Are you trying to install a VW OEM replacement refill blade or did you get aftermarket blade and wiper assembly such as rain x, michelin, etc?
Hello Everyone,
What is the secret to removing the "old" windshield wiper blade on the rear window of a 2009 VW Routan? The arm will not come out far enough to get leverage on popping out the blade. Any advice is appreciated.
Believe it or not, I called my Dallas VW Dealership and they were not able to assist over the phone from the Service Department
Thanks,
You have the "plastic" looking wiper arm correct? Not the metal standard arm type. I got this from the chryslerminivan.net
You could always swing by your local Dodge dealer and ask them to show you. I'm sure it only takes a second.to replace rear wiper blade, you need to lift wiper arm then push the wiper blade towards the body of the van. The wiper blade is just clipped in to the arm instead of being hooked in like the old style of blades
1958 VW Ragtop Bug
2005 VW Passat Wagon
2010 VW Routan SEL
Be sure to check out the Original Routan Dead Pedal Click Here
