Results 1 to 15 of 15
Thread: Mk4 jetta vr6 automatic trans fluid?
  1. Junior Member tabletop844's Avatar
    Jun 6th, 2009
    OC MARYLAND
    2002 JETTA WAGEN VR6 2003 GETTA 1.8T
    04-12-2012 10:21 AM #1
    What brand should i get?
    All we do is win win win no matter what!
  2. 04-12-2012 10:03 PM #2
    Maxlife, done. Nothing wrong w/ Castrol HiMiles either.
  3. Member rickjaguar's Avatar
    Apr 23rd, 2009
    Van. Island, BC
    07 GTi.. fun times
    04-15-2012 07:26 PM #3
    OEM
    Sent from my 1st generation Motorola brick using Tapatalk
  4. 04-17-2012 01:30 AM #4
    Weak Sauce
    Nov 10th, 2010
    mid hudson valley
    02 jetta wagon 1.8t, 03 passat 1.8,06 jetta 20t
    04-17-2012 08:26 PM #5
    Quote Originally Posted by Apexxx View Post
    Weak Sauce
    guess you're still laboring under the illusion that you know more than the manufactures.
  6. 04-17-2012 10:07 PM #6
    No, actually the fluids have improved since the OE issued the relevant specs 20 years ago.
    Too bad your mental capacity hasn't improved similarly.
    http://www.valvoline.com/admin/p37.png
    MaxLife® DEX/MERC ATF
    The first ATF for 75,000 miles & beyond
    High-performance seal conditioners maintain and preserve the elasticity of seals to help prevent leaks
    Long-life friction modifiers and premium base oils help improve smooth shifting, eliminate slippage and shudder, prevent clutch wear and improve drivability longer than conventional fluids
    Advanced anti-wear agents provide wear protection for smoother shifts under all driving conditions
    Enhanced cleaning additives help reduce varnish formation and keep the transmission running properly longer
    Engineered with a unique blend of viscosity modifiers and base oils to provide better oil flow at low temperatures and greater film protection at higher temperatures
    http://www.castrol.com/castrol/secti...tentId=7028224
    Recommended for use in vehicles that require:
    Honda, Acura — ATF–Z1 (except in CVTs)
    Toyota, Lexus — Type T, T–III, T–IV
    Nissan, Infiniti — Matic–D, Matic–J
    BMW — LA2634, LT71141
    Mitsubishi — Diamond SP–II, SP–III
    Hyundai — SP–II, SP–III
    Volvo
    BMW LT71141 is the synthetic Esso spec for Audis too, the $15 litre stuff.
    Nice post dummy.
    Nov 10th, 2010
    mid hudson valley
    04-18-2012 07:11 AM #7
    the 4 speed requires g 052 162 a2 spec fluid
    the 5 speed requires g 052 990 a2 spec fluid and is specific for the 09a trans and differential.
  8. 04-18-2012 01:52 PM #8
    Ever hear of one spec superceeding another?
    Nov 10th, 2010
    mid hudson valley
    04-18-2012 06:08 PM #9
    and why hasn't the manufacturer noted it? the 09a is a modern tranmission so their specs are current. the fluids you post are fine for their intended use. just don't think you know more than vag, mb bmw or porche for that matter.
  10. 04-18-2012 09:03 PM #10
    You "think", I *know*.
    Nov 10th, 2010
    mid hudson valley
    04-19-2012 06:11 AM #11
    it's never as complicated as you make it. worse is you think that manufacturer specs are superceded by audisquirt or whatever name you go by today.
    by the way do you have permission to use the charts and graphs you post? copyright issues you know.
    Nov 10th, 2010
    mid hudson valley
    04-19-2012 06:14 AM #12
    i have the capacity to think, something you should consider.
  13. 04-19-2012 08:39 AM #13
    Dude, you need a new hobby or something, this one isn't working out for you.
  14. Member
    Nov 10th, 2010
    mid hudson valley
    04-19-2012 03:11 PM #14
    you've been suspended under more names than one can think of, you give advice that voids warranties and think everyone else is stupid. i'll keep pointing it out as long as need be. maybe it's not working out for you.
  15. 04-20-2012 10:35 PM #15
