#1
UPDATED WEEKLY
1998 Blue K2 Jetta 2.0 | 158,175 Miles | Running & Driving | Parts Located In Derby, CT |
- Engine ran fine
- Pictures available upon request
- Sunroof works
- Full part out, let me know what you need
- Text in Red indicates parts are sold or scrapped
SOLD:
All Interior Trim
Back Speaker Shelf
Sunroof
All Seat belts
Sunroof Controls
Glove Box
Engine
Shifter & Boot
Ebrake Boot
Transmission
Steering Wheel
Seats
Heated Seat Switch & Wiring
Blisten Suspension with H&R Springs
Full Exhaust
Engine Wiring Harness
Subframe
Knuckles
Exterior Pieces
- Rear bumper cover (Blue) - $30
- Front bumper cover (Blue) - $30
- Rear plate tub - $10
- Upper radiator core support (for 2.0) $30
- Front bumper rebar - $20
- Sunroof, complete working assembly with glass - $100
- Fenders (Blue) - $30 ea
- Lower radiator core support (for 2.0) $30
- Heated windshield washer nozzles - $20
- Door handles - $10 ea
- Power Heated Mirrors (black) - $10 ea
- Doors (Blue) - $50 ea or $175 for all
- Trunk lid (Blue) $30
- Wiper arms - $10 ea
- Wiper motor with linkage - $30
- Rear bumper rebar - $20
- Power Mirrors (Black) - $15 ea
- Door Latches - $10 ea
- Fuel door - $5
- Rear window glass with defrost - $30
- Door window glass - $20 ea
- Antenna base and cable - $30
- Roof rain gutters - $10 ea
Lighting
- Smoked tail lights - $ 100 for the set or $30 ea
- Headlights - $40 ea
- Headlight harness (with fogs) - $30
- Headlight switch (with fogs) $20
- Fog lights $20 ea
- Headlight harness (with no fogs) - $20
- Headlight switch (with no fogs) $10
Interior
- Interior Trim Set
- Silver faced instrument cluster with 158K miles - $60
- Window regulators $50 each regulator with motor
- Black door cards / panels - $20 ea or $60 for the set
- Turn signal stalk with cruise $20
- Drivers knee bar cover $10
- Heated seat switch - $30
- Tilt Clamshell - $30
- Tilt Clamshell (broken interior tabs) - $10
- Airbag module - $40
- Ignition switch with lock cylinder, steering column and key $50
- Rear speaker shelf carpet (black) - $20
- Front center gear shift console with dual cup holder- $40
- Door speakers - $5 ea
- Dash tweeters - $5 ea
- Heater core $20
- Trunk seal - $10
- Airbag harness - $20
- HVAC box, heater core, A/C core - $40
- Climate control knob assembly - $20
- Glove box (Black) - $30
- Front seat guide rail covers - $5 ea
- Black dash shell – $20
- Passengers airbag - $20
- Passenger airbag cover - $20
- Fuse block - $20
- Black cabin carpet - $20
- Headliner - $5
- Sunroof motor - $20
- Sunroof motor cover - $5
- Central locking door lock pump - $5
- Switches $5 - $15 ea
- Dash Button Blanks - $2.00
- Dome Light/sunroof controls - $20
- Dash Vents $10 ea
- Center Dash Vents/Radio Surround - $15
- AC control panel cover - $10
- Dash Cluster Surround - $5
- Interior door handles - $5 ea
- Cig lighter with ash tray surround - $15
- Wiper stalk with MFA $25
- Grab Handle Trim x 4 - $10
- Sun visors (grey) - $10 ea
- Mirror triangle trim - $5 ea
- Rear view mirror $10
- Ash tray - $10
- Pillar panels - $10 ea
- Alarm modules (white, black, and silver) - $10
- Owners manual - $10
- Doorway kick panels - $10 ea
- Door seals - $10 ea
- Seat belts - $10 ea
- Relays $10 ea
- Trunk carpet - $20
- VW trunk bag with jack and tools $20
Engine / Transmisson
- A/C hard lines - $30
- A/C condenser - $40
- Starter for Manual tranny $30
- Ignition coil (obd2) $20
- Muffler with all exhaust piping $80
- Exhaust manifold - $40
- Distributor with cap - $30
- Spark plug ignition wire set $20
- Fuel pump with sending unit - $50
- Windshield washer reservoir - $20
- Cat converter - $40
- Coolant overflow tank with lid $10
- ECU (for 2.0 OBD2) - $50
- Fuel rail with injectors $30
- ABA 2.0 OBD2 motor (parting out)
- Engine bay harness (2.0 OBD2) - $100
- Water pump pulley $10
- Carbon canister with all tubing and valves - $30
- Alternator - $30
- Throttle body (2.0) - $40
- Power steering pump - $30
- Radiator - $30
- Rad. fan shroud - $30
- Coolant hoses - MAKE OFFER
- Downpipe - $30
- Oil pan (2.0) $40
- Front motor mount $20
- Passengers side motor mount $20
- Manual shifter box complete with shifter mechanism $40
- MAF (mass air flow) sensor for 2.0 - $40
- Stock intake - $40
- Secondary air injection pump - $30
- 2.0 OBD1 intake manifold - $25
- 2.0 OBD2 intake manifold - $25
- Drivers CV axle complete (for 2.0 5-speed) - $40
- Passengers CV axle complete (for 2.0 5-speed) - $40
- Throttle cable (2.0) - $10
- Clutch cable (2.0) - $15
- Heater fan control module - $20
- Gas tank (for 2.0) - $40
- Rad. Cover trim - $10
- A/C compressor - $40
Suspension/Steering/Brakes
- 4 lug rear beam complete with rear disc brakes $100
- Power steering rack $60
- Power steering pump $30
- Front disc brake calipers $20 each
- Power steering lines - $30
- Power steering reservoir $20
- Brake booster with master cylinder, and reservoir (2.0) - $50
- 4 lug spare donut tire - $20
- Control arms - $30 ea or $100 for entire front suspension
#32
How many miles on the gauge cluster, and do you still have it?
