Results 1 to 12 of 12
Thread: Light switch
  1. 04-08-2012 03:44 PM #1
    I noticed that there is no parking light position on the headlight switch, so how does the headlight switch work? Either all OFF or all on? Or is the on position really "auto"
  2. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    04-08-2012 04:47 PM #2
    Quote Originally Posted by gtitsi View Post
    its either all off or all on, no other way... unless you get a euro switch and disable DRL with vagcom.
    2011 GTI / APR K04-Carbonio stg1/2 intake-APR catted dp-Magnaflow catback-APR intercooler-Audi S3 shifter-Podi boost tap/boost gauge-034 Motorsports engine/trans mounts (street density)-DXD stg2 daily-H&R coilovers-APR 27mm rear swaybar/Whiteline adj. end links-vcds coding tweeks-Tinted oem tails-HPA 6 piston bbk/80a subframe mount
    Follow on instagram @glfsprtct1
  3. 04-08-2012 04:51 PM #3
    when it's "all off" do the DRL's still come on?
  4. Member gravis86's Avatar
    Dec 25th, 2011
    Kirkland, WA
    2012 GTI CSG 6MT
    04-08-2012 04:55 PM #4
    Yes, unless you have them disabled through vagcom.
    Have VCDS, will travel.
  5. 04-08-2012 05:01 PM #5
    I'm okay with DRL's on while the switch in on off. I just want to control the actual headlights.
  6. Member GlfSprtCT1's Avatar
    Feb 8th, 2002
    East Hartford, CT
    2011 CSG GTI
    04-09-2012 12:02 AM #6
    if you run the euro switch, disable DRL.. makes life easier for you. then you get full control of parking lights/headlights whenever you want.
  7. 04-09-2012 07:33 AM #7
    Quote Originally Posted by gravis86 View Post
    How do get a hold of the "scanner" (vagcom?) to change the settings?
  8. 04-09-2012 11:20 AM #8
    does the vagcom have to de done at the dealer?
  9. Member sfpegasus's Avatar
    Jul 23rd, 2009
    San Francisco
    04-09-2012 11:49 AM #9
    Quote Originally Posted by tfurr View Post
    Find someone here:
    Vag-Com Locator searchable map
    Or buy one from Ross Tech
    2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
    2007 CW Rabbit 6AT 2DR - Bone stock
  10. 04-09-2012 03:51 PM #10
    cool, thanks
  11. Member Smoky_Llama's Avatar
    Nov 21st, 2005
    Bellevue, Nebraska
    12' GTI, 10' Specialized Hardrock
    04-09-2012 04:09 PM #11
    You'll also need to run a trigger wire, look in the DIY.
    Need Vag-Com in Eastern Nebraska and Western Iowa? Send me a PM.
    Quote Originally Posted by Arin@APR View Post
    We don't run a business where we inspect damaged ECU's, completely destroy them, and/or whatever you were saying about your penis.
