Well you already know about the Speedo.. Only other thing is that you might rub when the suspension is loaded
#1
07 passat wagon fsi
16'' steelies
factory size 215/55-16 Considering 215/60-16
25.3'' dia 26.1'' dia
all other specs work; width, load, weight etc.
So was thinking change to a slightly taller tire (more sidewall) to increase ground clearance(3/8 inch) while it may also look better on this larger vehicle. Also going high-perf all season so I think they'll look good.
beside the speedo, are there any other prob's i may run into? comments please
also thinking, maybe push them out just a bit with spacers.
(the car looks like its on little donuts that are hidden inside the fenders, odd looking at times considering its a large wagon.)
#2
