Results 1 to 5 of 5
Thread: MK4 GTI Front driver's side wheel sits off center in wheel well.
  1. 04-15-2012 08:08 PM #1
    I'll have to upload some photos so I can explain better, but I just noticed both front wheels sit slightly more towards the front than the other side. I have Neuspeed softsport springs (only half inch drop) and Koni Yellows. The shocks/springs have been on for about a a year and a half. I don't think I noticed it before, but could this be caused by subframe shifting? I measured the space between the wheel well and the tire on the back end of the wheel well and the gap is about a third to a half inch greater on the driver's side. Any suggestions? Subframe shifting? I searched and brought up nothing. Thanks.
  2. 04-17-2012 11:20 AM #2
    As you can see in the photo the wheel has a very tight gap on the bumper side of the well but a larger gap on the door/fender side. Steering wheel is straight in this picture and the other side is more centered by about a half inch. D:
    Mar 23rd, 2008
    N/A
    N/A
    04-18-2012 12:23 AM #3
    Misaligned subframe, and/or bad lower control arm bushings, and/or bent lower control arm.
  4. 04-18-2012 10:59 AM #4
    That's what I'm thinking. I have a set of oem front bushings and r32/tt rear bushings on order and i'm going to have the shop play with the subframe when they're doing the alignment after install.
  5. n00b SMHyo's Avatar
    Jun 7th, 2012
    CT 203
    MK4 GTI
    10-13-2012 12:29 PM #5
    what bumper/valance is that? looks pretty good.
