Results 1 to 11 of 11
Thread: Comfort Control Module '02-'05
  1. Member teespeed's Avatar
    Apr 17th, 2008
    Puget sound, Wa
    04-15-2012 12:35 AM #1
    I have a Confort Control Module here, in very good working condition. Its the one that controls the interior lights, remote door locks, alarm system, memory seats, etc... located under the driver's seat, which sometimes gets wet and corroded. This one is Clean.. Fits all B6 A4 and S4 $200 shipped
    8E0959433T
    Jan 2nd, 2004
    Round Rock, TX
    2002 Audi A4 1.8TQM
    04-15-2012 02:29 PM #2
    Quote Originally Posted by teespeed View Post
    I have a Confort Control Module here, in very good working condition. Fits all B6 A4 and S4 $200 plus shipping
    8E0959433T
    the -T part only works with '02 A4s, 03+ B6/B7 A4/S4s use part ending in -BB. While they are mostly compatible, keyfobs will only worth with one or the other, which is why '02 owners have to upgrade to the -BB part to use a B7 keyfob.
    May 15th, 2002
    Beantown USA
    '02 A4 3.0
    04-18-2012 12:06 PM #3
    I know my '02 A4 has some electro-goblins (seems like fob fail when doors won't open or alarm goes off randomly when pressing buttons and needs reset). Sunroof will shut (tilt down to close with no raindrops or other provocation.
    Is there a way to determine whether the fob or Comfort Control box is source of problems?
    Thanks
    DW
  4. Member teespeed's Avatar
    Apr 17th, 2008
    Puget sound, Wa
    04-18-2012 02:25 PM #4
    Quote Originally Posted by Specktater View Post
    Thanks
    DW
    Sounds like the first thing to do is lift the carpet under drivers seat and take the comfort module out of the black storage box, disconnect all connectors and inspect it for water damage. If no water evidence, i would still suspect it to be the cause internally and not the fob. the fob Only sends lock/unlock/trunk signals and nothing else. the comfort module controls all the functions, and most likely invaded by the goblins u talk about. You can try to replace the fob with a new one, however i highly doubt thats whats causing your issues.
    May 15th, 2002
    Beantown USA
    '02 A4 3.0
    04-19-2012 01:55 PM #5
    and before the next rain storm . . .I assume my keys would need to be reprogrammed at the dealer to match Der Neue Komfortbox. Ya?
  6. Member
    Jan 2nd, 2004
    Round Rock, TX
    2002 Audi A4 1.8TQM
    04-19-2012 02:22 PM #6
    no, the radio pairing of the FOBs to the CCM is easily done; see http://wiki.answers.com/Q/How_do_you...udi_a4_key_fob
    Oct 14th, 2002
    Long Island
    2002 A4 1.8TQ, 2000 S4, 2006 Range Rover Sport
    04-22-2012 11:04 AM #7
    You will need VAG COM to pair the key on a B6. Also, the only way to know for sure if it is the central convenience unit is to scan the car and see if it comes up faulty.
    That being said, the issues you list sound exactly like the problems I was having before replacing mine. I used my VAG COM to reprogram fobs (very easy to do) and everything works great now. I wound up buying a new unit for $300, didn't want to spend 150 on an eBay one not knowing if it would last 10 days or 10 years. Also, these units fail without having ever gotten wet. My car has never seen water inside or had wet carpet (I purchased it new) and my central convenience crapped out.
    Oct 14th, 2002
    Long Island
    04-22-2012 11:07 AM #8
    That link for programming the key won't work on a B6 after replacing the CCM. I'm 100% positive of that.
    Jan 9th, 2011
    Boston, MA
    Broken B6
    07-01-2012 06:18 PM #9
    Just bought my B6, and found water underneath carpet
    I have to clear those drain plugs and pop in a new CCM. I want my damn windows/sunroof/alarm/rear view readout all back, and the buzzing to stop.
    PM'd
  10. Member teespeed's Avatar
    Apr 17th, 2008
    Puget sound, Wa
    01-30-2013 03:15 AM #10
    up, Module still available..ready to ship
