VWVortex.com - Touch Panel Installed!!
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 34
    Thread: Touch Panel Installed!!
    1. Member WiSatman's Avatar
      Sep 5th, 2007
      Madison, WI
      2001 1.8t Golf GLS + 1993 Corrado SLC
      04-08-2012 06:56 PM #1
      Here it is, I decided to make a new thread because the old ones title was pretty stupid. If you do want to look at the old one here is a link. Also sorry about the door buzzer after I put the key in, I didn't even notice it until after I uploaded it to youtube.
    2. Member CorradoCody's Avatar
      Oct 13th, 2001
      90 VW Corrado G60
      04-08-2012 07:07 PM #2
      Pretty sweet. Can you install navigation on the touch panel?
      CC
    3. Member JamesS's Avatar
      Nov 17th, 2008
      Calgary
      91 JDM Corrado, 05 Jaguar X-type
      04-08-2012 08:12 PM #3
      Wow that is nice. A bit cleaner of an install and interface and that would be amazing.
    4. Member dogger's Avatar
      Jul 29th, 2005
      Pasadena, CA
      1990 Corrado 2L 16V, 2004 Audi TT 3.2 Quattro S-Line
      04-08-2012 09:47 PM #4
      Yikes that's ugly.
    5. Member WiSatman's Avatar
      Sep 5th, 2007
      Madison, WI
      04-08-2012 10:01 PM #5
      Quote Originally Posted by CorradoCody View Post
      CC
      The touch panel can vnc into a computer, so if I had a computer with gps hardware and software it would work for navigation.
      Quote Originally Posted by dogger
      Yikes that's ugly.
      The touch surface is actually flush with the dash bezel I wish I could get a better bezel for the touch panel. It could be a lot worse, I could have gauges in the vents or on a pod somewhere, that looks like **** IMHO.
    6. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      93 VR6 Corrado, 04 R32
      04-08-2012 10:10 PM #6
      Have you thought about painting the silver parts of the bezel black? It seems the overall shape matches the soft curves shape of the 93 dash, it's just that gaudy silver color that really makes it seem out of place.
      Brendan Prout
      04 R32 145k miles
      93 VR6 Corrado 194k miles
      90 G60 Corrado 304k miles - RIP 2/12/11
    7. Member WiSatman's Avatar
      Sep 5th, 2007
      Madison, WI
      04-08-2012 10:26 PM #7
      Quote Originally Posted by g60racer View Post
      The silver area does remove and I would like to paint it, what is best for someone with little painting experience? Is there a good place I could bring it to get it painted, like a body shop? I know it's probably pretty easy to paint it, but I would like it done right.
    8. Member JamesS's Avatar
      Nov 17th, 2008
      Calgary
      04-08-2012 11:31 PM #8
      Quote Originally Posted by WiSatman View Post
      SEM color coat vinyl spray would do the trick. It can be found in a spray can at lots of upholstery shops.
    9. Member cata's Avatar
      May 19th, 2006
      Canada eh
      04-08-2012 11:42 PM #9
      I used a textured bumper paint to paint the faceplate frame off one of my previous receivers. Came out as a great match to the dash. The distance from which you spray dictates the coarseness of the texture. Practice on a piece of cardboard, then go nutts It'll come out great, just be sure to roughen up the faceplate a bit before applying the paint. I also applied a thin coat of clearcoat to it and it still looks great today.
      Kudos to you for doing something completely different. I've never heard of anyone going to such lengths to automate the stock airbox. That being said, I'd never do it. The manual knobs are much more simplistic and straightforward to use. Seems like a painful road to add in a ton of relays and wires, all while decreasing usability to boot. I'm sure it's something you've always wanted for yourself though, so thanks for sharing it with us
    10. Member WiSatman's Avatar
      Sep 5th, 2007
      Madison, WI
      04-22-2012 10:38 PM #10
      Textured plastic paint worked great
    11. Member petethepug's Avatar
      May 25th, 2001
      So Cal
      Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat 07 3x White NB & 08 Yukon Denali XL to tow em
      04-22-2012 10:55 PM #11
      Schweet!
      You know were all waiting for you to get the double din conversion from the Chinese Golf to put a flush mount touch screen in there.
      How would you rank the difficulty of the install compared to a custom Crestron install? You got this done pretty damn quick.
      !! opɐɹɹoɔ ǝɥʇ!!ƃuıʇɔǝdsǝɹ !!!
      !! odarroɔ ǝht gnitɔepser !!
    12. Member Benstanczik's Avatar
      Apr 11th, 2011
      Ft. Myers
      Mk5 Diesel, VR6 SLC Corrado
      04-22-2012 11:00 PM #12
      pretty damn sweet. Must of taken a lot of time to wire up
      "You can drink lava, but only once"
      Corrado build
    13. Member dasbeast3.0's Avatar
      Aug 14th, 2007
      Grizzly bear
      04-22-2012 11:14 PM #13
      Awesome work/ project. If you could get rid of the plastic housing and make a clean face integrated into the center dash bezel that would be tittttties. Regardless, very nice job man.
    14. Member WiSatman's Avatar
      Sep 5th, 2007
      Madison, WI
      04-22-2012 11:17 PM #14
      Quote Originally Posted by petethepug View Post
      I wouldn't do this with Crestron, because:
      #1 Crestron requires 24VDC or 120 AC, AMX uses 12VDC, all the equipment that I installed is plugged in without having to convert.
