Address 46: Central Conv. Labels: 1C0-959-799.LBL
Controller: 1C0 959 799 C
Component: 1H Komfortgerát HLO 0004
Coding: 00258
Shop #: WSC 00066
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
End --------------------------------------------------------------------------------------------------
I have an aftermarket headunit, and I'm not sure what to make of the window regulator switch fault...
But I'm curious to know the procedure for initiating the Aging of the Pre-Cat O2 sensor for the BEV motor. I've searched vortex and google and have found nothing, only information (source) for initiating the tests on the AVH/AEG/AZG engines (which have different procedures), I'm guessing I'd initiate tests based on the newer engine code (AEG I think--?).
