Results 1 to 24 of 24
Thread: FS: 92 jetta mk4 drivetrain, big brakes, westy front
  1. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-07-2012 10:03 PM #1
    i know i just put this together but a mk4 2.0 jetta just fell in my lap and would rather put allmy big turbo stuff in it. heres my thread from when i got it and swapped in the drivetrain and brakes from elreys black mk2.
    http://forums.vwvortex.com/showthrea...-back-in-a-mk2....
    GOOD:
    12.3" TT front brakes
    11" rear discs
    clean inside, no cracks on dash
    westy front with all tabs intact
    new headlight bulbs
    near new tires on 16" steelies
    neuspeed springs on kyb struts
    new wiper blades
    all glass is good
    grey interior in great shape
    have uninstalled 1 piece seat belts
    was daily driven with no issues
    sunroof works perfect and no leaks
    have spare minty headliner to swap in
    mk4 steering wheel
    r32 control arm bushings
    BAD:
    no radio
    some rust on left rear 1/4 panel and left side of trunk floor
    right rear door is wavy(have a black replacement)
    missing front grill emblem
    console is out for mounting radio into(needs finished)
    need spare minty door cards installed
    all stuff for ac is removed(good heat though last time it was cold)
    buy the car as it sits without the engine, trans, shiftbox, ecm for 1000. perfect for someone wanting to do a vr swap as all the stuff is there for hyro clutch and is ce2 for plug and play. all you would need is engine, trans, ecm wiring, shift box. already has 5 lug swap and big brakes.
    may part out if enough stuff is asked about....let me know thanks!!
    now looking for mk4 jetta goodies for possible trade
    Dubvinci on instagram
    Loves Trim Shop
    AIRCOOLED CABBY PROJECT
    need some work done in atl, hit me up...
  2. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-09-2012 07:47 AM #2
    bump for offers on the car minus the drivetrain. i think ive found a home for it already.
    Loves Trim Shop
  3. Member autotragik b3attlewagen's Avatar
    Aug 24th, 2003
    Norcross, Ga
    94' Jetta / 03' Mazda Protege5 /02' Passat Wagon/ 85' KLR600 x2
    04-09-2012 08:57 AM #3
    lolz. How did I know this was coming.
    Good luck w/ sale Shane.
    I have to laugh when someone calls me an a*****e. I've been called far worse than that.
    - Gordon Ramsay
  4. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-09-2012 03:03 PM #4
    hahaha...thanks kris...it wouldnt have come if this other car didnt fall into my lap for almost nothing...but i cant do 2 at the same time so this one is better to part with as a project...
    and now only for sale wihtout engine/trans/shift box. all else will remain unless people start asking for parts. will sell big brakes/5 lug swap and any of the inside pieces....has hydro master and pedal
    cluster installed. will remain a driving car for about another week or so...
    Loves Trim Shop
  5. Member autotragik b3attlewagen's Avatar
    Aug 24th, 2003
    Norcross, Ga
    04-10-2012 09:12 AM #5
    out of curiosity and possible interest, what might you want for the 5lug swap?
    - Gordon Ramsay
  6. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-10-2012 04:24 PM #6
    if swapping out with your stock mk3 stuff id say 350...or 500 with the wheels and tires. these 16s are the smallest wheel you could run on it...what size are your rs's? im on the lookout for some suspension/wheels for the mk4...lol...
    Loves Trim Shop
  7. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-11-2012 03:35 PM #7
    BUMP...looking for mk4 wheels and suspension if someone wants to trade...
    Loves Trim Shop
  8. Member autotragik b3attlewagen's Avatar
    Aug 24th, 2003
    Norcross, Ga
    04-12-2012 11:31 AM #8
    Quote Originally Posted by dubvinci View Post
    IM'd you
    - Gordon Ramsay
  9. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-18-2012 09:58 PM #9
    bump...still here waiting on a vr swap....car comes with axles also..all you need is a motor, trans, harness, subframe...has plus suspension already...
    Loves Trim Shop
  10. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-24-2012 08:30 PM #10
    bump...someone gotta want this... make me an offer...
    Loves Trim Shop
  11. Member vwlennon67's Avatar
    Oct 3rd, 2009
    LITTLE ROCK
    2007 touareg, 2004 gli, 90 g60 corrado
    04-25-2012 07:45 AM #11
    if its still available next month id buy it on the way to sowo
    volkswagens,metal,pbr and the mighty glasgow celtic
  12. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-25-2012 08:03 PM #12
    Quote Originally Posted by vwlennon67 View Post
    pm sent..
    Loves Trim Shop
  13. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    04-28-2012 08:31 PM #13
    also will trade for standard bug project...running with alot of rust is ok but let me know what you have...
    Loves Trim Shop
  14. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    05-21-2012 01:29 PM #14
    car still up for grabs as well as drivetrain and my stage 3 turbo kit seen here...
    http://forums.vwvortex.com/showthrea...8v-turbo-parts....
    make a package deal for someone wanting it all....
    Loves Trim Shop
  15. Semi-n00b
    May 22nd, 2012
    Atlanta, GA
    '90 Jetta GL
    05-22-2012 03:53 PM #15
    how much for the car with engine and drive train?
  16. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    05-22-2012 08:37 PM #16
    2k for car, engine, trans, and wiring harness...
    2500 for above plus big turbo kit...
    engine no longer has k03 setup on it...will need a mk2/3/4 downpipe and exhaust manifold.
    Loves Trim Shop
  17. Semi-n00b
    May 22nd, 2012
    Atlanta, GA
    '90 Jetta GL
    05-23-2012 01:05 AM #17
    so what does the turbo kit work with?
  18. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    05-23-2012 09:42 PM #18
    aeg mk4 2.0...
    Loves Trim Shop
  19. Junior Member Pierre898's Avatar
    Sep 2nd, 2002
    Panama City Beach, FL
    '10 GTI Autobahn / '93 Corrado SLC
    06-04-2012 11:41 PM #19
    PM'd
  20. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    07-10-2012 10:51 PM #20
    been busy with moving so now back to getting this car a new home...really looking to sell just the body as a roller with all the gooies minus the engine and trans...may also trade for some mk4 parts...make an offer all i can do is say no or make a counter offer...
    Loves Trim Shop
  21. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    07-15-2012 10:07 PM #21
    bump for mk4 wheels/suspension/interior
    Loves Trim Shop
  22. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    07-24-2012 10:08 PM #22
    offers? anyone? need to move this so i can get started on the mk4....offers without the brakes? or westy...ready for a vr or 1.8t or aba or whatever...hydro clutch ready. also have a cable clutch pedal cluster....
    Loves Trim Shop
  23. Member vwlennon67's Avatar
    Oct 3rd, 2009
    LITTLE ROCK
    07-24-2012 10:27 PM #23
    if you'd drag it to memphis id buy it
  24. Member dubvinci's Avatar
    Jan 22nd, 2007
    CONYERS GA
    97 civic, 91 cabby
    07-31-2012 10:29 PM #24
    bump...
    Loves Trim Shop
