Results 1 to 5 of 5
Thread: clutch arm?
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-07-2012 06:12 PM #1
    I just put a release bearing seals and clutch kit on my 020 trans and mounted it back on the motor and its almost impossible to push the clutch arm by hand. Is this normal?
  2. Member Broke's Avatar
    Aug 13th, 2001
    Columbus, Ohio
    86 GTI 2.0L, 88 Scirocco 16V, 2010 F150 STX
    04-07-2012 06:41 PM #2
    Quote Originally Posted by cll2993 View Post
    It should lift easily up to 9:00 with light spring pressure behind it, then get solid.
    The cable pulls it from 9:00 to 10:00 to disengage the clutch.
    9:00 is where the parts are all in contact with each other, lifting it further will begin to collapse the pressure plate and disengage the clutch.
    020 trans info pages - www.BrokeVW.com
    NEW 0.7619 5th gears for the 020
    NEW 020 reverse gears
    '86 GTI 8V 2.0L -'88 Scirocco 16V - '10 F150 4x4
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-07-2012 06:52 PM #3
    Quote Originally Posted by Broke View Post
    ok so when it starts to get stiff how far does it go until its fully engaged?
  4. Member Broke's Avatar
    Aug 13th, 2001
    Columbus, Ohio
    04-07-2012 07:14 PM #4
    Disengaged.... at about 10:00, or just under the 27mm selector cover:
    You won't be able to lift it by hand past this point:
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-07-2012 07:27 PM #5
    Thanks that helped out alot. I think im fine I was just worried a little. Im used to hydraulic.
