Results 1 to 11 of 11
Thread: Rear Hatch Window Seal?
    Aug 27th, 2003
    San Jose, CA
    '88 16V Scricocco; '00 Taurus
    04-09-2012 07:17 PM #1
    Hi Folks,
    Anyone know where I can get the seal for the rear hatch window? I know it's leaking (or maybe the rear spoiler?) because recently when it rained, I was getting water on the small ledge above the rear tail lights, but inside the hatch to body seal. Plus, I stuck a finger in the holes and there was definitely water in there. I know Vintage Rubber sells the hatch to body seal, but not the window seal.
    What to do?
    Also, any know where there's a thread that will tell me how to fix my rattle-y hatch! Sucker bounces over every bump it seems.
  2. Member crazyaboutrocs's Avatar
    Nov 23rd, 2005
    Winterport, ME
    2 '88 Sciroccos and an '08 MkV GTI
    04-09-2012 07:22 PM #2
    Are you sure it the window seal? Rattly hatch is most likely caused by the little rubber bumper things. If they are missing or not in there right, water will most likely seep right past the body to hatch seal.
  3. Member BluDemon's Avatar
    Jun 19th, 2005
    Dickson, TN
    2012 Golf R (3/12), 2008 Audi RS4, 2004 Aprilia Scarabeo 500, 1988 VW Scirocco
    04-10-2012 11:40 PM #3
  4. Member LoDub1.8T's Avatar
    Jan 18th, 2008
    Nashville, TN.
    2L 16v mk1 scirocco, on digi
    04-10-2012 11:50 PM #4
    I have had NOTHING but great experience with these guys!!
    http://www.vintagerubber.com/trunkli...roccomk1-.aspx
  5. Member red16vdub's Avatar
    Aug 20th, 2009
    somewhere obviously
    04-11-2012 08:07 AM #5
    Yea if ur getting water on the shelving above the taillights its definitely the window seal but best way to determine is climb in trunk & have someone spray water on the hatch. Let me know if you find the window seal cause I need one good luck
    Sent from my DROID RAZR using Tapatalk 2
    • ANYTHING UNATEMPTED REMAINS IMPOSSIBLE
    scIROCco 16v / quattro sport *VOLKSHORE/A dutty dub*
    Aug 15th, 2008
    Golden, CO
    '81 Scirocco S
    04-11-2012 08:36 AM #6
    Vintage Rubber sells the rear window seal.
    http://www.vintagerubber.com/rearcal...ccomk1--1.aspx
    -Kelly
  7. Member LoDub1.8T's Avatar
    Jan 18th, 2008
    Nashville, TN.
    04-11-2012 08:50 AM #7
    edited....sorry for the repost
  8. 04-11-2012 11:15 AM #8
    Quote Originally Posted by pltfnn View Post
    -Kelly
    I believe the OP is in need of a MK2 rear window seal.
    TEAM DHE/FAST 1976 KARMANN 8V FSP MK1 SILVER SCIROCCO 2X 08, 09. 10 & 12 regional champ.
    TEAM DHE/FAST 1980 KARMANN 8V FSP MK1 RED SCIROCCO 04 & 07 regional champ.
    1987 KARMANN 16V MK2 SILVER SCIROCCO
    They are back--> http://www.parts4vws.com Need Wax?--> Mother's
  9. Member onurB's Avatar
    Nov 4th, 2010
    46° 16' 0.02" N 73° 23' 0.02" W
    '87 scala 8v; '05 passat wagon 4motion troop carrier; '05 impreza wagon
    04-11-2012 10:38 PM #9
    Quote Originally Posted by mobiuslogic View Post
    I had this problem too and water was coming inside the trunk hatch from the small holes behind the badges.
    Also, can leaky window seal could cause water infiltration inside the hatch body?
    -Bruno
    Hkalissdöstijd'tabhärhnäck!
    -Old Norse swear word
    Mine
    Aug 27th, 2003
    San Jose, CA
    04-12-2012 05:39 PM #10
    DougT: You are correct, I have a MK2. It's definitely the window seal or the badges though. I can stick my finger in the holes at the bottom and feel water inside the hatch.
    onurB: I actually didn't even consider the badges! So thank you for pointing those out. I'll pop those suckers off (very carefully) and hit them with some silicone sealant. Of course I'd love for it to be nice and simple like that.
    As for the rattle-y hatch, I've tried adjusting those rubber feet, but they don't come out far enough for it to fully firm up. And even with them extended, the hatch still rattles, just at a higher frequency rather than a quick thump up and down over bumps.
    As well though, I'm getting water inside the trunk, and it's pooling up on the inside right trim piece under the cover for the rear washer bottle, and then getting the carpet wet in the back right corner. Could water be splashing up from the wheel and getting in through there as well?
  11. Member 16V_Scirocco_GTX's Avatar
    Jul 18th, 2001
    In the 94086 California
    90 Corrado TDI, 84 Scirocco GTI, 75 Scirocco, 09 Triumph Bonneville
    04-13-2012 03:44 AM #11
    Grab a bottle of water or a hose (maybe have someone do that), and watch from the inside where it's coming from. Only so many options for water intrusion: hatch seal, glass seal, badges, tail light seals and possibly the washer nozzle up on the pillar.
    I can't say I've even seen the glass seal leak.
    Tobias
    90 Corrado TDI, 84 Scirocco GTi, 75 Scirocco 1.8T, 09 Triumph Bonneville
