VWVortex.com - vmaxx adjustment help
    Results 1 to 3 of 3
    Thread: vmaxx adjustment help
    1. Junior Member
      May 25th, 2011
      Southwestern Ontario
      2002 VW Jetta 1.8t
      04-09-2012 08:43 PM #1
      I have the baseline coilover kit from vmaxx on my mk4.
      Bottom line: I went to put on my summer tires, turned the adjustment knob nearly to the top of the threads on the coilovers, take the car back off the jackstands and the thing is sitting so high it's ridiculous.
      If you tighten the spring the car should go lower no? Totally lost and need some help.
      this is my suspension kit: http://www.v-maxx.co.uk/viewproduct.asp?id=116&m2=112
      02' AWP :: UniStage2+ @20psi--Frankenturbo F4H :: Bosch 440cc :: NGK BKR7E@.028 Gap :: B&B 3" TurboBack :: Boostvalve MBC+N75F Parallel :: Forge007p DV :: VMaxx Coilovers
    2. Junior Member
      May 25th, 2011
      2002 VW Jetta 1.8t
      04-09-2012 08:47 PM #2
      Is this just a matter of me adjusting it the wrong way? it looks higher than it did before. Just need to know if I am supposed to expand or compress the spring to lower my ride height, it's my first time doing this so bare with me.
    3. 04-09-2012 09:52 PM #3
      lower it by spinning the collar down.
      raise it by spinning the collar up.
      it has nothing to do with compressing the spring.
