Results 1 to 5 of 5
Thread: air conditioner problem.
  1. 04-15-2012 08:12 PM #1
    once again, I come to you guys. the air blows normal, no problem with fan speed..its just not cold. the button above on dash is on the blue. what would cause this...do we still use freon?
  2. Moderator PanEuropean's Avatar
    Nov 3rd, 2001
    Victoria, Canada
    2004 W12
    04-15-2012 11:17 PM #2
    The Phaeton Forum 'Table of Contents' (FAQ by Category) is your friend. Have a look in there, see if you can find any discussions about air conditioning where your question might have already been raised and discussed.
    Michael
  3. 05-28-2012 12:47 AM #3
    Hello fellow Phaeton friends,
    I cant seem to locate any troubleshooting info on the A/C system so if this problem has already been asked & answered, please accept my apologies & point me in the right direstion. My 04 V8 doesn't blow cold air when the climate control system is set to the "low" temp setting. This occured last fall but if I shut the car off and restarted it, it worked fine. Now that we are back into the A/C season, I cannot seem to get any cold air from the system. I thought I saw a thread here somewhere about a problem with the blend door somewhere, but I can't locate it now. Any ideas on where to look or what to do would be GREATLY appreciated. Thank you for a great forum and the oodles and oodles of useful information.
    John
  4. Moderator
    Aug 26th, 2011
    Dorset, UK
    2005 Phaeton V10 swb 4-seat, Jeep Commander Hemi, Ssangyong Korando
    05-28-2012 09:00 PM #4
    Hi John,
    The place to start is with a VCDS scan using the latest downloaded version of the PC software from Ross-Tech, which includes a comprehensively updated label file for the HVAC climate controller, prepared recently by Jason/jyoung8607.
    The software allows you to start the diagnostics sequence built in to the HVAC controller, which sequentially excercises all the flaps and motors over quite some time. At the end of that it should be clearer if there's a sticky flap motor, or some such.
    Regards,
    Chris
  5. 06-01-2012 07:43 PM #5
    Any idea where I can get one? Is this basically like an OBDII scanner that hooks up to the same diagnostic port? How much do these run on average? I have no scan tools for my baby other than my OBDII scanner.
    Thank you,
    John
