I really like the OEM stuff personaly. I have zero issues with break dust and performance wise is perfect for my stock cc. I'm sticking with OEM till I eventually buy a BBK.
Sent from my SAMSUNG-SGH-I717 using Tapatalk
Well guys i'm just preplanning here, but id' like some advice. Hoping bsick comes in too. Anyway i've been getting a squeaking in my brakes on my front driver side for about a week or so now. Pretty sure its' not anything lodged in there, but i'm taking it in Monday to have it checked out along with my oil change.
I need suggestions on a pad that grips a little better than stock. The same question goes for rotors i've pretty much settled that i'd like a slotted rotor despite any minimal gains I might actually get out of them. I'm not wanting to go adams rotors so those are out of the question i'd like something quality.
I'd also like some help finding some oem parts should I just decide to go another oem route until I can do a bbk.
2010 CC R-line. 5% tint all around,Debadged, Euro Clear Corners, 8k Hid's, LED TAG lights, K&N Filter, VAG-COM windows, H&R springs, Led interior lights
2012 Jetta GLI Autobahn- Stock
15.18 @ 93.44 now time for upgrades.
I have been really happy with the Hawk HPS pads. Much better bite than the OEM pads and a lot less heat fade. Another bonus is significantly reduced brake dust. Used them on numerous different cars with similar results. Use some of this stuff when you install the pads for squeal free operation:
What's the best place online to pickup a set of hawks?
2012CC2.0LTSI DSG CW/35%Tint/Neuspeed HI-FLOTop&Turbo Discharge/APR3"DP/APRCarbonioSTGI/LotsVAG-COMdone/EuroStyleTurn Signal/StopTech Cryo-SportStop Drilled Rotors F&R/HawkHPSF&R/H&RSportSpringSet/Debadged/USP8000KDigitalHIDkit/AWEDV/Borla CT/Hartmann HTT-256-GA:M-Conti 235/35ZR19DW/APR FMIC/Black G2 Brake Caliper/DR 8mm/F/Hotchkis27mmRSB/InteriorLEDKit/APR KO4+UNITRONIC STG II DSG/R8Coilpacks&NGK-PFR7B/
I already changed both F&R rotors and pads multiple times. I keep on coming back to HPS for daily even my other car has the same set-up HPS and centric rotors. I chose the centric over OEM mainly because of the price and it's durability.
I kept on saying its durable because I tried using the second most aggressive pads that Hawk has to offer for our car which is the DTC-60. The result were really good, it did not warp and remained solid the whole day (track day). IMO it will last as long if not a tad bit longer vs OEM.
#11
I have this set up, I just love it. CC feels completely different from stock. Dion from ACHtuning will help you.
#12
I like that setup airmax, just would want to go with slotted instead of drilled.
#13
In that case will be a little bit more noise every time you brake. Is all about preferences.
#14
Don't mind that at all. Just don't want to prematurely replace the rotors if the drill holes start to crack. On another subject for a moment would anybody recommend stop tech over hawk's or is it pretty much the same thing?
#15
Island Gray Metallic 2010 CC Sport 2.0T 6M, APR Stage1, R-Line Sport Pedals, HTTRS-256-MA:M
235/35/19 Hankook Ventus V12 K110's, Borla CBE, Koni ss coilover kit, Adams slotted/drilled rotors, with Stop Tech pads.
#16
That black color looks pretty neat. What brand are those rotors?
#17
#18
Upgrade to the 4mo setup. Stopping power is AMAZING!
Otherwise, get some quality rotors (Brembo, ATE, etc) and some higher quality pads. I ran AXXIS Ultimates on my B5.5 Passat, and am currently running Hawk HPS pads on my Touareg.
#19
#20
Annnnd there is no performance advantage to slotted or drilled brakes, for looks only on a daily driver.
2009 CC Lux, Iron Gray Metallic, Cornsilk/Beige, Dynaudio, Tint F35%, R20%, R pedals, Euro Switch, VAG
2004 Nissan Quest SE, Dark Red, Gray Leather
1987 GMC S-15 Jimmy, old SQ IASCA comp vehicle
#21
#22
Agreed! I would like some drilled Baer brakes myself but I don't have that kind of cash to spend on brakes.
#23
R1 Concepts rotors and Hawk HPS for daily driving is the way to go!
sent using my fat fingers on this small phone!
North.East.Region.Dubs
