Results 1 to 3 of 3
Thread: Fox wagon rear springs
  1. 04-11-2012 06:04 PM #1
    Does anyone know of a direct bolt in substitute rear spring for a 88 Fox wagon that will increase the spring rate by 30-50 % ???
    The wagon is usded occasionally to haul some stuff, and the rear springs are just not up to the task !!
    I thought there might be a heavier spring from a heavier VW, like a Jetta Wagon maybe, that might work?
    No I don't want coil overs, at least at this time.
    Altho it might be the ony solution.
    All input appreciated
    BC
    SCCA 1.8L H Prod Scirocco,1988 VW Fox wagon, 2005 GTI 1.8T and others
    Dec 16th, 2005
    Williamsburg, VA
    1993 Volkswagen Fox 4-door, 2012 Ford Focus SE Sport 5MT
    04-11-2012 06:25 PM #2
    Stock Fox springs are really soft. However, like any coil spring, cutting it will up the rates a bit -- but probably not as much as you desire. FWIW, one of my Foxes had 1.5 coils cut off all around. Lowered it just a bit and firmed things up noticeably.
    Another option might be some aftermarket 35mm lowering springs for a MK2, which will up the rate but not lower the lighter/different Fox much, if at all.
    Aug 17th, 2011
    Brooklyn, NY
    '88 Fox GL Wagon, '04 Jetta GLS Wagon TDi, '89 Fox Coupe (sold)
    04-11-2012 06:47 PM #3
    and I just sold my extra set of 35mm Vogtland springs today...
    How a VW Fox Wagon sucked me back in...a build thread
