Results 1 to 23 of 23
Thread: Rotor and Pad advice
  1. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    2010 VW CC R-line, 2012 GLI Autobahn
    04-08-2012 02:32 PM #1
    Well guys i'm just preplanning here, but id' like some advice. Hoping bsick comes in too. Anyway i've been getting a squeaking in my brakes on my front driver side for about a week or so now. Pretty sure its' not anything lodged in there, but i'm taking it in Monday to have it checked out along with my oil change.
    I need suggestions on a pad that grips a little better than stock. The same question goes for rotors i've pretty much settled that i'd like a slotted rotor despite any minimal gains I might actually get out of them. I'm not wanting to go adams rotors so those are out of the question i'd like something quality.
    I'd also like some help finding some oem parts should I just decide to go another oem route until I can do a bbk.
    2010 CC R-line. 5% tint all around,Debadged, Euro Clear Corners, 8k Hid's, LED TAG lights, K&N Filter, VAG-COM windows, H&R springs, Led interior lights
    2012 Jetta GLI Autobahn- Stock
    15.18 @ 93.44 now time for upgrades.
  2. Member AustinChappell's Avatar
    Jan 12th, 2012
    MN
    2012 VW CC 2.0T
    04-08-2012 03:41 PM #2
    I really like the OEM stuff personaly. I have zero issues with break dust and performance wise is perfect for my stock cc. I'm sticking with OEM till I eventually buy a BBK.
    Sent from my SAMSUNG-SGH-I717 using Tapatalk
  3. Junior Member
    Aug 4th, 2011
    Surprise, AZ
    2012 CC R-line
    04-08-2012 03:51 PM #3
    What's wrong with Adams rotors?
  4. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-08-2012 04:47 PM #4
    Quote Originally Posted by Deathrazekraze View Post
    Not that its bad but I hear they just buy cheaPie blanks and machine them id rather go with someone who does all their stuff in house. Plus if my information is correct how can you properly stand behind your product
    May 29th, 2010
    Western Md.
    03 A4 1.8TQM / 09 CC VR6 Sport
    04-08-2012 06:03 PM #5
    I have been really happy with the Hawk HPS pads. Much better bite than the OEM pads and a lot less heat fade. Another bonus is significantly reduced brake dust. Used them on numerous different cars with similar results. Use some of this stuff when you install the pads for squeal free operation:
  6. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-08-2012 09:24 PM #6
    What's the best place online to pickup a set of hawks?
  7. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    04-08-2012 10:02 PM #7
    Quote Originally Posted by dj_cronic_metal View Post
    tirerack for hawks.
    2012CC2.0LTSI DSG CW/35%Tint/Neuspeed HI-FLOTop&Turbo Discharge/APR3"DP/APRCarbonioSTGI/LotsVAG-COMdone/EuroStyleTurn Signal/StopTech Cryo-SportStop Drilled Rotors F&R/HawkHPSF&R/H&RSportSpringSet/Debadged/USP8000KDigitalHIDkit/AWEDV/Borla CT/Hartmann HTT-256-GA:M-Conti 235/35ZR19DW/APR FMIC/Black G2 Brake Caliper/DR 8mm/F/Hotchkis27mmRSB/InteriorLEDKit/APR KO4+UNITRONIC STG II DSG/R8Coilpacks&NGK-PFR7B/
  8. Member Tom333's Avatar
    Nov 2nd, 2010
    OC CA
    2010 VW CC R-Line, 2010 MB C300, 2002 Audi TTQ 225
    04-08-2012 11:39 PM #8
    Quote Originally Posted by airmax1 View Post
    tirerack for hawks.
    x2! I personally like Hawk Hps for daily driving.(F&R or F& OEM rear)
    Rotors I'll go with plain centric rotors (w/black painted hub)
    Very durable rotors and best bang for $$.
  9. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-08-2012 11:43 PM #9
    Quote Originally Posted by Tom333 View Post
    Did you swap out the rotor with another set or did you go with the oem rotor from vw?
  10. Member Tom333's Avatar
    Nov 2nd, 2010
    OC CA
    04-09-2012 01:10 AM #10
    I already changed both F&R rotors and pads multiple times. I keep on coming back to HPS for daily even my other car has the same set-up HPS and centric rotors. I chose the centric over OEM mainly because of the price and it's durability.
