Results 1 to 20 of 20
Thread: auto transmission problems
  1. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    92 monty green gti, 91 audi 80 quattro
    04-10-2012 06:16 PM #1
    Okay so my sister has a 2000 passat wagon with a 1.8t and an auto transmission. The problems started when it would have trouble catching gears and getting off the line. I would be sitting at a light with it and the idle would bob between 800 and 1000 while sitting there in drive. If I put it in nuetral the issue would stop. Wasn't sure why it was doing it so she kept driving it. Then I noticed that you would hit the gas while driving and it would rev like it was in nuetral. It would also lurch forward off the line on occasion. Obviously something was wrong here.
    This all leads up to now. When you put the car in reverse it goes no where and when put in drive you need to seriously rev it before it will go anywhere. So what do you guys think? Is the tranny shot? I know nothing about automatic transmissions so I'm a bit confused at the moment. The car has about 120k on it. Thanks for any help.
    -Corey
    Quote Originally Posted by Moonequipt13 View Post
    The better question would have been is there anyone running a 15x8 with a properly sized tire
  2. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    04-10-2012 07:08 PM #2
    Check the transmission fluid level. Not a trivial task; look at the instructions HERE. If the fluid is OK, replace the transmission. Simple.
  3. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    04-10-2012 07:21 PM #3
    Thank you I had been thinking tranny fluid and had been telling her to give me the money to change it. Let's just hope its not to late. Ill give it a look next time I have a chance.
    -Corey
  4. Semi-n00b
    Aug 23rd, 2011
    Cambridge, Ma
    2000 B5 V6 Wagon
    04-12-2012 02:38 PM #4
    I recently had shifting problems (different from yours) that were solved by changing the fluid. It's probably a long shot, but it's a lot cheaper than replacing the transmission.
  5. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-08-2012 11:02 PM #5
    Welp changed the atf fluid and still nothing. I put in almost 6 quarts of redline d4 atf after draining the old and putting in a new filter. I only got out about 3 quarts out though so I think that's saying something.
    When I put the car in reverse it will only rev until about 3k. It struggles to get there and does not move the car. I put the pedal all the way down and it will still only get to about 3k. It seems to drive forward fine though but will not go anywere in reverse. So is the transmission dead?
    -Corey
  6. Member mk2dubdriver's Avatar
    Oct 15th, 2003
    Wilkes Barre Pa
    1997 Audi A4 1.8T Quattro
    05-09-2012 10:36 AM #6
    Is the check engine light on? A friend of mine had a similar problem. I plugged in my VCDS and ran a TB adapt and it works fine now.
  7. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-09-2012 10:54 AM #7
    Yea the check engine light is on. I don't have a cable though.
    -Corey
  8. Member mk2dubdriver's Avatar
    Oct 15th, 2003
    Wilkes Barre Pa
    05-09-2012 11:07 AM #8
    If you have any obd2 scanner you can see what the code is. If the code is p1545. Then it needs the TB adapted.
  9. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-09-2012 11:11 AM #9
    No scanner either. Ill see if I can find one local.
    -Corey
  10. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    2001.5 VW Passat V6 FWD
    05-09-2012 03:27 PM #10
    Quote Originally Posted by Rcmafia View Post
    most local autoparts stores, like AutoZone will scan your car for free and give you a printout of the codes. use that info to start tracking where the issues might be.
    God bless the homicidal maniacs... they make life worthwhile. - George Carlin
  11. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    05-09-2012 03:30 PM #11
    with our cars, ignoring a CEL is the most common way to make any problem become a major issue. leaving a failing part alone will most likely begin to cause others to fail and compound things.
  12. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-09-2012 03:57 PM #12
    Ill try and see if I can rent a scanner from them.
    The car is a 1.8t and has an oil sludge problem so it will get a cel from that. Its my sisters car so its hard to know what's going wrong it when your not the one driving it. All she would tell me is that the cel came on and then would shut off after.
    -Corey
  13. Member scotts13's Avatar
    Feb 15th, 2007
    Lehigh County, Pa.
