VWVortex.com - Johnson 50 question
    Results 1 to 8 of 8
    Thread: Johnson 50 question
    1. Banned StormChaser's Avatar
      Jan 3rd, 2000
      Annapolis, MD
      2006 Volvo V50, 1993 RX-7 R1, 1980 Hatteras 53MY, 2002 Grady White Release 283, 1958 Mohawk 14
      04-10-2012 09:02 AM #1
      Johnson 50hp engines, like the one on the Mohawk...should they pump water our the exhaust ports that are right below the power-head all the time? Or is there a thermostat that needs to open? Reason I'm asking is that we ran her with muffs on the trailer and it wasn't pumping water. The broker wasn't sure if it just needed to warm up, if there was a problem with the muffs, or whether it might need an impeller. Also, any idea how hard it is to replace the impellor and reseal the lower unit?
    2. Member mode12's Avatar
      Apr 26th, 2000
      Stillwater, MN
      2015 GTI & 2014 Silverado
      04-14-2012 02:21 PM #2
      I'm a merc guy, but I would bet johnnyrudes have a telltale (p stream).
      If you're not 100% on the timeframe of last impeller change...change it before running it again.
      It's a simple process and I bet there are youtube vids for that engine. Plus you get to r&r the lower unit lube.
      Sent from my T-Mobile G2 using Tapatalk 2
    3. Member tip's Avatar
      Aug 8th, 2008
      South Puget Sound
      Junk
      04-22-2012 01:27 PM #3
      Probably needs an impeller. mode12 is right, they have a pisser that should be spitting out a healthy stream of water anytime they are in water or being flushed.
      Dropping the lower unit is pretty easy, as long as everything isn't corroded. Good luck!
    4. Member drivrswntd's Avatar
      Dec 8th, 1999
      RI
      2015 GTI SE DSG
      04-27-2012 11:38 PM #4
      Definitely replace the impeller. That should be shooting water any time it is running. Not too difficult as long as the bolts aren't corroded.If they are use a little heat on them and they will come right out.
      ## Jay ##
      07 Yukon Denali XL
      2015 Gti SE DSG 4 Door
    5. Member mode12's Avatar
      Apr 26th, 2000
      Stillwater, MN
      06-12-2012 09:40 AM #5
      Did this motor melt down?
      You have that other post looking for replacements...uh oh.
    6. Banned StormChaser's Avatar
      Jan 3rd, 2000
      Annapolis, MD
      06-12-2012 09:55 AM #6
      Nope, not melted. Actually running OK, just starting shopping knowing it's old.
    7. Member drivrswntd's Avatar
      Dec 8th, 1999
      RI
      2015 GTI SE DSG
      06-21-2012 01:39 PM #7
      what are you looking to replace it with? I have a couple motors I'm selling.
      ## Jay ##
      07 Yukon Denali XL
    8. Banned StormChaser's Avatar
      Jan 3rd, 2000
      Annapolis, MD
      06-21-2012 01:49 PM #8
      And I confirm that they do NOT have "pee holes."
      As for what I'm looking to replace it with, see the thread I started on that (no replies yet):
      http://forums.vwvortex.com/showthrea...-used-outboard
