Results 1 to 6 of 6
Thread: Check Engine Light - Bad EVAP Purge Valve
  1. n00b
    Apr 9th, 2012
    2012 Passat SE V6
    04-09-2012 03:57 PM #1
    I only have 2200 miles on my new 2012 Passat SE V6 and the check engine light came on the other morning. I took it in to the dealer and they found codes P0442 (EVAP Emission Control System Small Leak Detected) and P0456 (EVAP Emission Control System Very Small Leak Detected). The tech says on the work order that he removed and tested the EVAP Purge Valve with a vacuum pump and the valve would not hold a vacuum. The dealer replaced the EVAP Purge Valve under warranty. They say this is the first 2012 passat V6 they've seen with this issue. Should I be worried? Any one see this yet? I've only had the car for 4 weeks.
    2012 Passat SE 3.6 | 2008 Jetta SE 2.5
  2. 04-10-2012 08:10 AM #2
    Probably just an aberration (you hope). With luck, this will be the only problem you have with your new Passat (for your sake, and VW's).
    "If stupid got us into this mess, how come it can't get us out?"
    Sep 23rd, 2002
    2012 Passat V6 SE (Night Blue ext / Black int)
    04-10-2012 08:14 AM #3
    Quote Originally Posted by xireon View Post
    I have the same engine as you and 1900 miles on it. Had the car since Oct 2011 and no issues so far.
  4. Member
    Jan 18th, 2001
    Texas
    Current: 2010 CW GTI 6spd. Old cars: 02 GTI 337, 04 Audi TT 3.2, 04 R32
    04-15-2012 04:23 PM #4
    I've had a 2010 GTi for 2.5 years and I got the exact same codes and it was the n80 Purge valve. I doubt the issue is common, and since I've only had this issue one I'm pretty impressed. I wouldn't worry about it, it's a minor problem and the v6 should be less issues than 2.0 T since there are no turbo gadgets.
  5. Member brsexton's Avatar
    Mar 30th, 2012
    VA
    2012 Passat SE and 2012 Jetta SE Conv/Sunroof
    03-23-2013 10:20 PM #5
    I just got a CEL and code P0456 (EVAP Emission Control System Very Small Leak Detected) this evening. My car is a 2012 2.5l and has 10400 miles on it. I will take it to the dealer, but I wonder if it could be the gas cap or if it could actually be a bad valve like the OP? Do these cars have a "gas cap light" like some models have? I checked the cap and made sure it was tight.
  6. Member brsexton's Avatar
    Mar 30th, 2012
    VA
    04-24-2013 07:08 PM #6
    Quote Originally Posted by brsexton View Post
    Well I took my car in a few weeks ago and they replaced the gas cap for that code. Fast forward to this past Saturday and the CEL came on again with the same code. I took it back to the dealer yesterday and they ran more tests and found that the N80 evap purge valve was bad on mine as well. Luckily they had one in stock and it didn't have to be ordered. I guess time will tell if that fixes my CEL issue.
