Results 1 to 20 of 20
Thread: Proper way to do the timing on a 1.8 16v?
  1. Member Vdubbin305's Avatar
    Feb 12th, 2010
    Atlanta, GA
    2004 Audi A4 1.8T,1981 rabbit diesel truck, 1987 Volkswagen GTI 16v, 2001 Vw Jetta GLS r.i.p.
    04-09-2012 04:00 PM #1
    Can anyone tell me the proper way to do the timing on a 1.8 16v, or point me in the right direction? I've searched on the forum but most of them are for 2.0 16vs or the thread has dead pics. i need to do this over the weekend and I want to make sure its done properly, that way the timing doesnt slip and then i have bent valves
  2. Member weejunGL's Avatar
    Feb 2nd, 2005
    Norwegen
    MKII G60 Syncro
    04-09-2012 04:07 PM #2
    are you talking about setting the initial timing?
    bad ignition timing won't slip your belt and bend your valves but setting the crank vs. head initial timing can do that
  3. Member Vdubbin305's Avatar
    Feb 12th, 2010
    Atlanta, GA
    04-09-2012 04:29 PM #3
    yes, the initial timing! and if i can also get pointed in the right direction for the ignition timing, it would be greatly appreciated
  4. Member weejunGL's Avatar
    Feb 2nd, 2005
    Norwegen
    MKII G60 Syncro
    04-09-2012 04:37 PM #4
    initial timing is just like the 2L
    crank at TDC, then the mark on the campulley at the arrow on the valvecover
    the IM shaft does not need any special orientation on the pulley
    only crank and cam pulley is important. and ensure that your distributor isn't 180 degrees off, because that can happen
  5. Member Vdubbin305's Avatar
    Feb 12th, 2010
    Atlanta, GA
    04-09-2012 05:28 PM #5
    got it, thanks man!
  6. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    '87 Mk2 Golf GTI 16v
    04-09-2012 11:44 PM #6
    I'm changing my timing belt soon too, and so I need this info as well. Which one is the TDC timing mark? Aren't there a few different timing marks?
    My current project: 1987 Mk2 Golf GTI 16v
    My previous project: 1984 Mk1 Rabbit GTI 16v
  7. Member Smiff's Avatar
    Jan 4th, 2011
    Something about Buckeyes I think
    89 GLi dead atm, 00 B5 ATW Wagon, 86 Audi 4ks daily
    04-10-2012 06:54 AM #7
    Like gold, worth the investment....
  8. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-10-2012 09:47 AM #8
    Quote Originally Posted by Slacker20 View Post
    Wait, you said in another post you have the manual, are you saying you can't read words and not just the wiring diagrams, also?
    FS:Sunroof Deflector
  9. Member Madvwz's Avatar
    Jun 27th, 2002
    Madison, WI
    86 GTI, 89 BBM GTI, 98 Jetta
    04-10-2012 10:02 AM #9
    Quote Originally Posted by Smiff View Post
    ^this^
    BEN'S VEEDUB SHOP
    MADSPEED
    ..i'll put firecrackers in your nutsack..and blow your ball$ all over your pants..
  10. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    04-10-2012 04:53 PM #10
    I do have the Bentley, but page 13 of section 3 merely says: "Using a socket wrench on the camshaft vibration damper bolt, rotate the engine by hand to set the No. 1 cylinder to Top Dead Center (TDC). Rotate the crankshaft again 1 3/4 revolutions (about 1/4 turn before No. 1 TDC). Note - Check the position of the distributor rotor or the flywheel ignition timing marks to confirm cylinder No. 1 TDC. The vibration damper mark alone could indicate TDC for cylinder No. 1 or No. 4." Section 8 page 19-20 (To check basic ignition timing) is only for checking the timing with the engine running and the idle adjustment correct. I can't find any mention of the TDC marks anywhere in the Bentley.
  11. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-10-2012 05:09 PM #11
    What TDC mark can you not find? There is one on the crankshaft damper(that lines up with a mark on the TB cover), there is one on the cam sprocket (that lines up with the arrow on the VC) and there is one on the FW(that will align with the pointer in the hole in the bell-housing) and there is one in the dizzy that the rotor will point to.
  12. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    04-10-2012 11:51 PM #12
    Quote Originally Posted by ps2375 View Post
    The flywheel. Aren't there other timing marks on the flywheel other than just TDC? Which one will I be looking for?
  13. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-11-2012 09:06 AM #13
    There is a"0" mark, which is TDC. And there is a "V" notch, which is 6*BTDC.
  14. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    04-11-2012 04:43 PM #14
    Thanks, that's all I was wanting to know.
  15. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    04-11-2012 08:12 PM #15
    That is in the manual...
  16. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    05-03-2012 08:21 PM #16
    So... my head timing marks are 180* off from the crankshaft TDC, as in when I align the vibration damper to TDC (checking the flywheel to make sure it is aligned to TDC as well), my camshaft sprocket's timing mark is pointing down, 180* from the V timing mark on the valve cover
    Do I need to align the head timing marks to the vertical V on the valve cover as instructed in the manual, or leave it the 180* off that it was before the removal of the timing belt? I was told the engine was stock and didn't have an aftermarket cam, but would an aftermarket cam change the initial head vs crank timing marks? By as much as 180*?
    My distributor rotor also appears to not quite align with the TDC mark on the distributor casing...
  17. Member Smiff's Avatar
    Jan 4th, 2011
    05-03-2012 11:00 PM #17
    One or both cams may be installed wrong. Pull the valve cover and look for the timing marks on the timing gears at the chain end of the cams. Check out this thread for some good pics and info:
    http://forums.vwvortex.com/showthrea...y-Thread/page3
  18. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    05-04-2012 02:00 AM #18
    I set the camshaft pulley to the correct timing marks and, after re-installing the timing belt, I was able to rotate the engine multiple times by hand without any binding issues. Checked the marks again, made a one-tooth adjustment on the timing belt, rotated it over a couple more times, and everything seems to be in order. I haven't attempted a start up yet though, I called it quits for the day being as how it was 12:30am
  19. Member
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    05-04-2012 11:14 PM #19
    If stuff is nasty or hard to see I like to take out plug #1, insert a long 1/4" extension and use it to find TDC while turning the engine with a ratchet. You just turn it till the extension (piston) is at its highest point. This is real easy since the spark plug is in the center and straight up.
    At tdc:
    a mark on the cam pulley aligns with an arrow on the valve cover
    a line on the crank pulley aligns with an arrow on the plastic timing belt cover. When I can I like to put some paint into the arrow on the plastic timing cover for better visibility
    the timing mark is visible at the top of the flywheel
    Sometimes these may not all all align perfectly, but still they should be very close to on the mark.
  20. Member HeyMayneItsB's Avatar
    Feb 10th, 2010
    Atlanta, GA
    05-05-2012 12:53 AM #20
    Quote Originally Posted by antichristonwheels View Post
    At tdc:
    That's exactly what I did, using a couple socket extensions as a visual guide. And at true TDC, the crankshaft vibration damper was just about right on the mark, the flywheel was dead on, but the camshaft sprocket was exactly 180° off (pointing straight down rather than up at the V in the valve cover). I corrected everything so that every mark was dead on, rotated the engine a few times by hand to make sure all was well, started it up, and used a timing light to dial in the distributor, and it's running great! The addition of the O2 sensor (never had one when I bought it) helped tremendously as well.
