Results 1 to 8 of 8
Thread: Question on VAG-COM change
  1. Member ColoradoB5's Avatar
    Dec 26th, 2001
    Denver
    Current: 2003 A4 Avant, 2012 Q5
    04-13-2012 04:36 PM #1
    I have a B6 Audi A4 Avant and I'm using a VAG-COM to make changes for the first time. I have a questions about the format of the coding.
    What I am trying to do is set my car so that I can roll up the windows and close the sunroof via the remote.
    Here are the details from the Ross-Tech site on the procedure:
    There are numerous options/ features that can be set. These are controlled by the Coding and in Adaptation Channel 62. When we published a simple table, many people didn't understand it, so here's an explanation:
    Let's look at Adaptation Channel 62 first (it is simpler, fewer bits than the Coding). The original value in a US 3.0L model is 95. Both a real VAG tool and VCDS display these values in decimal. 95 decimal is 5F hex, or 01011111 in binary.
    Value: 01011111
    Bit: 76543210
    Now we can correlate the bits with the chart
    for Adaptation Channel 62:
    State Bit Dec. Function
    ON 0 1 windows up with remote
    ON 1 2 windows down with remote
    ON 2 4 windows up with key in lock
    ON 3 8 windows down with key in lock
    ON 4 16 sunroof close with remote
    OFF 5 32 sunroof open with remote (does not appear to work)
    ON 6 64 sunroof close with key in lock
    OFF 7 128 sunroof open with key in lock (does not appear to work)
    Also, you will see if we add up the decimal values for each of the bits that are ON, we can verify that we did it right because we got the original Adaptation value of 95.
    1 + 2 + 4 + 8 + 16 + 64 = 95.
    By now you're likely starting to wonder why "Windows with Remote" stuff doesn't work since the appropriate bits appear to be ON. To answer this question, we need to look at the coding the same way. The original coding in this car is 11788 (decimal). That's 2E0C in hex or 010111000001100 in binary. Again, we can again correlate the binary bits with the function table, just like we did above.
    In VCDS I see two fields I can update before I click the button "Do It!"
    Software Coding (0 - 32767) : 03200
    WorkShop Code (0 - 99999) : 20111
    To set it like this:
    Do I change the first of second setting?
    Thanks for helping a VAG-COM n00b!
    Dub
    Jun 1st, 2003
    Dearborn Heights, MI
    2005.5 MKV TDI
    04-13-2012 04:52 PM #2
    Please post a full scan of your Vehicle.
    Rain Closing Windows, goF raeR, Aspherical Mirrors, Remote Windows, Amber Club
  3. Member ColoradoB5's Avatar
    Dec 26th, 2001
    Denver
    04-13-2012 06:21 PM #3
    A full scan, eh? This is the closest I could find - the Auto-Scan.
    VCDS Version: Release 11.11.3
    Data version: 20120401
    Friday,13,April,2012,16:17:12:11844
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    VIN: WAUVC68E63A172478 Mileage: 201800km/125392miles
    Address 01: Engine Labels: 06B-909-518-AMB.lbl
    Part No SW: 8E0 909 518 AF HW: 8E0 909 018 A
    Component: 1.8L R4/5VT G 0003
    Coding: 0016701
    Shop #: WSC 63351 000 00000
    VCID: 74EDE9B814A00E9
    No fault code found.
    Readiness: 0110 1101
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 H
    Component: ABS/ESP allrad 2328
    Coding: 04275
    Shop #: WSC 06435
    VCID: 2D5B3CDCE70A1F1
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 L
    Component: A4 Klimaautomat 1016
    Coding: 00000
    Shop #: WSC 63351
    VCID: 2A5137C0D6E4089
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul USA 0305
    Coding: 00003
    Shop #: WSC 63351
    VCID: 346D29B804204E9
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 C
    Component: Airbag 8.4EP 2000
    Coding: 0010607
    VCID: 37771EB44556A51
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 L
    Component: Lenksáulenmodul 0308
    Coding: 00042
    Shop #: WSC 63351
    VCID: 3C7D01982C70869
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 L
    Component: KOMBI+WEGFAHRS. RB4 D35
    Coding: 03200
    Shop #: WSC 20111
    VCID: 32612FA0FE34409
    WAUVC68E63A172478 AUZ6Z0B0243071
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDF72C4999E511
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 BB
    Component: Komfortgerát T7B 1311
    Coding: 12044
    Shop #: WSC 63351
    VCID: 72E1EFA03EB4009
    Subsystem 1 - Part No: 8E1959801
    Component: Tõrsteuer.FS BRM 0002
    Subsystem 2 - Part No: 8E1959802E
    Component: Tõrsteuer.BF BRM 0002
    Subsystem 3 - Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0002
    Subsystem 4 - Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0002
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 F
    Component: symphony II NP2 0051
    Coding: 01201
    Shop #: WSC 11100
    Is this the scan you were referring to?
    -Dub
    Jul 19th, 2010
    In the south, but not the "barefoot and toothless" south.
    2004 VWs
    04-13-2012 11:46 PM #4
    Thank you for posting a full Auto-Scan.
    The current Soft Coding of the Central Convenience Module is 12044. Change the soft coding to 12108.
    +00064 - Comfort Function via Remote Control (not USA)
    12044 + 00064 = 12108.
    Jef blah blah blah
    http://www.ross-tech.com
    071, 070, 034, 036, 046, 077
  5. Member ColoradoB5's Avatar
    Dec 26th, 2001
    Denver
    04-15-2012 07:00 PM #5
    Thanks! I'll give this a try and post my results.
  6. Member ColoradoB5's Avatar
    Dec 26th, 2001
    Denver
    04-26-2012 02:39 AM #6
    Hi Jef, I've made the code change to 12108 and I don't get the windows to roll up or down with the remote. How can I confirm I'm doing it right?
    Thanks,
    Dub
  7. Member zeroboy's Avatar
    Sep 3rd, 2005
    Audi
    02' S6 Atlas grey / 02' S6 Silver
    04-27-2012 09:49 PM #7
    I think you want 16242. I can't rember why, but for some reason that sticks in my head for module SOFT coding for your car.
    Jul 19th, 2010
    2004 VWs
    04-27-2012 10:07 PM #8
    Looks like there might be some Adaptation values as well. Go into CCM module, Adaptation channel 62, what is the current stored value?
    Jef blah blah blah
