VWVortex.com - Geeky math help requested.
    Results 1 to 9 of 9
    Thread: Geeky math help requested.
    1. 04-10-2012 04:46 AM #1
      I couldn't figure out how to properly phrase this in google, so I'm curious if one of you math nuts can explain this to me.
      I was calculating percentages of some dice rolls (putting together a game). I am using the following.
      1) D4 (four sided dice)
      2) D6 (six sided dice)
      3) D8 (eight sided dice).
      Each dice, when rolled, is "open ended" meaning if a value of 4, 6 or 8 (the highest possible value) is rolled, you may roll the dice again, adding to the original value. This can continue indefinitely.
      I am trying to establish the percentage chance of rolling the following values:
      4+
      5+
      6+
      7+
      The D6 and D8 are quite simple.
      D6
      4+ = 50%
      5+ = 33%
      6+ = 16%
      7+ = 16% (if a 6 is needed, and rolled, the minimum total will be 7)
      D8
      4+ = 63%
      5+ = 50%
      6+ = 38%
      7+ = 25%
      ...now the D4 is what I can't figure out (it's been a few too many years since my last math class).
      D4
      4+ = 25%
      5+ = 25% (Again, if a 4 is needed, and rolled, the minimum value is 5)
      6+ = a 25% chance, followed by a 75% chance ---- what overall chance does this equate to?
      7+ = a 25% chance, followed by a 50% chance ---- what overall chance does this equate to?
      I don't remember the formular to combine two percentage chances into one number - anyone?
      Thanks.
      PS: Part of me wants to simply say the chance is 75% of 25%...or 18.75% --- but it's not that simple right?
    2. Member GeoffD's Avatar
      Aug 13th, 2001
      15 Outback 3.6R
      04-10-2012 07:27 AM #2
      A pair of D4 gives you the following 16 possible combinations:
      1-1
      1-2
      1-3
      1-4
      2-1
      2-2
      2-3
      2-4
      3-1
      3-2
      3-3
      3-4
      4-1
      4-2
      4-3
      4-4
      Just add them up and divide by 16 to get your percentage
      4+ is 12 out of 16 or 75% odds
      5+ is 10 out of 16 or 62.5% odds
      6+ is 6 out of 16 or 37.5% odds
      My university probability theory course was back in 1978. The math behind this is long gone.
    3. 04-10-2012 03:02 PM #3
      I agree, but I'm not initially rolling two dice at once - a second dice is only rolled if the initial result is a 4.
    4. Geriatric Member VegasJetta's Avatar
      Jan 26th, 2003
      SoPo, Maine
      01 XJ 4.0, 13 TCH, 87 Honda TRX250, 82 Honda UrbEx, 85 Honda ATC70, 91 Yamaha YSR50
      04-10-2012 05:23 PM #4
      Quote Originally Posted by JacksSenseOfRejection
      Here's a fun fact: if someone is hitting you with a metal pipe, stay down.
      Apr 28th, 2008
      In a house
      2012 CC Rline Candy White
      04-10-2012 05:26 PM #5
      Done!!
      /thread
    6. Member GTiTOM's Avatar
      May 11th, 2000
      '11 WRX
      04-10-2012 05:39 PM #6
      D4
      4+ = 25%
      Thanks.
      I think it is that simple. I believe you just multiply the odds of the first roll (1/4) times the odds of the second roll.
      The odds of a 4 on the first roll are 1/4, and then the combined odds are then conditional on the second roll:
      5+: 25% (1/1 x 1/4 = 1/4)
      6+: 18.75% (3/4 x 1/4 = 3/16)
      7+: 12.5% (2/4 x 1/4 = 1/8)
      8: 6.25% (1/4 x 1/4 = 1/16)
      Similar to how if you roll two dice, your odds of rolling a 2 (1/6 x 1/6) are the same as rolling a 12 (1/6 x 1/6) or 1/36.
    7. 04-10-2012 06:51 PM #7
      Gotcha. I actually just called my mother, the accountant/super math wiz and we came to the same conclusion. Thank ye kindly.
    8. Member Kameirocco's Avatar
      Dec 19th, 2002
      Portland, Oregon
      2005 Dodge stratus SXT Coupe
      04-10-2012 07:27 PM #8
      Quote Originally Posted by VegasJetta View Post
      "Play a Windows CD backwards and hear scary messages. Thats nothing, play it forwards and it installs Windows"
      Homebrewers of the 'tex. Join us! Home brewers CHECK IN please!
    9. Member Inkarnata's Avatar
      Nov 26th, 2001
      Greensboro, NC
      90 Corrado G60, 01 Golf GLS, 01 GTI VR6, 01 Passat Wagon, 00 GTI VR6, 93 Corrado SLC
      04-10-2012 11:16 PM #9
      [IMG]http://cdn.******************/instances/400x/18277984.jpg[/IMG]
      Reppin the GAP- 93 Corrado SLC, 01.5 Passat Wagon
      Quote Originally Posted by TheDarkEnergist
      Psssh. I suck dick for the glory. I buy my cocaine.
