hi everyone.after finding the misterious missfire problem in my car (turned out to be a head gasket) i decided to go for a replecement engine.straight on e bay and won the auction and got it delivered to my door.everything is fine untill i found that i havent notice the code and the engine i bought turned out to be the one with coilpack wheres mine is with individual coils.oh dear!
silly me!
so what do i do now?as far as i can see its almost the same eccept for it has a missing cam sensor and a selenoid for the exhaust cam.are they interchangeable without the head or if i bought-modified the loom and a ecu from aue coded engine would be easier? or can i just put the engine in with the current ecu-loom set up and leave the sensor wires blank and try.finally if i bought an ecu,coil pack and the loom woul i need to re program the key or will it work since my car has its own transponder and key?
thanks
