Results 1 to 15 of 15
Thread: Which crank pulley is the big crank pulley, and how much boost with a 68mm?
  1. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    '86 Cabriolet G60, '82 280ZX Turbo, '06 325i Problem Child
    04-11-2012 12:45 PM #1
    I hooked up my boost gauge today in my mk1 G60, and I got 15-16 psi. I measured my charger pulley, it's a 68mm.
    My question is: What are the diameters of the large and small crank pulleys? I'm trying to get a handle on how much boost I should be making.
    The way I understand it, if I have the large crank pulley, I need to start looking at some apex strips, and if I have the smaller crank pulley, I'm all good to go.
    Thanks for the help guys.
    It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark... and we're wearing sunglasses.
    -Hit it.
    RooflessVW
  2. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    Orig Owner 90 G60 & 02 Allroad 6Sp Man w/ 3rd Row Seat
    04-11-2012 03:36 PM #2
    There's three pages on this link. Don't reference the Lysholm pulleys. After clicking on each pulley pic (link) it will take you to the page that shows the approximate boost capabilities. Send your G Ladder out for a service before you start to boost or ... well you know
    fixed the blue link ... sorry
    ¡¡ opɐɹɹoɔ ǝɥʇ!!!ƃuıʇɔǝdsǝɹ !!!
    !! odarroɔ ǝht gnitɔepser !!
  3. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    04-11-2012 04:25 PM #3
    ... what link? I'm feeling really dumb right now.
    Edit: makes sense now that the link is fixed, haha.
    It would seem that my numbers are correct for my pulley then. I plan on cracking it open here soon for a rebuild, it has about 40,000tkms since its last.
    -Hit it.
    RooflessVW
  4. Member G60 Carat's Avatar
    May 14th, 2004
    Regina, SK
    1986 Jetta Carat G60, 2001 Allroad 2.7T, 1982 320i
    04-12-2012 04:45 PM #4
    It was said that Passat Automatics had bigger crank pulleys (I've also read that all G60 automatics had bigger crank pulley's)
    Personally I'm not sure if there ever was a bigger crank pulley. My engine originally came from a Passat Syncro Auto, and it has a normal sized pulley on it.
    Gauge pressure is hard to test off of for a few reasons, but if you made 15-16psi @ 6000rpm with a 68mm your not leaving too much on the table. Aftermarket cams and/or head porting will lower boost on a G60, boost will also decrease as your elevation goes up, and same story with ambient temps. The higher they go the less boost you will see.
    Also gauge inaccuracy is sometimes a factor. If you're hitting that number for PSI there isn't too much wrong with your charger that's for sure. With that number you would be looking for minor boost leaks, like at the collector box. etc.
    With a 68mm on mine I see about 16psi @ 6000rpm, 17psi if it's really cool out, can be as low as 14psi if it's 30c + outside. I'm at about 2500ft for elevation.
    | Rust | Zip-Ties | JB Weld | Bad Idle | Scrapes Ground | Rubs when Turning | Busted Ass Door handles |
  5. Member efritsch's Avatar
    Aug 21st, 2002
    Kitchener
    1992 Passat Syncro Wagon, 1987 Fox Wagon (Project)
    04-12-2012 08:30 PM #5
    Quote Originally Posted by G60 Carat View Post
    My understanding was that the Passat Syncro's never came in an Auto-Tragic. They were manual transmission only.
    Quote Originally Posted by 90quattrocoupe
    I am old enough that I only have to be nice when I want to.
  6. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    04-13-2012 04:43 AM #6
    Thanks for all your input guys!
    -Hit it.
    RooflessVW
  7. Forum Sponsor JBETZ's Avatar
    Feb 17th, 2000
    Bend, Oregon
    02 GTI 337, 2010 H3T
    04-13-2012 12:01 PM #7
    Quote Originally Posted by s2kvondeutschland View Post
    I've never seen this mystery larger crank pulley...
    Boost... the displacement replacement!
    BBM, LLC 541.388.1202
    www.BahnBrenner.com
    we share the passion!
  8. Member s2kvondeutschland's Avatar
    Mar 19th, 2011
    Fayetteville, NC
    04-13-2012 02:50 PM #8
    Quote Originally Posted by JBETZ View Post
    That's why I'm curious. It's all over the internet about '91+ having a larger crank pulley that is good for another 2-3 psi. I measured mine but can't remember the damn number. I'll get on my hands and knees and hit it up again tomorrow morning. We'll see if it compares to what you guys have; I'm sure there is a possibility for some variation.
    It's not like I'm not going to rebuild the charger... I've got the stuff anyway, and it's due by miles even though it's got no oil leaks and it still makes good boost. I just wanted to see how far off my numbers were; I guess not very far, if at all.
    -Hit it.
    RooflessVW
  9. Member G60 Carat's Avatar
    May 14th, 2004
    Regina, SK
    04-13-2012 04:38 PM #9
    Quote Originally Posted by efritsch View Post
    Hmm Maybe it was a Manual, but it was definitely from a Syncro. Somebody else took the drive train.
  10. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    04-14-2012 02:13 AM #10
    Yes, that's correct. Crank pulley was smaller on late 91 G60. It did spin things just a fraction faster. This used to be significant. Now with so many aftermarket G Ladder pulleys available,it's moot. No need to overspeed the p/s, alt & a/c anymore.
  11. 04-14-2012 11:56 AM #11
    ????? Crank pulley needs to be larger to spin the G-ladder faster I think. Smaller makes it spin slower.
  12. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    04-14-2012 12:39 PM #12
    Years ago i did this larger Crank pully numbers for my Lysholm setup.
    OEM G60 crank pully size is 5 3/4" I used a TDI OEM crank pully which is 6". this gives a larger
    pully ratio and spins the charger to a higher RPM giving more boost.
    5 3/4" = 146mm
    6" = 152
    152mm/68mm= 2.2:1
    146mm/68mm = 2.1:1
    When i was S/C setup I used 6" and a 50mm pully on lysholm for 3.0:1
    500HP 1990 Cowrado
  13. Member G60 Carat's Avatar
    May 14th, 2004
    Regina, SK
    04-14-2012 01:01 PM #13
    I think the stock G60 crank pulley is 133.6mm
    But anyways running a 6" TDI crank pulley with a 68mm, would be the same as running with a 60mm charger pulley. Which is like 20psi at 6000rpm, charger life is definitely in question at that speed.
  14. Member petethepug's Avatar
    May 25th, 2001
    So Cal
    04-16-2012 08:31 PM #14
    Quote Originally Posted by DigiMatrix View Post
    What he says Thnx
  15. Member mattrip's Avatar
    Sep 5th, 2005
    USA
    92' Corrado
    04-16-2012 10:50 PM #15
    To try and confirm the larger pulley size on the G60 Automatic I will get a measurement of my crank pulley this week. It's in a box in the shed pending engine rebuild...
    92' G60 Corrado originally an automatic. I did the 5 speed swap 10 years ago retaining the original pulley. I was told back then the autos came with a larger pulley than the manual cars.
    "A sudden provocation does not make me an ill-tempered man. It shows what an ill-tempered man I am."
