Results 1 to 7 of 7
Thread: FS wrecked (PARTS): 2000 VW Jetta GLS 5spd $2000 OBO takes it or part out (Mechanicsville,VA)
    Jan 17th, 2008
    Summerville,SC
    01 VW Jetta GLS 2.Slow
    04-14-2012 04:35 PM #1
    *This is a friend's car not mine so you will have to call him*
    2000 VW Jetta GLS 5-SPD (Mechanicsville,VA)
    *ALL Must Go!
    mileage: 125,100
    Motor & Trans is in great shape *RUNS*, bp gas whole life and oil changed 3,000.
    804-564-2216 John *Can send more pix through txt if needed*
    Heres the read out of the vac-com scan!
    VCDS Version: Release 11.11.2
    Data version: 20120126
    Saturday,14,April,2012,15:57:38:41871
    Chassis Type: 9M - VW Jetta IV
    Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
    75 76
    Mileage: 201330km/125100miles
    Address 01: Engine Labels: 06A-906-018-AEG.lbl
    Part No: 06A 906 018 JJ
    Component: 2.0l R4/2V MOTR HS V01
    Coding: 00031
    Shop #: WSC 01423
    VCID: 73EBDD4841AE09B
    No fault code found.
    Readiness: 0000 0000
    Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
    Part No: 1J0 907 379 P
    Component: ABS 20 IE CAN 0001
    Coding: 03504
    Shop #: WSC 00066
    VCID: 3E7D3C7C3A6C943
    Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
    Part No: 6Q0 909 605 A
    Component: 09 AIRBAG VW5 0003
    Coding: 12345
    Shop #: WSC 00066
    VCID: 356F23500F5A57B
    1 Fault Found:
    00532 - Supply Voltage B+
    07-10 - Signal too Low - Intermittent
    Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
    Part No: 1J0 920 900 J
    Component: A4-KOMBIINSTR. VDO V56
    Coding: 07242
    Shop #: WSC 09417
    VCID: 2957FF20D3E203B
    Subsystem 1 - Part No: IMMO
    Component: IDENTNR: VWZ7Z0X2004949
    IMMO-IDENTNR: VWZ7Z0X2004949
    Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
    Part No: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 00066
    VCID: F0E15244B0B8B23
    End ---------------------------------------------------------------------
    "I'll trade a kidney for an MK4 R32"
    Jan 17th, 2008
    Summerville,SC
    04-18-2012 09:17 AM #2
  3. Member pedrosan's Avatar
    Feb 5th, 2005
    Edgewater MD
    90 corrado g60. 00 jetta tdi. 97 a4
    04-18-2012 10:04 AM #3
    what engine is in this?
  4. Member
    Jan 17th, 2008
    Summerville,SC
    04-18-2012 06:32 PM #4
    It has a 2.0L AEG (125,100mi) with a 5-speed....Runs with zero codes, airbags never deployed...Interior(tan w/black seats) is good except for the headliner other then that seats,dash and all is perfect. He can get you more pix if you txt him. I did a scan with my ross-tech vag-com, runs strong, no misfires...The radiator did bust on impact but did not overheat from it so the motor wasnt hurt. I pop the timing belt cover off and bump it over to check the belt and thats still in good shape. Hes asking for $2000 or part out but if you want the motor and trans you will need to pull it yourself all he asking if for there to be no wire snipping if you do take it.
    Jan 17th, 2008
    Summerville,SC
    04-18-2012 06:49 PM #5
    Far as body parts I know the good is back pass door,trunklid,headlights, and 3 tire rims, door glass,back window, pass mirror,gas lid.
  6. Member
    Jan 17th, 2008
    Summerville,SC
    04-24-2012 08:56 AM #6
  7. Member hfiles2011's Avatar
    Dec 5th, 2011
    MD
    00 VW Jetta 2.0L AEG
    04-27-2012 03:04 AM #7
    should sit jackstands on wood. sit car on jackstands. remove wheels. cover car.
