Results 1 to 13 of 13
Thread: New wheels, three fit perfect and one rubs???
  1. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    '87 gti 16v--RIP, '92 corrado slc --RIP, 2000 golf 1.8t
    04-13-2012 07:51 PM #1
    I got a new set of wheels today, they are 18x8 et 38, the tires are 225 45's and the rears have no issues at all, the front drivers side is fine, but the front pasenger tire rubs on the shock... Anyone else ever had this issue?
    Any ideas? Why would it ony rub on the passenger side, I would think that if the tires were too big it would rub on both sides....
    I appreciate the help!
  2. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    04-13-2012 08:47 PM #2
    That et is pretty high.. I"m assuming this is a MK4? Get like a 5mm spacer for both fronts and be done.
  3. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    04-14-2012 01:44 AM #3
    yes it is an mk4 golf 1.8t, I will look into getting the spacers, but isnt it weird that it only rubs on one side?
  4. 04-14-2012 10:14 AM #4
    How is your camber? One side could be in a little more than the other.
  5. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    04-14-2012 11:40 AM #5
    You need some 215/40s and at least a 10-20mm spacer.
    MKV | MKIV | AWhiteRabbit| perfect.
  6. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    04-15-2012 12:15 AM #6
    Do you really think I need to go that big on the spacers? Isn't the stock offset 35? That is what I read somewhere...
    Has anyone ran tires this size? It seems like it should work, I am installing a new suspension kit soon, and I will get an alignment and wheel spacers, hopefully it all works out.
  7. Member Airy32's Avatar
    Nov 14th, 2007
    NC
    MkIV R
    04-15-2012 04:46 PM #7
    225/45/18 is a really big tire. Sure you don't mean 225/40? The width is probably ok, but in combination with the height (around a full inch taller than stock size) could be an issue. If your new suspension will include any lowering, they may not work at all.
    I would try 5mm spacers first. That should be enough to stop rubbing on the strut. But then you might start having fender lip or liner clearance issues while turning. I wouldn't proceed with any more mods until you're sure the tires will fit first.
  8. 04-15-2012 05:57 PM #8
    Quote Originally Posted by mistamaximus View Post
    No, the stock offset is ET38 or ET42.
    Get the right size tires and they shouldn't rub.
  9. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    04-19-2012 02:54 PM #9
    Oh ok, then the offset is correct, it must be the taller tires then. still weird that it only runs on one side....
  10. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    04-19-2012 02:55 PM #10
    Thanks everyone for the input, I appreciate it a lot. I am going to replace my suspension because it is shot and have an alignment done, then I will go from there. I will keep you posted as to the results.
  11. Member turbonium89's Avatar
    Aug 1st, 2008
    cathedral city, CA
    mk2 89 gti, and mk4 jetta gli rolling chassis
    04-19-2012 05:31 PM #11
    well if ur suspension is shot, ur passenger side might be saggin a smidge more than driver side. get new lower r32/tt control arm bushings and shock tower bushings. also make sure the ball joints are ok.
    i personally think 225/45/18 would look pretty good cause it would fill the wheel well a bit better. i like bigger wider tires tho and most people in the vw scene think its more appealing to have large wheels with tiny tires which looks good as well as long as its doe right. anywho, the larger tire side wall (225/"45"/18 would change your speed compared to your speedo.
    if they are 40 series tires you should b fine.
    also take into consideration that a 35et or 38et on a 18x8 is different than 35et or 38et on a 16 or 17x7.5.
    id run a spacer but keep it minimal up front and keep in mind most allignment shops and tire shop dont deal with cars with spacers. and being FWD large spacers will cause damage to wheel bearings and axles over time.
    where did you get your wheels. i know tirerack lets you do exchanges and you should find some wheels that have a +25 et or even +20. then you wont need spacers in most cases with a 8 inch wide wheel
    btw any pics of the wheels you got? interested!
    Living fast in the the slow lane. Still have a vw though. Sometimes that's just enough
  12. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    05-07-2012 06:03 PM #12
    So when's finally got my new suspension installed, it dropped my car approximately 1.25" all around. When removing the old suspension I found out that the front passenger strut actually dropped about 1-1.5" in the knuckle, I'm glad I caught it because it was getting close to the axel boot. But after replacing the suspension, the new set up fits, I do rub a tiny bit when I turn really sharp, I think I need to trim my inner fender liners and I should be good!
    Thanks for all your help everyone! I will post pictures when I get home, I can't get my phone to upload any pics...
  13. Junior Member mistamaximus's Avatar
    Feb 25th, 2007
    Beaverton, Or
    05-11-2012 06:38 PM #13
    Golf with new suspension and 18's
    here is the pic I said I would put up, let me know what you think.
