Results 1 to 29 of 29
Thread: Oil-y leak up front
  1. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    96 Jetta - 300K Club, Truck, Boat, Quad
    04-09-2012 07:45 AM #1
    i went out to start the jetta this am after it sat for 3 days - i have a decent sized somewhat dried puddle in front of the car - the fluid is clear - i know my brake fluid is dirty as hell.....is this power steering fluid? I checked the canister and it's pretty low - what is more keen to blow out first, the pump seal(s) or the hoses? Big/Expensive fix?
    There aint no OZ in rape.
  2. Member Rugrat Anklebiter's Avatar
    Dec 5th, 2000
    PSL, FL
    '96 GTI VR6
    04-09-2012 08:26 AM #2
    Pump is around $160, rack is around $275, high pressure hose custom made is $80-100 or $250 for OEM. There is a by-pass part someone on here makes that turns your rack into a manual with no power steering and a belt you can buy to bypass the pump. $45 for the bypass and $20-30 for the belt. This is the cheapest method but won't help if you are leaking from the rack which is between the fire wall and rear of the engine. However, Lucas power steering leak works wonders on the leaking seals of the rack. Costs about $8 at your auto parts store.
    I replaced everything personally and it feels like new!
  3. Member Rugrat Anklebiter's Avatar
    Dec 5th, 2000
    PSL, FL
    '96 GTI VR6
    04-09-2012 08:28 AM #3
    Also, sounds like it is your high pressure hose near your battery tray leaking. Is that the area where the leak is puddling at?
  4. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-09-2012 09:04 AM #4
    Quote Originally Posted by Rugrat Anklebiter View Post
    yes - it's right near my front drivers wheel - almost direct under my batt - will check this hose out tonight, i know they're pretty old - most likely original - (car is a '96)
  5. Member aphythiate's Avatar
    Jul 9th, 2007
    IL
    a turd
    04-09-2012 09:44 AM #5
    You can get a ps pressure hose for about 30 bucks at a parts store.
    It's part number 92030 in Edelmann.
    LW5Z Enthusiast
  6. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-09-2012 09:51 AM #6
    Quote Originally Posted by aphythiate View Post
    LW5Z Enthusiast
    awesome, already found it for 35$ - thanks dude. Any other things i should check/replace? i have no noises as of yet from the pump and would like to not blow it out - have lift access this weekend.
  7. Member Sky-Fi's Avatar
    Jan 19th, 2008
    Charleston, SC
    97 LG5R Jetta GLS
    04-09-2012 11:14 AM #7
    Quote Originally Posted by WakusPakus View Post
    Any other things i should check/replace?- have lift access this weekend.
    It's never a bad idea to do the oil cooler gasket. $2 o-ring can ruin your whole day if it gets old and cracked and decides to blow out. Don't really need a lift for that though.
    We need a series like this state-side. I'm in if there is one, or will be one. VW Cup 2013, anyone?
  8. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-09-2012 12:41 PM #8
    Quote Originally Posted by Sky-Fi View Post
    will do!! thanks for the heads up - had NO idea about this
    Mar 23rd, 2008
    N/A
    N/A
    04-09-2012 01:52 PM #9
    You can get the high pressure hose for about $20 from rockauto.com. They usually have 2-3 different brands to choose from.
    I got my Edelman from them when they had some closeouts for $10.
    But, power steering fluid doesn't dry up/evaporate. Are you sure what you saw is not coolant? What color is your coolant, right now? You could have a leak from the radiator, the thermofan switch, or a hose (running across the bottom of the car from the right side).
  10. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-09-2012 02:28 PM #10
    Quote Originally Posted by germancarnut51 View Post
    it didn't dry up - it's seeped into the concrete but still able to pick up by finger.
    my coolant leak was just recently repaired - that fluid is green - i've been around the block enough to know my fluids.
    oil levels are good, coolant is good, trans is good, brake is good, p/s is almost dry.
    the fluid (on my finger this AM) was clear.
  11. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-09-2012 02:55 PM #11
    p/s was low, i threw some in - it's up to level now.....when i went outside to go to the gas station to get more....there were no leaks.
    any ideas?
  12. Member aphythiate's Avatar
    Jul 9th, 2007
    IL
    a turd
    04-09-2012 04:59 PM #12
    It could be your rack leaking. Take a look at the inner end boots, and if they're wet... boom, Bob's your uncle. A rack leak may leave a somewhat infrequent drip, as it may collect all around your k-frame before it drips down.
  13. Member
    Mar 23rd, 2008
    N/A
    N/A
    04-09-2012 05:24 PM #13
    MKIIIs use a special fluid in the power steering and automatic transmissions. You can't get the stuff at the corner gas station.
    It's named Pentosin. It's clear or yellowish color. You can get it at the VW Dealer, and some VW Specialty/Aftermarket Shops.
