Results 1 to 7 of 7
Thread: FS Automatic G60 Corrado - with issues
  1. Member dab043's Avatar
    Jun 8th, 2005
    kenowhere, WI
    69 baja, 92 Cabriolet, 09 SportWagen
    04-12-2012 07:03 PM #1
    SOLD
    Well a few weeks ago figured out why car is running crappy. #1 cylinder is at 20 psi. So its not a car you can get in and go. It will need some motor work. With that said I would rather sell the complete car than part it out. I have done a lot to it over the last few years, but its time for it to go. I will NOT part it out at this time, but if there is no interest then I will list it in the parts section. I would like $1,500 for it.
    Auto raddo with aprox. 145,000 miles on it. I have no idea what has been done to the charger, it works and boosts fine. I was told belts were replaced when complete motor got all new seals and rebuild from 2 owners ago. It has dings and some surface rust, par for the course for a car that old, nothing larger than a quarter, no holes. Rear wing works fine. It has a home made intake an aftermarket cone filter. Still has AC, but does not get cold. It has a CD player. Sun roof works fine and does not leak. It has SLC hood. It has a black front bumper now, but I have the color matched one for it as well.
    Bad - besides that its an Auto (Everyone hates on it)
    No compression in #1 cylinder
    Rear shelf cut for 6x9 speakers.
    This is what I have done with it while i have had over the last two years:
    New Fuel Pressure Regulator
    Brand new Heater core, its dang hot and does a great job
    (2) Bosch front wipers and rear wiper, rear wiper arm cap
    H&R 60/40 suspension - used, but good condition
    both rear wheel bearings
    front strut bearings
    rear strut bushing kit
    both front tie rod ends
    New cross drilled, vented front rotors, powder coated, front brake pads
    turned rear rotors and new rear brake pads
    All Caliper sliders regressed and replaced with new rubber boots
    mk4 rear caliper conversion with new SS brake lines for conversion & banjo bolts (lighter, aluminum instead of cast iron, and better rear disk brakes)
    Brake fluid flush and all new fluid
    new brakes lines from MC to both rear brakes
    passenger window switch and hand full of other interior pieces.
    New defrost switch
    custom car mats from Volkssport for the Corrado
    New dust shields front and back
    Alignment and balance after suspension work
    All suspension parts painted to help keep away the rust
    new rear side shelf speakers
    I just had the timing, serp and PS belt replaced. 1 month ago
    I put brand new winter tires on the stock BBS rims that have under 2,000 miles on them. I made some BBS 5x100 center caps fit but they are not perfect. I also have another set of rims that are on the Raddo now. I can be flexible on what rims and tires go with the car.
    "To let another man define your own goals is to give up one of the most meaningful aspects of life – the definitive act of will which makes a man an individual."- HTS
    Jul 18th, 2002
    Nebraska
    85 eurospec GTI, 98 turbo GTI, 1990 Miata, 2010 Ford Edge, Road race CRX B16
    04-17-2012 11:17 PM #2
    wish you were a little closer - i have a good g60 block hanging out in garage doing nothing...
  3. Member dab043's Avatar
    Jun 8th, 2005
    kenowhere, WI
    04-24-2012 08:12 AM #3
    bump
  4. Member dab043's Avatar
    Jun 8th, 2005
    kenowhere, WI
    05-09-2012 09:35 AM #4
    bump
  5. 05-14-2012 03:11 AM #5
    Pm sent
  6. Member dab043's Avatar
    Jun 8th, 2005
    kenowhere, WI
    05-14-2012 10:56 AM #6
    Quote Originally Posted by awdbeetle View Post
    Pm sent
    sent you a PM this am and an email
  7. Member dab043's Avatar
    Jun 8th, 2005
    kenowhere, WI
    05-28-2012 09:41 AM #7
    bump
