Results 1 to 6 of 6
Thread: New 01 EV MV
  1. Semi-n00b
    Oct 13th, 2009
    Charlotte, NC
    2001 Eurovan MV
    04-13-2012 08:19 PM #1
    Hey
    New Eurovan owner here.
    Just picked up my 2001 EV MV for $4950.
    Has some issues. Wanted to ask a few questions from the experienced VDubbers on here.
    Where to buy parts online?
    I had the ABS light come on. When I restarted it disappeared? Common issue? Rebuild of the ABS module?
    I had the oil pressure light come on while on the highway. I was about to pull over and it went away. It was on for about 4 seconds and disappeared. I was almost home just just completed the trip. Oil level looked fine.
    How are the transmissions?
    Any other good sites with DIY threads?
    Thanks!
  2. Member bigfatgeek's Avatar
    Feb 5th, 2005
    San Diego County, CA
    '01 EuroVan MV, '91 Miata
    04-13-2012 11:26 PM #2
    The ABS light could be due to a bad brake light switch. A common point of failure, at least it's cheap and about a five minute job to replace. That was the case with my own '01.
    I bought mine from Europarts SD - http://store.europarts-sd.com/switch...2001-2003.aspx
    Note the comment "7th revision of this problematic part".
    And Europarts SD is a good vendor, I've bought the transmission kit from them a few times.
    Oct 12th, 2005
    South Australia
    2001 VW TRAKKA SYNCRO 2.5TDI,'06 Mk5 Golf TDI,'01 Polo 1.4 16V
    04-14-2012 06:54 PM #3
    Quote Originally Posted by jwwells View Post
    I think this is the largest English speaking T4 forum, lots of good stuff on there.You will need to register though to get access.
    http://www.vwt4forum.co.uk/forumdisplay.php?f=146
  4. Semi-n00b
    Oct 13th, 2009
    Charlotte, NC
    2001 Eurovan MV
    04-14-2012 09:49 PM #4
    Thank You!
    I really appreciate the responses.
  5. 04-14-2012 09:51 PM #5
    Only thing with the overseas forums is for drivetrain questions, they generally do not have an abundance of the same engine and transmissions that we got so they might be a bit weak on finding that kind of information there.
    For parts, europarts-sd.com IMHO is the way to go for most things. germanautoparts.com has treated me well for past VWs as well as autohausaz.com but they don't specialize in Eurovans as much as europarts-sd does but all are fine vendor.
    I don't think any of the above deal much in aftermarket fun stuff though but eurocampers.com does. I've had good experiences with them for those sorts of things.
    No idea on your oil pressure light. My '00 did that to me once and did the same sort of thing (went away after I downshifted to get the revs up to increase pressure) and it was fine after that and never came back.
    I second the opinion of the ABS light; check your brake light switch. Common failure item. Also the ignition switch (the inexpensive electrical portion) also fails a bit easily but it's inexpensive to replace (but a little hard to get at from what I hear).
    Transmissions are delicate though. Treat it as if the internals are made of the finest and most expensive crystal (really!). I just posted this link in another thread re: transmissions:
    http://www.rialtainfo.com/TheBaldy/vw/transmission.htm
  6. Member
    Oct 12th, 2005
    South Australia
    04-15-2012 07:16 PM #6
    As a new owner with auto transmission you need to be made aware that oil changes are essential.
    If you go to the link that Matt has given you & you open the PDF file "transmission service manual" it says the trans is sealed for life, no oil changes needed or something like that. That has proved to be WRONG!, unless you are happy paying for a new transmission on a regular basis.
