VWVortex.com - FT - MK4 jetta GLX VR6
    Results 1 to 13 of 13
    Thread: FT - MK4 jetta GLX VR6
    1. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      bagged vr, smurf mk1
      04-15-2012 09:51 AM #1
      only rule is to not to low ball, something the same value or cash on top... no rust buckets
      2000 UniBlack Jetta vr6, millage is around 155xxx will go up
      Few mods-
      - 18" RML Snowflakes with great rubber
      - spacers/ 5mm front/ 15mm back
      - magnaflow catback
      - highflow cat w/ o2 spacer (still have the stock cat with headers)
      - full FK suspension (dropped 2")
      - B&M shortshifter
      - front eurosport stress bar
      - votex polished roofrack
      - hoodbra
      - cold air intake
      - hard wood trunk
      - GLI front/back lips (original, back not installed)
      - shaved GLI trunk (not installed, needs respray)
      - Ostrich skin interior (still have the original gray)
      - bi-xenon retrofits
      - drilled/slotted rotors
      - new badgeless grill (not installed)
      things done in the passed few months
      - oil change (Total Quartz 5w40 every 3-4k)
      - new brake pads (still have more then half left)
      - new bosh platinum fusion spark plugs
      - new battery and alternator
      - new valve cover gasket
      - new radiator
      - fresh coolant (G12 about a month ago)
      ...ETC
      DOD V
      will have some recent pics soon
    2. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-15-2012 10:28 AM #2
      bump
    3. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-16-2012 01:40 PM #3
      bump
    4. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-21-2012 01:14 AM #4
      bump
    5. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-23-2012 08:48 PM #5
      bump
    6. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-25-2012 09:55 AM #6
      bump
    7. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-26-2012 06:27 AM #7
      bump
    8. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-27-2012 08:49 PM #8
      bump
    9. Member Choppa6's Avatar
      Jan 9th, 2009
      Pensacola, Florida
      1 '90 G60 Corrado, 1 Permantly parked '90 G60 Corrado. '01 Passat 1.8T
      04-28-2012 10:06 AM #9
      Free bump for the coolest Sub box ever!!!!!
      " Can't Scuttle drive you guys up in the boat? " Quote from Dogger!
    10. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-28-2012 10:08 AM #10
      Quote Originally Posted by Choppa6 View Post
    11. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      04-30-2012 10:50 PM #11
      bump
    12. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      05-07-2012 11:01 PM #12
      bump
    13. Member McDubber's Avatar
      Nov 19th, 2011
      North NJ
      05-09-2012 12:29 AM #13
      bump
