Please post a full scan of your Vehicle.
#1
I have a B6 Audi A4 Avant and I'm using a VAG-COM to make changes for the first time. I have a questions about the format of the coding.
What I am trying to do is set my car so that I can roll up the windows and close the sunroof via the remote.
Here are the details from the Ross-Tech site on the procedure:
There are numerous options/ features that can be set. These are controlled by the Coding and in Adaptation Channel 62. When we published a simple table, many people didn't understand it, so here's an explanation:
Let's look at Adaptation Channel 62 first (it is simpler, fewer bits than the Coding). The original value in a US 3.0L model is 95. Both a real VAG tool and VCDS display these values in decimal. 95 decimal is 5F hex, or 01011111 in binary.
Value: 01011111
Bit: 76543210
Now we can correlate the bits with the chart
for Adaptation Channel 62:
State Bit Dec. Function
ON 0 1 windows up with remote
ON 1 2 windows down with remote
ON 2 4 windows up with key in lock
ON 3 8 windows down with key in lock
ON 4 16 sunroof close with remote
OFF 5 32 sunroof open with remote (does not appear to work)
ON 6 64 sunroof close with key in lock
OFF 7 128 sunroof open with key in lock (does not appear to work)
Also, you will see if we add up the decimal values for each of the bits that are ON, we can verify that we did it right because we got the original Adaptation value of 95.
1 + 2 + 4 + 8 + 16 + 64 = 95.
By now you're likely starting to wonder why "Windows with Remote" stuff doesn't work since the appropriate bits appear to be ON. To answer this question, we need to look at the coding the same way. The original coding in this car is 11788 (decimal). That's 2E0C in hex or 010111000001100 in binary. Again, we can again correlate the binary bits with the function table, just like we did above.
In VCDS I see two fields I can update before I click the button "Do It!"
Software Coding (0 - 32767) : 03200
WorkShop Code (0 - 99999) : 20111
To set it like this:
Do I change the first of second setting?
Thanks for helping a VAG-COM n00b!
Dub
#2
Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
#3
A full scan, eh? This is the closest I could find - the Auto-Scan.
VCDS Version: Release 11.11.3
Data version: 20120401
Friday,13,April,2012,16:17:12:11844
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUVC68E63A172478 Mileage: 201800km/125392miles
Address 01: Engine Labels: 06B-909-518-AMB.lbl
Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0003
Coding: 0016701
Shop #: WSC 63351 000 00000
VCID: 74EDE9B814A00E9
No fault code found.
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Part No: 8E0 614 517 H
Component: ABS/ESP allrad 2328
Coding: 04275
Shop #: WSC 06435
VCID: 2D5B3CDCE70A1F1
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1016
Coding: 00000
Shop #: WSC 63351
VCID: 2A5137C0D6E4089
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
Part No: 8E0 907 279 E
Component: int. Lastmodul USA 0305
Coding: 00003
Shop #: WSC 63351
VCID: 346D29B804204E9
Address 15: Airbags Labels: 8E0-959-655-84.lbl
Part No: 8E0 959 655 C
Component: Airbag 8.4EP 2000
Coding: 0010607
VCID: 37771EB44556A51
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 00042
Shop #: WSC 63351
VCID: 3C7D01982C70869
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D35
Coding: 03200
Shop #: WSC 20111
VCID: 32612FA0FE34409
WAUVC68E63A172478 AUZ6Z0B0243071
Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
Part No: 8E0 951 177
Component: Innenraumueberw. 0604
Coding: 00001
Shop #: WSC 00000
VCID: EBDF72C4999E511
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 12044
Shop #: WSC 63351
VCID: 72E1EFA03EB4009
Subsystem 1 - Part No: 8E1959801
Component: Tõrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tõrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 F
Component: symphony II NP2 0051
Coding: 01201
Shop #: WSC 11100
End ---------------------------------------------------------------------
Is this the scan you were referring to?
-Dub
#4
Thank you for posting a full Auto-Scan.
The current Soft Coding of the Central Convenience Module is 12044. Change the soft coding to 12108.
+00064 - Comfort Function via Remote Control (not USA)
12044 + 00064 = 12108.
#6
Hi Jef, I've made the code change to 12108 and I don't get the windows to roll up or down with the remote. How can I confirm I'm doing it right?
Thanks,
Dub
#7
I think you want 16242. I can't rember why, but for some reason that sticks in my head for module SOFT coding for your car.
#8
Looks like there might be some Adaptation values as well. Go into CCM module, Adaptation channel 62, what is the current stored value?
