Results 1 to 3 of 3
Thread: 1997 Jetta GLX Vr6 Rebuilt motor and Tranny
    Jul 20th, 2011
    Boise, ID
    1997 Jetta GlX Vr6, 1989 JEEP Cherokee Laredo, 1993 Ford Escort
    04-11-2012 01:55 AM #1
    I am forced to sell this car because I am leaving for the military. This car is my baby and I have put over 5k into it and it was worth every penny. It has a brand New rebuilt motor and a 5 speed manual transmission with only 130k miles on it.
    Only 3500 miles on the motor. I have replaced almost everyhting in the car and reupholstered the whole interior exept seats. A couple cosmetic flaws and drivers seat is torn but its hardly noticeable also a 10 speaker sound system that is already wired for subs.
    This car is fast and has new tires(front) it will run a 15 second 1/4 mile at firebird.
    Brand new carpet! Leather Heated seats Power locks. Tinted Windows CLEAN TITLE.
    This Car is reliable, it has taken me to san diego and portland without a single Hiccup. With this car, ou are buying reliability and a car the with last you another 200k miles.
    It also has a sun roof. Needs a new cable before it can be used again, the motor is fine though. It only flips up, doesnt slide back.
    The Bad:
    The worst part about this car is the body, one dent under passenger side door and a rust spot on the rear wheel well.
    If you can live with that, the car is amazing performance wise and reliabile.
    Also passenger side door does not lock. Havent looked in to it.
    An occasional tire rub when braking and turning left due to the larger 17 inch Monte Carlo rims but wheel spacers will take care of that.
    Classic vw problem, the speedo tends to quit on occasion.
    NEW PARTS:
    -Motor
    -Motor mounts
    -Cv axles
    -Tires (front)
    -Fan control module
    -Coolant reservoir
    -Headlights
    -BRakes (Discs and Pads)
    -Sway bar end links
    -New coolant hoses
    -Thermostat
    -Clutch and flywheel
    -Rear springs and shocks
    Pretty much anything else you can think of.
    Has 4 wheel disc brakes
    Upgrades:
    Stage 1 BFI Motor mounts
    Stage 1 clutch and Flywheel
    Chipped
    8mm wheel spacers (Rear)
    Call/text thomas at (208)994-9122
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    Jul 20th, 2011
    Boise, ID
    04-11-2012 01:58 AM #2
    Going for $2,950 obo
    Jul 20th, 2011
    Boise, ID
    04-12-2012 12:51 AM #3
    Need It gone soon before I leave
