Results 1 to 10 of 10
Thread: Airbag error
  1. Junior Member
    Jan 10th, 2011
    2006 VW Jetta, 2012 VW Jetta Sportwagen TDI
    04-11-2012 10:40 AM #1
    Hi all,
    Relatively new car, less than 6 months old, less than 2k miles. The airbag warning light came on, and the MFD display reads "Airbag error".
    Before I take it in, I'd like to know if anyone else has had an issue so early in their JSW life, and what was the cause? Just trying to ramp my expectations.
    Thanks.
    Power is nothing without control - Pirelli
  2. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    04-12-2012 04:16 PM #2
    Haven't heard anything yet, but I know harness connectors have caused issues in other VWs...
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
  3. Semi-n00b
    May 6th, 2011
    2011 Golf Wagon 2.5 (prev. 2000 Golf 2.0; 1989 Golf)
    04-16-2012 01:13 PM #3
    My airbag light was on from the beginning, likely before I drove it off the lot, though I'm not certain. Regardless, it took four freakin' trips to the dealership to get it fixed.
    - trip 1 - yup, that light sure is on alright; diagnostics says it's the driver-side airbag; don't have a replacement; reset the error
    - trip 2 - yup, that light is on again; took it apart and checked connections, etc. (but didn't have the replacement bag like they said they would, bastages); reset the error
    - trip 3 - yup, light's back on; replaced the bag
    - trip 4 - yup, not fixed; replaced the associated computer chip; now it's fixed
    Hopefully my experience might save you some time.
  4. Junior Member
    Jan 10th, 2011
    04-16-2012 03:17 PM #4
    Hmm... Good to know, thanks for the heads up. I'll post an update once I get my car back from the dealership. Hopefully, it's not a big deal...
    May 30th, 2010
    Houston, TX
    10 JSW TDI, 12 R
    04-16-2012 07:39 PM #5
    I've set the light off a few times while doing the stereo. If you turn the ignition hot with the little passenger airbag light disconnected, it's trip the warning and keep it until you clear it with VCDS or take it to the dealer.
  6. 04-18-2012 09:32 AM #6
    2009 MKV JSW 2.5L
    Same for me. When I removed my interior to soundpoof and run power and audio cable, I went through all of the same steps I've used since I worked at an audio shop during college in the early 90's:
    Disconnect battery, wait about 15 minutes to allow the airbag capacitors to discharge, remove the seats, remove carpet, do the work, put everything back in, reconnect battery.
    Aside from my amazement on how many wires cars have in them these days, and how damn complicated the interior panels are in VWs, everything went back together fine.
    Still got an airbag error code. Dealership I went to was clueless about it.
    I ended up buying one of these wannabe vagcoms from ECS and cleared the fault that way.
    http://www.ecstuning.com/Volkswagen-..._Tools/ES9950/
  7. Junior Member
    Jan 10th, 2011
    04-19-2012 01:44 PM #7
    Still haven't been able to make it out to the dealership... I haven't messed with the audio unit, so I don't think that's the culprit. Hopefully it's not a wiring harness issue...
  8. Junior Member
    Jan 10th, 2011
    04-27-2012 01:28 PM #8
    Turns out, it was just a loose sensor that was improperly fitted at the factory. Sigh. Glad it wasn't anything more serious.
  9. n00b
    Apr 28th, 2012
    va beach
    '09 rabbit 2dr
    04-28-2012 04:28 PM #9
    thanks for the link! my light went off after replacing my stereo and the dealership wants $120 to reset the light...wtf at least i'll have this on hand now
  10. 05-01-2012 09:11 AM #10
    No prob.
    You might need to do a little surgery to the supplied cable, though.
    The female end that is supposed to plug into the car didn't fit correctly on my '09 JSW 2.5L.
    Link to illustrate:
    http://forums.vwvortex.com/showthrea...V-Checker-Help
