Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 35 of 141
Thread: INA baffled oil pan (with extra ground clearance)
  1. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-08-2012 11:13 PM #1
    So I recently had the privilege of installing the new INA VR6 race oil pan on my car. The unit that I have is a pre-production unit, but as far as i know the production version is more or less the exact same.
    main benefits of this pan.
    - extra ground clearance. this pan sits over an inch higher than an OEM 12v pan.
    - extra volume for increased cooling (7 liters of oil in my system without an external oil cooler).
    - baffled, to keep oil at the pick up for the track or windy roads (or even on long highway ramps).
    - fittings for oil return (front and rear), as well as for oil temp probe.
    - steel, so will be more durable (unlike the mk5 r32 unit).
    I'm not sure on pricing or availability, but if you are interest, please message Isaam.
    now for the install.
    first, here are 2 overview pics of the pan, so you can see how it looks. (all hail my Wurth spray bomb skills)
    and now two pics of the internals. you can see the proper trap door style baffles, as well as magnetic drain plug.
    now to give you a sense of the OEM pan, and how much clearance it has. Take note of the bottom of the pan in relationship to the bellhousing as well as the subframe.
    the biggest concern of course is that the OEM pan is the lowest point of the car, and sits lower than the subframe.
    now with the OEM pan removed, you can see the stock oil pump/pickup.
    now look at the mk5 r32 pump/pickup. It is instantly obvious how much higher it sits (and how much of my powdercoating came off, lol)
    and then.... drum roll please..................
    the INA pan installed.
    the most important pic, where you can clearly see that the pan is now higher than the subframe.
    Thats it for now. Unfortunately i didnt get before and after pics of the ground clearance with the car on the ground. But its just too hard to get a good pic of that. But there is probably 1 1/2 inches of additional clearance. The other thing is that I'm actually seeing a bit higher oil pressure now, which may be because of the fresh oil pump.
    If anyone has any questions, feel free to ask.
    I think this is a great product, and its nice to see companies like INA continue to support the VR6 platform.
    Here is a link to the album where the pics are stored in case you want to see the full size version of the pics.
    https://picasaweb.google.com/1012223...839/INAOilPan#
    Oct 18th, 2001
    CT
    '90 Corrado vr
    04-09-2012 10:46 PM #2
    im in for sure, any idea if it will work with a crank scraper? im sure it would.
  3. Member Ziptied's Avatar
    Dec 1st, 2009
    Campbellsport, Wisconsin
    91 gti with six cylinders / 83 jetta turbo diesel / 98 jetta tdi
    04-10-2012 03:52 PM #3
    Is r32 pump required to run pan? Either way looks like a nice product
  4. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    04-10-2012 04:46 PM #4
    Quote Originally Posted by Ziptied View Post
    Looks like it... It looks like the stock pumps' pickup is lower than the INA oil pan.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  5. Member monkeydoc's Avatar
    Mar 2nd, 2004
    Center City Philly
    93 Corrado VRT, 07 A4 Avant, 02 325xi, 92 Jetta GL, 00 Jetta GLS VR6, 88 Jetta GL, ...
    04-10-2012 05:19 PM #5
    this is awesome - any idea on the availability for public market, or is it going to be a custom order kind-of-thing?
    Either way, count me in as well. If the price is right I'd buy it yesterday
    /////////Eurofine
    NEK ...philly rep
  6. Member Ziptied's Avatar
    Dec 1st, 2009
    04-11-2012 08:48 AM #6
    Any word on price?
  7. Member VR SEX's Avatar
    Apr 2nd, 2002
    Ft. Lauderdale, Florida
    93 SLC / 01 Jetta GLX / another project
    04-11-2012 10:55 AM #7
    interested
    -Andrew-
    Turbine Mechanic
  8. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    04-11-2012 11:33 AM #8
    Hmmmm, will this be going into production soon? Def agreat looking product
    Sucks I just bought a new standard 12V OEM when I did my rebuild... ohwell.
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
  9. Member mk3alltheway's Avatar
    Feb 9th, 2011
    Jefferson, NJ
    99 Wolfsburg (RIP) 97 CBR 600 F3 (Sold) 97 jetta glx (parted), 99 CBR 600 F4, 1991 Gti
    04-11-2012 11:45 AM #9
    I find it interesting that the r32 oil pump is required with this pan. Is it just because of clearance issues?
    Id love to get one but keep my oem oil pump..
  10. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    04-11-2012 12:26 PM #10
    Quote Originally Posted by mk3alltheway View Post
    That's the thing, on the VR6 oil pump the pick-up is one piece with the pump itself. So the only pump with the higher pick-up is the R32 pump.
    If the pick-up was a bolt on like say a Mk3 2.0 (ABA), then a modified tube would be all you'd need.
  11. Member mk3alltheway's Avatar
    Feb 9th, 2011
    Jefferson, NJ
    04-11-2012 04:23 PM #11
    Quote Originally Posted by Scotty_2.0 View Post
    Fair enough, as far as the higher oil pressure. Will that effect anything?
  12. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-11-2012 09:28 PM #12
    We designed these around the MKV R32 Oil Pump as it sits approx 30mm towards the pan rail than the MKIV/MKIII VR6 Oil Pumps. Not only does this allow extra ground clearance but being a truly engineered piece allowed us to add volume in areas not possible with the cast unit.