      #2 Crestron has no small control frames, I tried to hide an old Gentner AP800 DSP for my stereo and deemed it to big, it was a single rack unit like a Crestron frame.
      #3 Crestron Products seem to run about three times as much as AMX. I bought all the AMX gear for about $350 on ebay Crestron would of been probably $1000+
      #4 I don't believe Crestron has a double din sized panel and I don't think they support any video input. I don't know that I will use the video input, but I like that I have the option.
      I'm sure setting the program up probably would of taken the same amount of time, but again I don't think the Crestron panels are as capable as the AMX ones for this application.
    15. Member g60racer's Avatar
      Nov 18th, 2000
      South Bend
      04-22-2012 11:44 PM #15
      Well played, sir. Well played.
      Brendan Prout
      04 R32 145k miles
    16. Member Tk2g60's Avatar
      Aug 26th, 2010
      Eastern PA
      1993 vr6 Corrado, 2000 vr6 Jetta(sold) 1991 g60(sold) 93 BMW 318ti(sold)
      04-22-2012 11:50 PM #16
      Looks awesome now that it's painted black great idea with that touch screen
      WTB: Estyles Headers
      My build thread-->The Gift and The Curse
      If you live in PA and own a Corrado click here-> Pennsylvania's Corrado's
      Shop Spoonfed Tuning for your Corrado essentials
    17. Member BmoreDubs's Avatar
      Aug 25th, 2009
      Baltimore/NYC
      boards&4wheelgermans
      04-23-2012 12:16 AM #17
      good job! mold that screen into bezel
      America... just a nation of two hundred million used car salesmen.
      -Hunter S. Thompson
      www.believebaltimore.com
    18. 04-23-2012 01:09 AM #18
      wowzers, digitized controls.
    19. 04-23-2012 04:34 AM #19
      Will this work during the WI winters?
      ENVIRONMENTAL
      Operating Temperature: 0° C (32° F) to 40° C (104° F)
      Operating Humidity: 20% to 85% RH
      Storage Temperature: -20° C (-4° F) to 60° C (140° F)
      Storage Humidity: 5% to 85% RH
    20. Member WiSatman's Avatar
      Sep 5th, 2007
      Madison, WI
      04-23-2012 06:33 AM #20
      Quote Originally Posted by a_riot View Post
      ENVIRONMENTAL
      Damn you're right I'm screwed, I'm sure it won't work with that in mind. I know how all Iphones break here in the winter.
      Iphone Environmental Requirements
      •Operating temperature: 32° to 95° F (0° to 35° C)
      •Nonoperating temperature: −4° to 113° F (−20° to 45° C)
      •Relative humidity: 5% to 95% noncondensing
      •Maximum operating altitude: 10,000 feet (3000 m)
      Dude, I already told you I'm not running my car in the winter in the last thread. If you're so worried about this then I would recommend that you not install a system like this. As for me, it's my car and I'll do the same thing that I do when anything breaks in my car, fix it.
    21. Member cstanley19's Avatar
      Sep 23rd, 2006
      Osan AB, South Korea
      92 Corrado VRT, 2012 E63 AMG
      04-23-2012 07:29 AM #21
      Looks awesome, and Dave got some love on your desk top! haha really slick man, I wish I had the patience and technical ability for a project like that. Very intuitive.
    22. Member SlowVRT's Avatar
      Jan 3rd, 2009
      Jacksonville, Florida
      92 Corrado SLC, 2001 Audi S4, 2013 CC
      04-23-2012 09:43 AM #22
      Looks awesome dude. Your motor idles just like mine lol!
      Sent from my DROID2 using Tapatalk 2
    23. Member xtremevdub's Avatar
      Jun 25th, 2004
      Neo Tokyo, Florida
      1991 Corrado 16VT Aqua Blue Pearl effect. 2004 Audi A4 1.8T Ultra Sport (Daily)
      04-23-2012 10:06 AM #23
      Looks pretty decent I would have painted the AMX black also to blend a little better, but may be in the future you can find or make a smaller bezel or shave it a tad so it looks cleaner.
      Sick project overall.
    24. Member Sr. Karmann's Avatar
      Feb 4th, 2009
      Jacksonville, FL
      91 Corrado 2.0l 16v on MS3X, Parked like Jurassic... 83 Cabby 1.8l 16v... 88 Powerplay XLT-185
      04-23-2012 11:07 AM #24
      Pretty slick, operations wise
      Not too fond of the bezel, but sometimes the bad comes with the good
      Quote Originally Posted by crazynorweegian View Post
      Good luck, might want to get vaccinated for "while-I-am-in-there" syndrome.
      tek-euro.com SpoonFedTuning
      my Corrado's specs on corrado-database / My Corrado Build Thread / My Cabby Build Thread / My Boat Build: 18' Powerplay w/5.7l V8
    25. Member Boostedcorrados's Avatar
      Dec 2nd, 2003
      Firestone/Longmont
      87 toyota with taco dash,3rz,duals,Diamonds and more, 93 c3500 soon to be on air
      04-23-2012 01:21 PM #25
      It may not look the best but man is it sweet! if only the screen sat more flush and it looked a bit more factory
      its sweet either way.
