Welcome to old-school VW electrical - there is no 'accessory' key position. We have but three:
- Off
- Run
- Start
Now, from the factory, the radio fuse (which also powers the dome lights, and cigarette lighter) is always hot. So, unless you're testing the wrong fuse, not sure how yours is switched (unless it was, ah, molested?) If someone modded that circuit to switch with the key, then the dome lights wouldn't work unless the car was on...
How did the factory radios work? Well, they were a lot more mechanical, back in the day. The radio was turned on by, well, turning it on.![]()
Most common way to get switched power for a radio is to simply grab it from the defroster switch.
IIRC, the black/yellow wire is the feed from the X-contact relay; this wire is live only in Run.
(me, I installed a toggle switch for the radio, looped from the radio power wire. I like being able to have the radio on with the car off.)
