Results 1 to 4 of 4
Thread: Trade: my 1985 Vr6 Mk2 4 door for your TDI - b4 Wagon preferred
    Jul 18th, 2002
    Nebraska
    85 eurospec GTI, 98 turbo GTI, 1990 Miata, 2010 Ford Edge, Road race CRX B16
    04-07-2012 11:25 PM #1
    Trade for a TDI - even better yet - a TDI swapped mk2 4 door w/ ac ? Or a B4 passat TDI Wagon? Or other TDI ?
    No Diesel Trucks sorry - gotta haul the kids around...
    Show me..
    I'm in Nebraska
    1985 Volkswagen Golf
    4 door
    5 speed
    obd2 Vr6 engine swap
    Functioning - heat and Air Conditioning
    cruise control components are there - but it not working - only thing left to replace is speed sensor
    Car:
    1985 VW Golf 4 door built right here in America. The car has been in one small wreck in it's life. The rear must have been hit because the rear paint is a little darker. The hatch has the worst paint but NO rust or damage. The rest of the car is original paint.
    Engine:
    1998 mk3 Jetta VR6 full OBD2. Yes you can scan it with VCDS. - odometer says 79,000 - take that for what it worth.
    Mods include: Autotech chip, brospeed header(ported), ABD mk3 intake rewelded to fit perfect in the mk2 chassis. BFI motor mounts cut down to clear the hood. I did not cut the hood like some other people! Mason Tech crackpipe, 42 Draft Design block off for the SAI system(deleted everything AND all electronics)
    Check engine light is on for the SAI - i dont have vag-com to clear it / ignore it.
    Drivetain:
    Corrado VR transmission (best VR trans), Corrado axles, Corrado g60 hydro clutch setup.
    Suspension
    mk3 front subframe (plus suspension). Corrado VR crossmember and rear beam. Brand new Koni suspension with HOR springs. a-arms have poly bushings.
    Steering
    factory mk2 manual steering with brand new tierod ends for the plus suspension
    Brakes:
    Full 5 lug swap from the 1998 Gti vr6 driver edition mk3. Master cylinder is Corrado. Obviously rear disc with new cables. Its also a Corrado rear beam.
    Gas Tank:
    mk3 VR to include the pump
    Wiring:
    Engine is mk3 CE2
    engine bay is mk2 CE2
    cluster is mk3 CE2
    A/C is Corrado VR6 CE2
    Rear is factory that I made a plug/play connector.
    Stereo:
    Alpine Media Head unit - decent speakers
    Wheels/Tires:
    Factory Corrado Speedline Rims with Ziex 912s
    HERE IS LINK TO BUILD THREAD:
    http://forums.vwvortex.com/showthrea...ause-I-want-to
    Blast to drive!!! I bought a Subaru and just dont drive this Golf anymore. Always get in the Subaru.
    $5500 Firm - might be flexible if you bring your own wheels - or i have Steelies but not sure of the tire condition.
    Located in Lincoln Nebraska 68516
    on to fresh pics:
    here are pics of the paint fade in the rear:
    cracked tail light - i have a good one...
    little crack / chip in paint
    interior is so incredibly clean:
    mk3 instrument cluster in the dash:
    Alpine head unit - i have a new trim stereo bezel - this is iphone / media unit with iphone / ipod / usb cord ran down by passenger side seat.
    scan port: guy at Auto Zone was confused when my air filter cone came off the MAF - my check engine light came on and i had them scan it .. good times.
    these are previous owners pictures - with BBS wheels that are gone
    there are all sorts of receipts from this car - the original owner actually emailed me through my ad on thesamba.com - kinda cool.
    EXTRA:
    The rear seat belts are lap only - i have conversion to do shoulder belts in the rear
    I also bought black rear c pillar covers from Europe from a 4 door ( with seat belt holes )
    Black sunvisors - black sunroof stuff, crank , black sunroof cover - pretty much everything to convert headliner to black - except the actual headliner part. Also bought BNIB golf ball shifter -
    These items are negotiable to potential new owner.
    Jul 18th, 2002
    Nebraska
    04-09-2012 11:24 AM #2
    t t t
    Jul 18th, 2002
    Nebraska
    04-15-2012 07:16 PM #3
    t t t
  4. Member
    Jul 18th, 2002
    Nebraska
    04-22-2012 02:52 PM #4
    t t t
