    Page 1 of 3 123 LastLast
    Results 1 to 25 of 70
    Thread: Part Out: 1998 K2 Jetta 2.0 | CT | Picture Heavy
      Dec 1st, 2011
      Shelton Connecticut
      04-12-2012 01:18 PM #1
      UPDATED WEEKLY
      1998 Blue K2 Jetta 2.0 | 158,175 Miles | Running & Driving | Parts Located In Derby, CT |
      - Engine ran fine
      - Pictures available upon request
      - Sunroof works
      - Full part out, let me know what you need
      - Text in Red indicates parts are sold or scrapped
      SOLD:
      All Interior Trim
      Back Speaker Shelf
      Sunroof
      All Seat belts
      Sunroof Controls
      Glove Box
      Engine
      Shifter & Boot
      Ebrake Boot
      Transmission
      Steering Wheel
      Seats
      Heated Seat Switch & Wiring
      Blisten Suspension with H&R Springs
      Full Exhaust
      Engine Wiring Harness
      Subframe
      Knuckles
      Exterior Pieces
      - Rear bumper cover (Blue) - $30
      - Front bumper cover (Blue) - $30
      - Rear plate tub - $10
      - Upper radiator core support (for 2.0) $30
      - Front bumper rebar - $20
      - Sunroof, complete working assembly with glass - $100
      - Fenders (Blue) - $30 ea
      - Lower radiator core support (for 2.0) $30
      - Heated windshield washer nozzles - $20
      - Door handles - $10 ea
      - Power Heated Mirrors (black) - $10 ea
      - Doors (Blue) - $50 ea or $175 for all
      - Trunk lid (Blue) $30
      - Wiper arms - $10 ea
      - Wiper motor with linkage - $30
      - Rear bumper rebar - $20
      - Power Mirrors (Black) - $15 ea
      - Door Latches - $10 ea
      - Fuel door - $5
      - Rear window glass with defrost - $30
      - Door window glass - $20 ea
      - Antenna base and cable - $30
      - Roof rain gutters - $10 ea
      Lighting
      - Smoked tail lights - $ 100 for the set or $30 ea
      - Headlights - $40 ea
      - Headlight harness (with fogs) - $30
      - Headlight switch (with fogs) $20
      - Fog lights $20 ea
      - Headlight harness (with no fogs) - $20
      - Headlight switch (with no fogs) $10
      Interior
      - Interior Trim Set
      - Silver faced instrument cluster with 158K miles - $60
      - Window regulators $50 each regulator with motor
      - Black door cards / panels - $20 ea or $60 for the set
      - Turn signal stalk with cruise $20
      - Drivers knee bar cover $10
      - Heated seat switch - $30
      - Tilt Clamshell - $30
      - Tilt Clamshell (broken interior tabs) - $10
      - Airbag module - $40
      - Ignition switch with lock cylinder, steering column and key $50
      - Rear speaker shelf carpet (black) - $20
      - Front center gear shift console with dual cup holder- $40
      - Door speakers - $5 ea
      - Dash tweeters - $5 ea
      - Heater core $20
      - Trunk seal - $10
      - Airbag harness - $20
      - HVAC box, heater core, A/C core - $40
      - Climate control knob assembly - $20
      - Glove box (Black) - $30
      - Front seat guide rail covers - $5 ea
      - Black dash shell – $20
      - Passengers airbag - $20
      - Passenger airbag cover - $20
      - Fuse block - $20
      - Black cabin carpet - $20
      - Headliner - $5
      - Sunroof motor - $20
      - Sunroof motor cover - $5
      - Central locking door lock pump - $5
      - Switches $5 - $15 ea
      - Dash Button Blanks - $2.00
      - Dome Light/sunroof controls - $20
      - Dash Vents $10 ea
      - Center Dash Vents/Radio Surround - $15
      - AC control panel cover - $10
      - Dash Cluster Surround - $5
      - Interior door handles - $5 ea
      - Cig lighter with ash tray surround - $15
      - Wiper stalk with MFA $25
      - Grab Handle Trim x 4 - $10
      - Sun visors (grey) - $10 ea
      - Mirror triangle trim - $5 ea
      - Rear view mirror $10
      - Ash tray - $10
      - Pillar panels - $10 ea
      - Alarm modules (white, black, and silver) - $10
      - Owners manual - $10
      - Doorway kick panels - $10 ea
      - Door seals - $10 ea
      - Seat belts - $10 ea
      - Relays $10 ea
      - Trunk carpet - $20
      - VW trunk bag with jack and tools $20
      Engine / Transmisson
      - A/C hard lines - $30
      - A/C condenser - $40
      - Starter for Manual tranny $30
      - Ignition coil (obd2) $20
      - Muffler with all exhaust piping $80
