012 Passat SEL 2.5L, 2000 Audi A6 (non-Quattro), 1996 Audi A4 (non-Quattro)
      Me: 1995 Passat GLX VR6, 1987 Jetta GL, 1985 Jetta GL
    10. Junior Member
      Aug 20th, 2003
      Chicago
      04-11-2012 03:14 PM #10
      Had my TDI in a couple weeks ago where it sounded like the rear window was open just a crack. My friend is a VW Tech and he had to put some extra weather stripping around the frame and also adjusted the striker a couple mm. He said Corporate was very interested in any issues related to sound/rattling noise. He also mentioned the side mirrors as one of the biggest issues related to the higher wind noise. No info from VW about any upcoming 'tweaks'. I was somewhat happy to hear that Corporate was keeping track of any of these issues though.
      2012 Passat TDi 6MT
      1991 Audi 200 20V Quattro
    11. Member
      Nov 7th, 2011
      North Dallas, Texas
      2012 Passat TDI SEL Premium Tungsten/Black
      04-11-2012 04:01 PM #11
      Quote Originally Posted by CCISFORME View Post
      same thing here. i agree with you 100 %
      2004 VW Touareg V6 - Traded for the 2006
      2006 VW Touareg V6 - Traded for the Tiguan
      2009 VW 2.0T Jetta Wolfsburg - traded for the Passat
      2012 VW Tiguan 2.0 TSI SEL Premium Nav
      2012 VW Passat TDI SEL Premium w/rear lid spoiler
    12. Member vwbrvr6's Avatar
      Jul 30th, 2002
      Boca Raton, FL
      '11 GTI,
      04-11-2012 04:12 PM #12
      It is definitely nosier then my other Passats were, But not to the point where it bothers me. The other Passats had nearly zero wind noise. They were tanks. I can actually hear the wind flowing over the car on the 2012.
    13. Member
      Apr 19th, 2007
      CT
      04-20-2012 01:52 PM #13
      I don't have a clue if this will help; from what you guys have reported I'm convinced the noise is due to a sealing problem on individual cars.
      About 10 years ago I had a Ford Escape as a company car (which was nice as I averaged 1200 miles a week in it). It had a lot of wind noise over 55-60 mph, and a friend at the company had the same problem. At a BBQ he had, we were bitching about the cars and his brother, who had a doctorate in physics and worked as an engineer (for a company that supplied OEM parts to the auto industry) mentioned that he'd seen mirrors in their wind tunnel that had dotted surfaces on the top and/or bottoms and said they were there to add turbulence to cut down noise.
      We decided to check it out, and the mirrors on our cars were smooth. After a few beers we thought we could try adding some plastic "dots" that are used under glass table tops as a cheap way to see if it made a difference. We eventually found something like this:
      http://www.amazon.com/3M-SJ5302-Bump..._ob_hi_title_1
      The ones we found were a bit smaller, maybe 1/4" across and hemispherical. We put a couple of rows worth on the top of the mirrors with a different pattern on each car.
      It worked!
      Over the next few weeks, we changed up the patterns, added some to the bottoms, and compared notes. I don't remember what worked best; the biggest effect came by just adding the bumps. But it almost eliminated wind noise from the mirrors up to about 90 mph.
      $0.02
    14. Junior Member
      Nov 29th, 2011
      Northwest Fl
      2013 VW Passat SEL Premium
      04-20-2012 11:17 PM #14
      Had the same problem and VW replaced all the seals. They have another service bulletin for this problem...ask to go for a ride with the QA manager and point out all the concerns and they will get it corrected. Worked for me...
    15. 04-21-2012 05:48 AM #15
      Quote Originally Posted by Sunrico90 View Post
      Do you have a technical bulletin number? That would help us out, cause dealers are lazy in looking that stuff up and act like they never heard of such a thing like searching.....
      Current: 2012 VW Passat TDI SEL Premium is used for Off-Road Use Only
      Previous: '07 VW GTI 2.0T, '07 BMW K1200LT, '00 VW Golf 1.8T (4DRGTI), '92 GTI 2.0 16V, '04(2) Nissan Altima, '83 Rabbit GTI, '85 Golf GTI, '86 cabrio, '91 GTI 2.0 16V, '93 Passat VR6 and a couple others that I won't mention.
      My 2012 Passat TDI SEL Premium Fuelly Record
    16. 04-21-2012 03:47 PM #16
      Quote Originally Posted by Daddydiesel View Post
      Is anybody else having this problem and if so is there any remedy that is currently available?? Anyone visit a dealer about this problem and get resolved from them reapplying new stripping or add more insulation?? Thanks for any advice or feedback!
      I'll be curious to see if VW addresses this problem with the 013 models. There seems to be no doubt that the problem exists and is widespread. Pretty much all the published reviews have mentioned it, and it's reported more often that not here too. It may be a deal breaker for me since I tend to drive all highway and at quite high cruising speeds (I can't help but assume that the faster you go, the worse it is). Some extra and/or bigger weatherstripping might do it, but I'd much rather see an engineered fix.
      "If stupid got us into this mess, how come it can't get us out?"
    17. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      04-22-2012 12:13 PM #17
      I'm having some wind noise at my rear doors as well. I only hear it at around 70mph, but I do plan to have the dealer check it at my 1000 mile dealer check. Does anyone have a copy of the TSB for this?
    18. Junior Member
      Nov 29th, 2011
      Northwest Fl
      04-22-2012 10:03 PM #18
      Ck PM...
    19. Member brsexton's Avatar
      Mar 30th, 2012
      VA
      2012 Passat SE 2.5
      04-23-2012 11:52 AM #19
      Ck PM...
      Did you send a PM? If so, I didn't get it. Or was this in response for someone else?
    20. 04-23-2012 12:30 PM #20
      I would also like the tsb for this as well....I'm losing my mind with the noise in mine.
    21. 04-23-2012 04:23 PM #21
      Quote Originally Posted by brian81 View Post
      It worked!
      $0.02
      Haven't tried this personally, but BMWs I've had in the past have had these little bumps on the tops of the side mirrors, so there is probably something to it. Also, I know that some of the skin suits athletes like runners and cyclists also use the same technology.
    22. 04-25-2012 11:31 AM #22
      Quote Originally Posted by dcmc View Post
      I think this is one of the factors contributing to the wind noise...(Went to my local new car auto show this weekend. Point on the new VW Jetta/Passat. They only have one layer of door seals on the frame of the body. Every other car line that I looked at from super rich to dirt poor had double layer seals...one on the door and another on the frame. (This includes my B6 by the way) Is this a cheap way to save costs or what?)...These double layer seals became ops. normal for most cars decades ago. Now VW marches forward..to the rear???
    23. 04-28-2012 01:04 PM #23
      In my MKV Jetta, I went to Home Depot and got some weatherstrip material and added a second layer myself. Wasn't factory, but it worked.
    24. Member
      Mar 10th, 2012
      Dallas, TX
      2012 VW Passat TDI; 2013 VW Jetta GLI
      04-28-2012 01:57 PM #24
      Quote Originally Posted by pretzelogik View Post
      I brought the car back to my local dealer yesterday, and the guy was aware of the problem. He quickly helped me to adjust the leakage. No more hissing sound.
    25. 04-28-2012 03:34 PM #25
      Quote Originally Posted by cnnpress View Post
      Was it a TSB, what did he do? My dealer is clue less and but on wed. I am going to drive with them and I would love to know how to show them how to fix it.