    2004 GLS 1.8T
    05-09-2012 06:36 PM #13
    Actually, it won't give you a CEL in the usual sense. If your oil pressure is low, you'll get a STOP message, and oil can icon, and a buzzer - maybe the CEL is on, too, I don't know. But for sludge (and therefore low oil pressure) you'll never get just a CEL. That's far too urgent for a single light.
  14. Member mk2dubdriver's Avatar
    Oct 15th, 2003
    Wilkes Barre Pa
    05-09-2012 06:48 PM #14
    Dude that car has a bigger problems then the trans not working right. You need to get a oil flush, maybe replace the oil pump and use full synthetic oil. A working trans will be worthless if you continue to starve the engine of oil. Trust me I lost the engine in my A4 when it blew an oil cooler gasket. Even only running with no oil for a few seconds will kill a 1.8t.
  15. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-09-2012 10:38 PM #15
    It has full synthetic 5w-40, an oem filter and the oil level got checked very regularly because of the problem. That doesn't stop it from getting an oil pressure warning light and cel though. Most of the time it just says emissions workshop will come intermediately. Not having access to a scanner or vag-com makes it a bit harder to trouble shoot a newer car.
    My sister actually wants to get rid of the car as she is very sick of putting money into it She didn't exactly realize that cars require maintenence and thought she could drive it without doing anything to it.
    -Corey
  16. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    05-10-2012 01:09 PM #16
    CEL and emissions workshop doesn't sound sludge related to me. How exactly do you know it has a sludge problem? I'd suggest running 1/2 can of seafoam into the crankcase for about 100 miles, then do an oil change, but drop the oil pan and check for any signs of sludge or clogs in your screen. If you see any hard deposits, then it could be a sign of a sludge problem that went uncared for. Overtime, the sludge can cook or coke and become hard deposits or granuals (commonly called "turbo turds"). If it's gotten to this point, then a serious cleaning along with a new oil pump and screen are in order.
    Emissions could be pcv, purge valve, or catalytic converter related. You really need to get it scanned to best diagnose what's causing the CEL and Emissions warnings.
    It sounds like you may have several issues going on right now, but since you're not getting oil pressure warnings... sludge might not even be a part of the equation.
    If you can post back with codes once you get a scan done, we can probably give you much better and more detailed help as to the issues at hand and how to correct them.
  17. Member koidragon1980's Avatar
    Jul 8th, 2011
    Astoria, NY
    05-10-2012 01:12 PM #17
    At the very least, you need to figure out what's wrong. Getting rid of the car without giving the buyer details about what work is needed is not a cool move.
  18. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-10-2012 01:26 PM #18
    As I said in my post directly above yours, it does have an oil pressure warning light along with the emissions warning. That's how I know there's an oil sludge problem. To be honest this car at the moment is a nightmare. Its got a bad oil leak along with the other problems and I'm pretty sure its from the turbo side.
    I may give in and finally buy vag-com so I have it. I really would rather spend my money on parts for my gti, but having a scanner would be a good investment. I have no problem figuring out the codes and finding what they do. Automatic transmissions are just a mystery though as this is the first car I worked on with one.
    -Corey
  19. Member Rcmafia's Avatar
    Nov 26th, 2009
    Burlington, CT
    05-10-2012 01:40 PM #19
    Quote Originally Posted by koidragon1980 View Post
    Sounds like what happened when she bought the car. Its had most of the problems since she got it. Everything seemed fine when she took it for a drive, but within a week or 2 it started with the problems. Then she didn't want to spend the money on fixing them and the problems got neglected making it a lot worse.
    I wouldn't sell somebody a car without telling them what's wrong with it nor did I say anywere that I intended on doing that.
    -Corey
  20. Member mk2dubdriver's Avatar
    Oct 15th, 2003
    Wilkes Barre Pa
    05-11-2012 06:58 AM #20
    That's what happened to me. My passat was great for the 40 mile drive home. The next day the car was smoking idling bad abs and the gear select lights were lit up. I have been trying to fix the problems for the last 4 months.
