#36
Not sure if it's as bad as the trim for my tahoe was to remove, but I picked up one of these http://www.amazon.com/3M-Stripe-Whee.../dp/B00063VT0G Removed the adhesive without messing with the clear coat. attaches to a drill and as long as u dont sit in the same spot with it, it works great. just my $.02
#37
#38
Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
#39
Unitronic>Revo and hauling ass! K04 w/ RS4 injectors, Forge WINtake, Eurojet intercooler, ECS lightweight pulley, APR TBE, APR hpfp, BSH TB pipe, Forge DV, Neuspeed K04 discharge pipe, ECS dogbone mount, BFI stage 2 engine & tranny mount, 42 DD Ultimate catch can, HPFP Upgrade 145 BAR FRV, Snow Performance Stage 2 water/meth kit, Level 10 valve body rebuild
#40
Did some work to my engine bay recently:
1. Removed oil filler neck.
2. Painted washer fluid cap black
3. Installed Forge DV w/ red vacuum hose
4. Cleaned up a bit to be able to leave hood popped at shows.
Ordered Forge oil and coolant caps, but they accidentally sent wrong finish. Should have those on before Staggered 2012 next weekend. Contemplating JCaps washer fluid cap, but just cant fathom spending $75 on one piece. Just need to order some red silicone hose for dv relocate to match vacuum hose. Thinking of having my dv relocate pipe powder-coated over winter...maybe red...or black. The green on the BFI mount sticks out, but oh well.
Quick Forge DV review: I went for a quick spin after installing to make sure everything was working fine. I did notice that I spooled a tad quicker, and it makes an awesome sound, way better than the sound my Rev D made with the Forge spacer. The install was easy. I used red zip ties to help secure lines from popping off.
#41
Had this installed:
http://hpfpupgrade.com/Products/Show...nce+Rail+Valve
I chose the 145 BAR. I felt a difference in acceleration immediately. My boy who is a VW tech was able to get the OEM unit off without removing the Intake Manifold, he then spent about an hour getting the aftermarket unit in. Luckily, he has small hands. If you don`t, you will probably have to remove the intake manifold. IMO, well worth the money if you are tuned Stage 2+ or above.
#42
Unitronic Stage 2 -- 42DD 3" catless downpipe -- votex front lip -- HiDef side skirts -- painted rear valence -- mkvi wheel w/DSG paddles -- DDM HID headlights -- Euro side markers -- Interior & licence plate LEDs -- Skyline style Euro Tail Lights -- Podi gauge and pod kit -- revision D diverter valve -- Eibach DG springs (waiting to be installed)
#43
What would keep someone from changing the Fuel Lobe profile for more fueling? I know price is a factory but at an engineering standpoint?
#44
#45
Went to Staggered 2012 tooday. Had an awesome time.
Engine Pic (Forge alloy caps installed, picked up windshield washer fluid cap at the show):
Little bit of sticker action:
#46
Lookin good! Is that a one piece tip rather than the usual dual exit look?
Can you post a pic of that when you get a chance?
2006 Passat 2.0T Tiptronic | Unitronic Stage 1+ | Rokkor Coil Overs | White Line Control Arm Bushings | BFI Tranny Mount | Nuespeed P-Flo Intake | Newsouth Boost Gauge | AWE DV | BSH PCV fix | eBay Climate Knobs | Autotech Exhaust | DDM HIDs | Stereo Upgrades | Bentley Manual | VCDS
2008 Touareg VR6
#47
#49
#51
Well, as many of you know, and the rest will learn eventually; buying a house and house projects slows down the modding significantly. But here goes.....
Switched to the MRRs earlier this week.
^ Quick cellphone pics taken this morning, pics dont do it justice, the wheels look better in person.
Currently...I am sitting in the Dunkin Donuts next to Level 10 Performance having my valve body upgraded. Talked with Pat (Owner); he drove my car, asked about my upgrades, and even inquired about future upgrades so that he can tailor valve body upgrade to them. He stated that normal turn around time is 3-4 hours. So....I will post a review of the rebuild this weekend. Im so excited that I can finally rip my car and not worry.
