2 piece? Where are you located
#1
19x8 Dpe R20 2piece wheels with brushed face and 2" lips. These wheels are discontinued.
-19x8.0 all around with a 32ET
5x112mm
-255/30/20 Toyo T1R (1 tire might have an air bubble on the inside)
-2 rims have minor nicks on the lips that can be fixed easily.
-for my 14" wilwood BBK I had to use a 8mm spacer...if not then they clear OEM brakes well from 1.8-4.2 braking systems
wheel&tire combo 1400
wheels alone 1000 firm
#2
07 B6 Passat 2.0 turbo - http://unitronic.ca Unitronic Stage 2 HPFP - High flow cat downpipe 3" - ABD Racingwerks intake Stage 2 - HPFPUpgrade.com Stage 1 HPFP - 142 Bar fuel Pressure relief valve - 5 zigen Oil catch tank - Autotech 3" catback - Adams Rotors - H&R Springs teamed with Bilstein Sports.
http://i51.tinypic.com/153w51g.png
#3
