Results 1 to 8 of 8
Thread: Steering noise
  1. Member BMP2Ov's Avatar
    Jan 23rd, 2007
    CT
    Previous: 95 GTi, 04 GLi. Current: 09 Passat
    04-10-2012 07:21 PM #1
    Hey guys, just picked up and 09 passat 2.0t. Noticed the other day when I turn the steering wheel that there is a noise coming from the steering column...maybe. I turn the wheel and the noise is like a "buzzing" sound. That's probably the best that I can explain it. Not sure if this is normal, maybe like an electric motor or something. Any help is appreciated. I did some searching but only found stuff on clicking or thumping noises, which is not the noise I'm hearing. Thanks!
    Oct 14th, 2008
    '07 Passat 3.6 4mo wagon; '05 GLS 4mo wagon
    04-10-2012 08:22 PM #2
    Power steering pump? Could be as simple as a fluid issue.
    Feb 17th, 2008
    brooklyn ny 11230
    07 passat 2.0t wagon,09 vw cc vr6 4motion
    04-10-2012 08:26 PM #3
    Quote Originally Posted by Incrementalg View Post
    cant be , its electric
  4. Member BMP2Ov's Avatar
    Jan 23rd, 2007
    CT
    04-10-2012 08:31 PM #4
    So the steering is fully electric?
    Feb 17th, 2008
    brooklyn ny 11230
    04-10-2012 08:37 PM #5
    it is fully electric in the 07. not aware of any change's in the 09 when you start car a lil red & yellow steering icon should light up in your mfd, if steering problem occurs they will light up.
  6. Member najel's Avatar
    Apr 10th, 2008
    Mankato MN & Bielefeld Germany
    03 Jetta GL & 06 Passat 2.0t
    04-10-2012 09:28 PM #6
    I hear that noise too sometimes. I think it might just be the electric motor that drives the power steering. It sounds like an electric motor to me anyway. Hope it's nothing else
    Owning a VW is like having a hot girlfriend that's mentally unstable
  7. Member BMP2Ov's Avatar
    Jan 23rd, 2007
    CT
    04-14-2012 06:42 PM #7
    Thanks for all your help guys!
    Mar 10th, 2009
    2006 Passat 2.0t 6mt
    04-15-2012 06:06 PM #8
    If its a swishing/buzzing noise then its likely a noise clock spring.
