I am parting out my car and in that list of parts in my mason-tech air suspension.
This is just the shocks, struts, and bags, not the management and air lines.
Mason-tech fitted universal air bags to bilstein struts. They made all billet cnc aluminum mounts. I made my own rubber molds to prevent metal on metal contact with the frame of the car and the mounts for the bags and such. anyways, this kit is great and is a real jaw dropper. if you want low, this is the kit for you!
I also have a spare rear bag. its brand new and i'll throw it in with this kit.
Ok, so i'm selling the management too with everything needed. This is separate to the bags, shocks, and struts.
Kit includes:
5 Gallon tank (body matched quartz grey metallic)
1-400c Viair 150psi air compressor
1-VU4 Accuair 4 corner valve unit
Ridetech Ridepro E3 management
Water Trap
Custom made distribution manifold to house flow controllers, pressure senders, and ptc fittings for lines
Approx 6' of braided high pressure compressor hose
All 3/8" air line needed for 4 bags
All wiring, fuses, and relays needed to fit a b7 perfectly
Extra remote control wire
Mufflers
An extra pressure sender.
The rest of the ridepro e3 management kit.
This whole kit, minus tank, was hidden in the rear drivers side wheel well. It is an extremely clean set up and took a long time to figure out how to hide it all, but it was done and now it is literally all ready to be installed with only the soldering of one wire for the compressor. There were a lot of wires that had to be made special to fit this car to make it a couple hour install. Everything has been labeled to make your install go as smooth as humanly possible. You will not be disappointed!