    I kept on saying its durable because I tried using the second most aggressive pads that Hawk has to offer for our car which is the DTC-60. The result were really good, it did not warp and remained solid the whole day (track day). IMO it will last as long if not a tad bit longer vs OEM.
  11. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    04-09-2012 05:34 AM #11
    I have this set up, I just love it. CC feels completely different from stock. Dion from ACHtuning will help you.
  12. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-09-2012 09:51 AM #12
    I like that setup airmax, just would want to go with slotted instead of drilled.
  13. Member airmax1's Avatar
    Dec 7th, 2008
    Atlanta
    2012 VW CC 2.0T DSG
    04-09-2012 10:10 AM #13
    In that case will be a little bit more noise every time you brake. Is all about preferences.
  14. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-09-2012 01:12 PM #14
    Don't mind that at all. Just don't want to prematurely replace the rotors if the drill holes start to crack. On another subject for a moment would anybody recommend stop tech over hawk's or is it pretty much the same thing?
  15. Member sfccryder's Avatar
    Nov 24th, 2009
    Castro Valley, CA
    2010 VW CC Sport 2.0T 6M
    04-09-2012 02:45 PM #15
    [IMG][/IMG]
    will let you know after i have them installed...
    Island Gray Metallic 2010 CC Sport 2.0T 6M, APR Stage1, R-Line Sport Pedals, HTTRS-256-MA:M
    235/35/19 Hankook Ventus V12 K110's, Borla CBE, Koni ss coilover kit, Adams slotted/drilled rotors, with Stop Tech pads.
  16. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-09-2012 03:18 PM #16
    That black color looks pretty neat. What brand are those rotors?
  17. Member sfccryder's Avatar
    Nov 24th, 2009
    Castro Valley, CA
    04-09-2012 03:27 PM #17
    these are adams rotors done in black zinc. i know youre not a fan
    of adams but i thot i'd give them a try.
    ive never used them before...they recommend stop tech pads with
    their rotors. so will give them a try too...
  18. Junior Member
    Apr 17th, 2003
    Twin Cities, MN
    2009 CC V6 4mo, 2008 Touareg FSI V6, 2002 Passat GLX 4mo (gone), 2003 Passat GLS Wagon - gone :-(
    04-09-2012 03:59 PM #18
    Upgrade to the 4mo setup. Stopping power is AMAZING!
    Otherwise, get some quality rotors (Brembo, ATE, etc) and some higher quality pads. I ran AXXIS Ultimates on my B5.5 Passat, and am currently running Hawk HPS pads on my Touareg.
  19. Member MrRline's Avatar
    Apr 6th, 2010
    Buckeye, Arizona
    04-09-2012 10:16 PM #19
    Quote Originally Posted by ameoba View Post
    That's more than i'm looking to spend at this point especially considering apr stage 1 is 600 bucks and that's 1,000. I'd rather go faster on a slotted setup than brake hard on a mid range with no speed :d
  20. Member
    Jun 15th, 2009
    Columbus, Oh
    2009 VW CC
    04-10-2012 08:39 PM #20
    Annnnd there is no performance advantage to slotted or drilled brakes, for looks only on a daily driver.
    2009 CC Lux, Iron Gray Metallic, Cornsilk/Beige, Dynaudio, Tint F35%, R20%, R pedals, Euro Switch, VAG
    2004 Nissan Quest SE, Dark Red, Gray Leather
    1987 GMC S-15 Jimmy, old SQ IASCA comp vehicle
  21. Member
    May 29th, 2010
    Western Md.
    04-10-2012 08:47 PM #21
    Quote Originally Posted by bigmikeo View Post
    So what's wrong with a little bling;-) I like the look of drilled rotors. I really don't care if they don't perform any better as long as they don't detract from my braking ability. No different than any other appearance mod.
  22. Member
    Jun 15th, 2009
    Columbus, Oh
    2009 VW CC
    04-10-2012 09:12 PM #22
    Agreed! I would like some drilled Baer brakes myself but I don't have that kind of cash to spend on brakes.
  23. Member
    Aug 6th, 2007
    Seacoast, NH
    '03 W8 Wagon(RIP), '79 euro BMW 635 csi, B6 3.6 4motion wagon, fleet of Scoot Coupes/mopeds
    04-10-2012 09:16 PM #23
    R1 Concepts rotors and Hawk HPS for daily driving is the way to go!
    sent using my fat fingers on this small phone!
    North.East.Region.Dubs