    DO NOT POUR THE NORMAL RED STUFF IN YOUR POWER STEERING SYSTEM.
  14. Member aphythiate's Avatar
    Jul 9th, 2007
    IL
    a turd
    04-09-2012 05:27 PM #14
    Probably too late for that...
  15. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-09-2012 08:52 PM #15
    Nope. Gas station happens to be a vw shop for vw/audi parts only.
    Sent from my BlackBerry 9650 using Tapatalk
  16. Member Rugrat Anklebiter's Avatar
    Dec 5th, 2000
    PSL, FL
    '96 GTI VR6
    04-10-2012 05:07 AM #16
    Damn I got raped on the high pressure hose then.
  17. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-10-2012 08:17 AM #17
    got up this AM, checked again, nothin.
    my already repaired coolant leak is back....damn shop coulda changed out my ORIGINAL coolant hoses but NOOO.
    time for those. as far as the mystery fluid....all levels normal this AM and no new leaks...will keep an eye out in the parking lot here @ work...will check steering boots this weekend on the lift.
  18. Member
    Mar 23rd, 2008
    N/A
    N/A
    04-10-2012 12:59 PM #18
    It's probably a really slow leak.
    If the steering rack boots are leaking, the seals in the rack are shot. You can buy a seal kit and refurbish your old rack, but the seal kit would probably cost more than a used rack from a Vortex Member.
    I'd recommend buying a used rack, streering racks are pretty durable parts (unless the car was abused). Before you buy a used one, pull back the boots, and check for leaks. If the boots are already torn, and there's ugly crud in there, look for another, that one's a poor candidate. Buy new boots and install before you put the rack in your car.
    Check the high pressure hose from the pump to the rack, and if it's seeping or leaking anywhere, change it at the same time you change the rack.
  19. Member OddJobb's Avatar
    Nov 6th, 2004
    Greenville SC
    2004.5 Jetta GLI, 1995 Golf III City
    04-10-2012 08:18 PM #19
    Automatic or manual transmission? If manual, it may be you transmission output shaft seal leaking and it may be gear oil. Look to see if you have oil contamination on the drive axle.
  20. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-10-2012 09:39 PM #20
    Quote Originally Posted by OddJobb View Post
    Yep-5speed...I'll check it in the am and let you know what I find
  21. Member OddJobb's Avatar
    Nov 6th, 2004
    Greenville SC
    04-10-2012 10:25 PM #21
    The output shaft seal is on top of the transmission housing. It's where your gear shift linkage connects to the transmission (covered by a small rubber boot). Gear oil will drip down on top of the housing and onto the drive axle because they are really close together. I just wanted to clarify so your not looking at where the drive axle connects to the transmission and become confused.
  22. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-11-2012 09:49 AM #22
    coo - thanks dude, i didn't check it this AM...didn't get up early enough...tomorrow is my late day (in the office for 10AM) so ill check and post up.
  23. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-12-2012 03:23 PM #23
    results are in:
    no more leaking as of yet.
    stop and go leak i guess, or i'm losing my mind and my GF's garage leaks.
    after she's on the lift ill post up again with pics and rack/boot conditions.
  24. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-16-2012 08:46 AM #24
    well i put it on the lift last night for 5-6 hours
    bled my brakes, even did my alignment
    no leaks, no p/s leaks, replaced the high pres hose
    rack is good, boots are good, tie rods are good
    not sure what the hell that leak was, but i may never find out. oh well!
  25. Member
    Feb 7th, 2006
    1995 VW Golf 2.0L, 1998 VW Golf 2.0L, 2011 VW Golf TDI
    04-16-2012 09:23 AM #25
    That WILL ruin your day too! I had that happen to me a few months ago on my 95!
    Geno-Bob
  26. Member ExpoAccel's Avatar
    Jul 6th, 2006
    Lynnwood, WA
    00 Cabrio 97 GLX 97 Cabrio 92 GLI 83 GTI 79 Scirocco
    04-24-2012 06:04 PM #26
    Yesterday was my special day for this. Got the car home (after 4 qts) and found the leak.
  27. Senior Member Dan J Reed's Avatar
    Jul 26th, 2004
    NJ - AKA - Earth's armpit.
    Too many
    04-24-2012 11:05 PM #27
    Quote Originally Posted by ExpoAccel View Post
    http://faculty.ccp.edu/faculty/dreed...seal/index.htm
  28. Member WakusPakus's Avatar
    Feb 13th, 2012
    860 and 727
    04-25-2012 03:56 PM #28
    Just ordered the seal-thanks DJR-my turn!
  29. Member ExpoAccel's Avatar
    Jul 6th, 2006
    Lynnwood, WA
    04-26-2012 09:50 AM #29
    Replaced mine yesterday and it was not too bad except for some light rain as I did this in the driveway. My seal came with a couple of ears with holes that located the seal using the nubs on the cooler. Thanks Dan for the documentation.
