AMU uses the v1.3
#36
Can we get any confirmation as to which adapters fit the AMU/BEA motors while retaining the mess on top of the 3rd & 4th cylinder coilpack/engine cover?![]()
#37
AMU uses the v1.3
#38
I just got my coil packs from Username :beeyond (http://www.whanab.com/) and they are nice, OEM vw with the metal bottoms and I got them quick as hell!! I just put them in and the car does run alot smoother and I havent even regapped the plugs . . . What gap size do you guys use on a chipped 225TT(ko4s) ??
Thx![]()
#39
.040 I believe
#40
http://forums.vwvortex.com/showthrea...t-done-I-guess
^^^Big Turbo build lots of pics^^^
Best shop for repair and custom workin ma
http://www.wentworthmotorsports.com/
#42
Guys stop making me want to buy these! Question though, with these adaptors, and new coil packs, how are the new coil packs held down? I saw the Played (or maybe someone else) had a bracket go over the coilpack and bolted down into the adapter...
#43
#44
Where do you guys move that vacuum thingy that sit on top of #4??
Just a wondering...
Never underestimate the stopping power of a tree.
#45
I relocated mine underneath the battery tray.
Also the hold downs aren't necessary because the tolerances on the adapters are so tight.
#46
#47
#48
didnt know INA made v1.3 style until now but oh well. yeah i think its ridiculous for what you pay for these. they should only be 50 tops. im hoping my idle will improve though.
#49
For street use the unsupported coilpacks are probably fine, but I track my car so I need the extra support to avoid failure. IE is a solid supporter of this marque and do much development and innovation. I have no problem with their pricing - this is a well designed and manufactured piece.
#50
The people selling these say they have identical internals to the 1.8t packs. I have seen NO evidence these are any better than stock coil packs - certainly no scientifically verifiable evidence. I run peak of 27lb of boost, high timing and .044 gap on stock 1.8t Coil packs... IMO this is just the fad of the moment.
#51
#52
is it really a piece of metal?
i mean it has a 3 holes in it also. the center hole also has slots cut in it. it also is in a needed shape.
your argument of it being a piece of metal is the most assinine argument I have seen in a while.
With that logic you can say IE's cams are just hunks of metal. Pistons are just slugs of metal. A home is just a pile of wood and cement. You are just a bag of water and protien.
If the price is so outrageous, people should not be buying them. People DO buy them, so that right there tells you the price is fine.
80-90$ for 4 pieces of metal isnt really that much. If you were to go to metal supplier and ask for half inch plate in a 12inx6in section of aluminum they would charge you in the range of 30$. The would be enough material to make you a set of 4, maybe more, but for sure not 8.
Paying 50$ to have the pieces cut, the holes drilled, slots cut all on tooling that costs over $10,000, THEN have it annodized and a gaurentee it will fit......
tell me, who is the unrealistic one with his head up his ass?![]()
#53
Oh don't forget the longer bolts to hold them down!!!
Sometimes you don't realize how much designing goes into simple things. Not to mention how much machining is done to get the tolerances so fine. I paid 85 shipped for 4 and bolts. You figure 20 for each spacer and 5 for bolts. That's more then reasonable in my eyes.
#54
Sorry to keep bumping this, but do you also need to actually upgrade your actual coil wiring as well? I.E. makes it seem as if you do...
I was planning on just getting the Tiguan Adapter or just wrapping the wiring up in thermal wrap, what did everyone else use?
#55
the wiring kit is only for cars that have a different setup. (1997-1999.5 B5 Audi A4 1.8T ( AEB Engine Code)
if you have an mk4 vw golf/jetta/gti you dont need it.
#56
If your harness connectors are 4 pin they are plug and play. The b5 1.8t are 3 pin and therefore need to be switched. All TT's will work with these.
#58
#60
You can always swap out valve covers to work with the circle ones
#61
Uh, did I f*ck up and get the wrong adapters?? I thought they were pretty much all the same except for the outward appearance - holes drilled in the same spots etc.
I have an ATC engine...
#62
All of them are the same just some are square and others circular.
#64
they are not the same.
the valve covers are different. some have round holes, some valve covers have square holes.
if you use the round adapters on a square hole valve cover, you will have corners exposed, and allow crap to fall into the plug area.
#65
I think he was talking about the layout of the spacer. All of the mounting holes should be the same
#67
#69
#70
I just bought some from O'Reilly Auto and they are BWD or Borg Warners. They look like the Red ones but are black. Pulled one out of the box and noticed they did not have the Square Hold downs with provision to bolt them down. They said it is what is called for my 2002 AMU. Are these not good to use?