    Ball Park is going to be around $600 with the MKV R32 Oil pump, as always feed back is appreciated.
    Scott thanks so much for the write up!
  13. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-11-2012 10:50 PM #13
    Quote Originally Posted by Issam Abed View Post
    you're quite welcome. its an awesome upgrade to my car.
  14. Member VR SEX's Avatar
    Apr 2nd, 2002
    04-12-2012 02:52 AM #14
    Cost with out pump? I have an mk5 pump already for my engine build.
    -Andrew-
    Turbine Mechanic
  15. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    04-12-2012 09:22 AM #15
    Any idea on how soon this will be available...? Thinking I need to set aside some $$
  16. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-12-2012 09:07 PM #16
    Quote Originally Posted by VR SEX View Post
    If you bought the pump you would know they are not cheap
    I want to MSRP them for $399 USD as that is what we have the 1.8T units going for.
  17. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    04-12-2012 09:21 PM #17
    Not bad at all. At 400 w/out pump it'd be more cost efficient to buy this then to make it. Simple but complex. I like it.
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  18. Member VR SEX's Avatar
    Apr 2nd, 2002
    04-12-2012 09:28 PM #18
    Yea i was lucky enough to get it from 1stvwparts a while back for right smack around 200.00
    which isn't cheap i know
    -Andrew-
    Turbine Mechanic
  19. 04-13-2012 11:58 PM #19
    $400 is a steal.
    Are you from New Jersey, or did you just get the paint job in New Jersey?
  20. Member .therealvrt's Avatar
    Mar 29th, 2006
    Ottawa
    94 golf vrt ( sold after 18.5 years of fun)
    04-14-2012 01:52 PM #20
    holy fawk.....
    thanks for mentioning this the other night
    11.91@121 mph. slicks, pump gas, full exhaust vrt v.2.0
    12.09@127 mph. 205 40 17 falkens, pump gas, full exhaust vrt v.3.0
    member since 2002 -banned several times
  21. 04-14-2012 04:10 PM #21
    in for updates. Wouldnt mind one of these
  22. Member DJ-Vr6's Avatar
    Jan 17th, 2006
    NY
    2000 GTI VR6
    04-14-2012 06:22 PM #22
    Quote Originally Posted by WannabeVWguy View Post
  23. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-14-2012 11:19 PM #23
    Quote Originally Posted by .therealvrt View Post
    holy fawk.....
    It slipped my mind , I swear
  24. Member luckypenney's Avatar
    Nov 29th, 2010
    Jeffersonville, VT
    '87 GTi (sold), '04 BMP .:R32T
    04-21-2012 06:38 AM #24
    In for updates. My Mk4 .:R might want one.
  25. 04-21-2012 03:14 PM #25
    im in love how much for 1998 vr6
    Sent from my iPhone using Tapatalk Reihenmotors
  26. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    04-21-2012 03:48 PM #26
    Quote Originally Posted by llanowar View Post
    Trying to keep the MSRP around $399 for the unit but with the extra material and labour to weld its proving tight. Seriously speaking how many of you want one of these?
    Jump on the list and tell a friend.
    The more we get on the cheaper it gets.
    INA Engineering Inc.
    Email | Facebook
    INA Billet | 034 EFI | Mahle Powerpak | DM Forged | Ferrea | Supertech | ARP | South Bend | HTA Turbochargers | Mocal Oil control | DBW Throttle Body Upgrades
  27. Member mk3alltheway's Avatar
    Feb 9th, 2011
    Jefferson, NJ
    04-21-2012 03:53 PM #27
    If the price is right id take one
  28. Forum Sponsor INA's Avatar
    Nov 15th, 2005
    EARTH
    Too many to list
    04-21-2012 03:56 PM #28
    Lets call it $399 for now...
    Email | Facebook
  29. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    04-21-2012 04:27 PM #29
    Quote Originally Posted by INA View Post
    Sounds good, been spreading the word amongst my 12V friends.
    So far me plus one interested.
  30. Member VR SEX's Avatar
    Apr 2nd, 2002
    04-21-2012 08:45 PM #30
    you should put this in the FI forum
    When can we call to place orders?
    -Andrew-
    Turbine Mechanic
  31. Member Issam Abed's Avatar
    Feb 12th, 2004
    EVERYWHERE
    91 Audi 80 2.0T
    04-21-2012 11:05 PM #31
    Maybe someone here can cross post in the FI forum? I do not want to do an official thread until we have the MKV R32 oil pumps in stock.
  32. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    04-21-2012 11:49 PM #32
    done
  33. Member
    Dec 29th, 2008
    Victoria, BC
    1993 VW Corrado VR6
    04-22-2012 07:03 PM #33
    Im interested, just keep me posted. Cash in hands... will need the pub aswell.
    Also, just curious, i know with the mkv pan you had to drill a hole for the dip stick, im assuming this isnt the case for these pans?
    Cheers,
    Stephen
    Hondas are pretty sick.....just saying.
  34. Member mk3alltheway's Avatar
    Feb 9th, 2011
    Jefferson, NJ
    04-22-2012 07:22 PM #34
    For the r32 pump and the pan?
  35. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    04-22-2012 09:38 PM #35
    Don't we all wish..... lol.
    He's talking pan on it's own.
