VWVortex.com - Some assistance needed....
    Results 1 to 13 of 13
    Thread: Some assistance needed....
    1. Member Gryphon001's Avatar
      Apr 25th, 2008
      Mississauga
      2008 Audi A3 Sportback
      04-11-2012 09:06 PM #1
      Need a but of help diagnosing a problem.
      Last week I installed a Neuspeed intake on the car. Almost immediately it felt like it lost a lot of power. When scanned, an intermittent MAF fault code showed up. Cleared the code and the car ran fine... For about 10km, than back to 'limp' mode. Rechecked the intake for leaks... Nothing. Cleaned the MAF... Still didn't help. Finally replaced the MAF with a new one... Car started off running fine but went limp after another 10km. No faults found with vag com...
      Pulled the DV and did a visual check for any damage and it appears to be ok. The DV was changed for the updated F revision last August.
      Each time the car goes into limp mode, when I do a fault code erase using the APR software tge car runs five for a bit than goes limp again... Every time I scan the car when in limp mode there are NO faults found, but when I clear faults anyway, the car runs fine for a while.
      I'm all out of ideas at this point... If it was the DV again why would it work fine for a while and than put the car in limp mode? When I run the car in stock mode the car is very sluggish... When using the 93 octane program, the car is only a bit slower than normal stock when it goes into limp mode...
    2. Member mattA3's Avatar
      Feb 24th, 2010
      South Florida
      2007 A3 Premium DSG
      04-11-2012 09:58 PM #2
      APR Software? Do you have access to VAGCOM to run some logs?
      Have you tried disconnecting the battery? Reconnect and let the car idle for a few minites.
      Also have you posted this question in the 2.0T FSI forum?
      2007 A3 Premium, DSG, Lava Grey, Votex body kit, BSH PCV, Comp Catch Can, APR Stg1.
    3. Member Gryphon001's Avatar
      Apr 25th, 2008
      Mississauga
      04-11-2012 11:57 PM #3
      Quote Originally Posted by mattA3 View Post
      DOH...!!!
      Never occurred to me to post it there. I have had some ridiculous issues with APR software before, but they were never anything to do with engine performance. Only the security lock out activating itself while I'm driving on the highway... Unless this is some retarded way the Valet mode activates randomly...
      I did make an observation though. The car goes into limp mode after cruising on the highway... Since the new MAF went in twice I drove to take care of an errand, took the highway there, limp mode, took the regular roads back... No limp mode.
      I will try the whole battery thing tomorrow, see if that helps solve the issue.
      This is my first new car and I seem to be cursed with these weird, one in a million issues...
    4. Member
      Dec 29th, 2010
      Lynnfield, MA
      03 VW Golf(sold), 05 Jetta(sold), 09 Audi A3, 12 GTI
      04-12-2012 08:39 AM #4
      Quote Originally Posted by Gryphon001 View Post
      DOH...!!!
      I had something like this when I installed my CAI. It was a while ago and I can't remember exactly what I did to fix it. I cleaned the MAF, reset the connectors, I think at the end I cleaned throttle body and performed addaptation... again it was over an year ago. GL!
    5. 04-12-2012 01:33 PM #5
      This may be a stupid sugestion but I had my MAF out last weekend and it looks like it can be installed backwards. Are you shure it is pointing the right direction.
      If thats not the problem I would start by logging 003-2 Intake Air Mass.
    6. Member Gryphon001's Avatar
      Apr 25th, 2008
      Mississauga
      04-12-2012 02:20 PM #6
      Already checked the MAF ... The intake is facing the direction the air is coming from.
    7. Member ApexAudi's Avatar
      Nov 23rd, 2011
      Vaughan Ontario
      2016 Golf R Lapiz Blue
      04-12-2012 02:55 PM #7
      The F has been replaced by an N breather. There should still be an open recall on your vehicle. If you PM me your VIN I can find out for you.
      That would be the first place I would check.
      [URL="http://forums.vwvortex.com/showthread.php?5910882-Goodbye-fellow-A3-owners!"] 2006 A3 Brilliant Red 2.0T DSG Tribute
      Golf R MK7 Thread coming soon
    8. Member Gryphon001's Avatar
      Apr 25th, 2008
      Mississauga
      04-14-2012 08:04 PM #8
      Well... Got the problem sorted out...
      Here is the progression of events...
      After the issue started, check the MAF, clean the MAF, replaced the MAF... Did throttle body adaptation... Checked all the fittings for leaks... Checked the DV... Appeared fine. 3 days later I went to replace the DV and this is what came out.
      Replaced the DV... Car still goes into limp mode... Finally put the stock intake back on and the car seems to be back to normal again. Will need to drive it a bit more to be truly sure though.
      Think I got the wrong Neuspeed, the MAF was in the wrong place and was throwing off the readings causing the car to overboost and blew the DV. The MAF is about 3" right of where it was on stock.
      Officially biggest PITA I've ever had with this car... And there were several.
    9. Member ApexAudi's Avatar
      Nov 23rd, 2011
      Vaughan Ontario
      04-16-2012 09:37 PM #9
      Damn !!! I hope Neuspeed is going to cover parts and labour on that! Hope everything gets resolved soon.
    10. Member Gryphon001's Avatar
      Apr 25th, 2008
      Mississauga
      04-16-2012 09:44 PM #10
      Neuspeed gave me a sales pitch on their intakes and says that he never heard of any issues like it an it has to be the APR software since its inferior to the Neuspeed software...
      In other words I'm stuck with a useless intake...
    11. Member ApexAudi's Avatar
      Nov 23rd, 2011
      Vaughan Ontario
      04-16-2012 10:00 PM #11
      ****in pricks! Customer service is a myth. I bet there's at least a dozen people on this forum who have both APR software and neuspeed intake with no problems... If I didn't buy my Scirocco, I'd totally take the intake off your hands and try to make her work, but the Scirocco has all my funding now... Still cheaper then the GF!
    12. Member Gryphon001's Avatar
      Apr 25th, 2008
      Mississauga
      04-16-2012 10:35 PM #12
      So which one are you bringing to the meet?
    13. Member ApexAudi's Avatar
      Nov 23rd, 2011
      Vaughan Ontario
      04-16-2012 10:43 PM #13
      Lmao A3... the Scirocco isn't even registered. It's getting stripped out, re-built, and raced. Hopefully by the end of the summer too!
      Unfortunately I'm back on night shift for the next 8 weeks. Therefore, no Thursday night meets for 8 weeks
      Either way I'm just happy our dealership is busy enough to have a night shift. Better then being bored off my ass...
