Results 1 to 4 of 4
Thread: Secondary Air Solenoid and Pump Confirmation
  1. Member expated's Avatar
    Oct 9th, 2007
    West Chester, PA
    96 Jetta VR6, 87 16V GTI, 2001 A6 2.7 Quattro and 96 Ford Ranger XLT
    04-08-2012 06:17 PM #1
    Car: 1996 Jetta GLX VR6
    Just wanted to confirm operation of a Secondary Air Solenoid 191 906 283 A.
    No voltage or disconnected = closed no vacuum applied to the combi
    12 volts applied = open drawing vacuum to the combi
    Has anyone ever seen one stuck open applying vacuum continuously?
    Also to test the pump, does it just require battery and ground? I applied battery and ground to the pump and nothing! Having replaced the Combi valve 18 months ago and now having a possible bad pump and solenoid is not going over real well......$$$$$.
    Any recommendations? All i want to do is get 6 readiness codes cleared for the PA inspection. I'm not interested in a chip because of the advance and having to burn high octane fuel.
    Feb 19th, 2009
    LI, NY
    2004 Audi S4, 1996 24v VR6 GTI, 1983 Rabbit
    04-08-2012 07:01 PM #2
    haha looks like you found your problem. If you put 12v directly to the pump and it doesn't come on you have a bad pump. I see a lot of blown strip fuses on the sa relays at my shop. good to take a look at that as well. As for the solenoid they are like 8 bux iirc from the dealer.
  3. Member expated's Avatar
    Oct 9th, 2007
    West Chester, PA
    04-08-2012 10:29 PM #3
    Quote Originally Posted by SHAKEDOWN View Post
    Can't wait to see the price of a pump.....regarding the solenoid were the heck are yah getting em for 8 bucks?
  4. 04-08-2012 10:32 PM #4
    I have a few pumps if you need one. Shoot me a pm. In western PA so shipping will be cheapish.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