On another note, I have decided to downgrade my stereo system as its mighty heavy, and not really needed. Im going to sell my current setup and switch to one 10 or 12 and a small amp.
List to do before Waterfest:
1. Remove tailight film and lightly tint with VHT paint.
2. Touch up Plasti Dip on window trim.
3. Mount euro plate bracket on front grille.
4. Fix paint chips.
5. Clay bar and buff paint.
#52
Another awesome project I'm excited to hear more about.
Let me know if you are heading to Rochester for work or anything and we can meet up. I am rarely near Syracuse myself.
2008 Touareg VR6
#53
Im Excited that you finally get to rip on your car. You have some self discipline man. It would have driven me crazy not being able to really get on it
Have you ever considered upgrading the tranny cooler?
#54
#55
It was hard, but i knew it would be worth it. Knowing that i dont have to worry makes me more relaxed.
I have not upgraded cooler yet, and will not. After talking to Pat from Level 10. He informed me that the pump has to work harder to fill the cooler, which causes a negative effect. The upgraded valve body runs at normal temp. O drove about 250 miles today after the rebuild, and am very happy. The car is absolutely better. The power is laid down better. The only negative is that i can feel the shifts a bit more, but im sure thats amplified due to stage 2 mounts.
#56
Worked a bit on the Passat yesterday getting ready for Waterfest.
1. Finally mounted my europlate frame and europlate.
2. Touched up a few spots on plasti dip on window trim.
3. Added some more stickers to rear windshield.
4. Removed subs and amp.
#57
So I installed my LED interior light kit and license plate lights from Krauto Parts last night. The kit is super affordable, and uses the same lights as many other kits out there. Here are some pics:
As stated, the kit includes all interior lights, glovebox, and license plate lights. He will have a tent at Waterfest, and be offering an awesome special, and one including installation there. Check out his website: http://www.krautoparts.com/#!home/mainPage You can use the Contact link to ask him for deals and prices as I do not want to be made that im advertising. He has some sweet backup LED lights, as well as H& and H11 LED lights that will be available as well. We also developed a kit for Touareg owners out there.
#58
WHich Kit do I get? The Audi b6?
#59
#60
Have your been railing on the car since the valve body upgrade?
2008 Touareg VR6
#61
#62
I would love to see the results of that.
2008 Touareg VR6
#63
Been a busy summer with new job hours, house projects, and trying to make shows. I need to get some great pics of my car..... But look what I got:
Stage 2 kit, 2.5 gallon reservoir, USRT TB spacer, dual nozzle kit. Going to try and tackle this over the fall or winter.
Also, sold my big system. Didn`t use as much and wanted to lighten up a bit. Picked this up at Waterfest:
I originally had a smaller box, but the sub was too deep.
I am trying to find another intake manifold to shave and paint over the winter. Also going to try and dress up the engine bay over the next few months. I would like to paint the valve cover and polish some of the metal.
I am still in the air about the Forge K04 actuator over this winter. Its a lot of work!!!! The water/meth will be a great gain alone.
#64
Double post
2008 Touareg VR6
#65
I can't wait for a water/meth review.
2008 Touareg VR6
#66
08 Black TSI Passat /ABT lip/HI-DEF side skirts and spoiler/Color matched rear bumper/Rokkor coilovers/19" Black RS4 wheels
#67
Are you planning on running a 100 oct file with the meth?
Where did you get your paddle shifters from?
2008 Touareg VR6
#68
No, with Revo, i simply adjust my timing to accomodate the setup. This is one reason why I love Revo, i can adjust for different variables. I do not want to change tunes, but APR is releasing a more aggressive K04 tune for us here in US. Revo has released an update in Europe as well, but has not made any announcements on US side. With water/meth and more aggressive tune....i may not go bigger turbo. Their v2 K04 file is putting out GT28 numbers, and water/meth will make those numbers even better.
I purchased the paddle shifters from ECS Tuning. I lpid like $120 for them, and wish i hadnt. I use them, but not much. I mainly shift with the shifter. Id rather get the DSG shifter for a little more for what i paid for paddles. It does make my interior look good though.
#70