      - Exhaust manifold - $40
      - Distributor with cap - $30
      - Spark plug ignition wire set $20
      - Fuel pump with sending unit - $50
      - Windshield washer reservoir - $20
      - Cat converter - $40
      - Coolant overflow tank with lid $10
      - ECU (for 2.0 OBD2) - $50
      - Fuel rail with injectors $30
      - ABA 2.0 OBD2 motor (parting out)
      - Engine bay harness (2.0 OBD2) - $100
      - Water pump pulley $10
      - Carbon canister with all tubing and valves - $30
      - Alternator - $30
      - Throttle body (2.0) - $40
      - Power steering pump - $30
      - Radiator - $30
      - Rad. fan shroud - $30
      - Coolant hoses - MAKE OFFER
      - Downpipe - $30
      - Oil pan (2.0) $40
      - Front motor mount $20
      - Passengers side motor mount $20
      - Manual shifter box complete with shifter mechanism $40
      - MAF (mass air flow) sensor for 2.0 - $40
      - Stock intake - $40
      - Secondary air injection pump - $30
      - 2.0 OBD1 intake manifold - $25
      - 2.0 OBD2 intake manifold - $25
      - Drivers CV axle complete (for 2.0 5-speed) - $40
      - Passengers CV axle complete (for 2.0 5-speed) - $40
      - Throttle cable (2.0) - $10
      - Clutch cable (2.0) - $15
      - Heater fan control module - $20
      - Gas tank (for 2.0) - $40
      - Rad. Cover trim - $10
      - A/C compressor - $40
      Suspension/Steering/Brakes
      - 4 lug rear beam complete with rear disc brakes $100
      - Power steering rack $60
      - Power steering pump $30
      - Front disc brake calipers $20 each
      - Power steering lines - $30
      - Power steering reservoir $20
      - Brake booster with master cylinder, and reservoir (2.0) - $50
      - 4 lug spare donut tire - $20
      - Control arms - $30 ea or $100 for entire front suspension
      Dec 1st, 2011
      Shelton Connecticut
      04-12-2012 07:05 PM #2
      Dec 1st, 2011
      Shelton Connecticut
      04-13-2012 01:16 AM #3
    4. Member
      Dec 1st, 2011
      Shelton Connecticut
      04-14-2012 11:43 AM #4
      Dec 1st, 2011
      Shelton Connecticut
      04-16-2012 11:03 AM #5
    6. Member
      Dec 1st, 2011
      Shelton Connecticut
      04-17-2012 11:22 AM #6
      Aug 26th, 2010
      medford ma
      95 golf gl 2.0,92 jetta carat 1.8,92 gti vr6
      04-17-2012 02:25 PM #7
      gas tank and fog lighs still for sale? pm pls
      Dec 1st, 2011
      Shelton Connecticut
      04-17-2012 04:47 PM #8
      Quote Originally Posted by iamatwinkie View Post
      PM'ed
      Dec 1st, 2011
      Shelton Connecticut
      04-19-2012 12:57 PM #9
    10. n00b
      Feb 13th, 2012
      Manchester
      1998 jetta tdi
      04-19-2012 06:28 PM #10
      hey do you still have the transmission from this car? I have a 96 jetta 2.0 that i need a trans for. Give me a call id like to buy it from ya. Thanks Dave 860-682-4761
    11. Member
      Dec 1st, 2011
      Shelton Connecticut
      04-20-2012 09:25 AM #11
      Quote Originally Posted by dbendtdi View Post
      PM'ed
      Dec 1st, 2011
      Shelton Connecticut
      04-28-2012 11:48 AM #12
    13. Member
      Dec 1st, 2011
      Shelton Connecticut
      04-30-2012 04:58 PM #13
    14. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-02-2012 10:43 PM #14
      New pictures added
    15. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-03-2012 08:44 AM #15
    16. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-03-2012 10:32 PM #16
    17. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-05-2012 02:39 AM #17
    18. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-06-2012 11:11 AM #18
    19. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-06-2012 06:52 PM #19
    20. Junior Member
      Feb 16th, 2012
      S.NH
      Tr 96 VW golf 2.0
      05-07-2012 10:49 AM #20
      hmu for your seats 603-770-6884
    21. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-08-2012 11:49 AM #21
    22. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-09-2012 02:48 PM #22
    23. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-11-2012 04:09 PM #23
    24. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-12-2012 06:01 PM #24
    25. Member
      Dec 1st, 2011
      Shelton Connecticut
      05-13-2012 11:09 AM #25
