Page 1 of 2 1 2 LastLast
Results 1 to 35 of 36
Thread: Introducing my 2005 tt
  1. 04-16-2012 06:56 PM #1
    I've finally upgraded my ride! On Saturday I pulled the trigger on one of three 225qs I was contemplating.
    I drove this 2000 Golf GL for the last 2 years (major upgrade!):
    This is an introduction thread not a build thread (keeping it stock for awhile and if I modify I most likely won't be doing the work myself) although some things I will post about include my attempts at fixing a few defects/minor improvements:
    Interior
    Re-hinge glovebox latch
    Install aftermarket head unit
    Exterior
    Polish out a few light scuffs
    Respray my roof trim
    Mechanical
    Replace timing belt
    Change Haldex fluid/filter
    I'll be posting more pictures and posts documenting my TT experience to help others doing the same projects (when I do them myself).
    Thanks for reading, I look forward to any suggestions, input or whatever you want to say! I'll post some DSLR pics after a good wash.
    Last edited by rhythm629; 05-05-2012 at 04:16 PM. Reason: organized and removed pics
  2. Semi-n00b cdlynx's Avatar
    Mar 11th, 2012
    NE, Ohio
    '03 225 TT, '93 S4, '95 A6, '04 A4 3.0 '76 BMW 2002
    04-16-2012 07:37 PM #2
    New TT looks great....almost got that color as well, but found an '03 225Q Lake Silver Metallic close to me this year. I've been having a great time on daily commute.
    (Reprint from my first post):
    I came up with this solution for the ubiquitous glove box latch breakage (broken as purchased)..... I cut off the lock (with Dremel cutting disk), fit Deutsche 1 Mark coin in recess (perfect fit), and used industrial velcro to reattach the left side non-functional latch. Simply pull off latch, and I can still open glove box as normal.
    https://lh3.googleusercontent.com/-s...0/DSCN0084.JPG
  3. 04-16-2012 07:51 PM #3
    Thanks cdlynx, yea I had a blast on my commute this morning! I'm still getting used to the turbo kick. I've been trying to shift before the turbo starts spooling (unless i want to go fast) so I can get my mpg dash # as high as possible. 17.9 now... What's your number?
    Unique fix with the coin, unfortunately my girlfriend doesn't like the idea..
    I think I'll just try to use a set screw for the hinge.
  4. Member Forty-six and 2's Avatar
    Jan 21st, 2007
    Csprings
    '01 TT 225Q
    04-16-2012 09:47 PM #4
    I am starting to think that may be my favorite stock color. I recently picked mine up and have been loving it.
    Quote Originally Posted by rhythm629 View Post
    I do the same and have been scoring between 25-29.
    It's not always about "racekar"...
    .:46and2:.
  5. 04-16-2012 10:09 PM #5
    Quote Originally Posted by Forty-six and 2 View Post
    I really wanted black at first but I really like the blue too. The papaya orange was pretty cool but I think I would have gotten sick of it.
    Wow thats really high! If I don't see anything higher than 20 by the end of the week I may go through this checklist and advice in the What's Your MPG thread.
  6. Member Mantvis's Avatar
    Jan 1st, 2010
    Chicago, IL
    2001 Audi TT 225hp, 2003 Audi TT 180hp
    04-16-2012 10:32 PM #6
    Ill take the radio!
    Looove the color same as mine
    Time to mod it! :p
    Sent from HTC Evo 3D
    2001 225Q (Function Car): APR Stage 3+, APR 3' Exhaust System, Brembo Brakes, Koni Suspension
    2003 180 (Form Car): Rokkor Coilovers,Custom Front Single Frame Bumper with A8 Grill Votex Sideskirts, Votex Rearlip, Axis Penta 19' Wheels, 2 Rockford Fosgate 15' Subwoofers
  7. Member ttwsm's Avatar
    Feb 27th, 2011
    Minneapolis
    2005 TT 225Q
    04-16-2012 10:49 PM #7
    Damn too slow compared with Quick Draw McGraw here. If Mantvis changes his mind, I'll take the radio...
  8. 04-16-2012 11:16 PM #8
    I'll let you guys know on the stock head unit once I have a new one installed.
    I'm kinda debating keeping it so I can reinstall and move the aftermarket unit to a new car in the future...
  9. Junior Member
    Oct 18th, 2007
    VA
    02TTQC
    04-16-2012 11:19 PM #9
    Get some Turtle Wax brand polishing compound, some Mother's brand wax, and a sponge applicator from any standard auto store. Take a somewhat rough old rag (with nothing stuck to it from previous use), place about a finger tip size dab of the polishing compound and polish the scratches with a bit of pressure. Then do again but instead of using the rag, use the sponge. Then wax the area.
    If that doesn't work, then you'll have to get a hose and 1500 grit sandpaper and LIGHTLY wet-sand the spot. I repeat, LIGHTLY, and with the water constantly running on it. 1500 sandpaper WILL eat through all of the clearcoat and into the base paint if you dick with it too much. The goal here is to break down the edges of the scratches so it is all even - not to eat through the clearcoat. Once this part is done, the area will look very dull. Follow all of this up with the first procedure I gave above. Future waxing will need to be more thorough on the affected area. I do see a couple of spots in the scratched area that are missing paint - ignore those, there's not much you can do unless you want to buy touchup paint matched to your car's paint code.
    I did the above procedure (wet-sand and all) for my 1999 truck on the bed area where a cheapo bed liner scratched up the cap rail really bad, and you would not believe the results.
    As for the rusted area, I highly recommend taking the vehicle to the best paint shop you can locate in your area. I will stop short of saying to pay them whatever they are asking, but I'm a bit reluctant to not say it. You don't want any part of rust, and the work they will have to do to stop it will require more knowledge than what you and I probably have.
  10. Member
    May 23rd, 2008
    Lewisville, TX
    2001 LZ7W 225 coupe; 2007 3.2 A3
    04-17-2012 12:02 AM #10
    the "rust" area is not rust. that strip is aluminum = no rust. it's due to poor paint prep at the factory. in the very early days, audi covered the repaint under the corrosion warranty. But then someone at audi decided the repair/repaint was costing serious money and in a moment of brilliance or douche-baggery (depending on which side of the argument you were on ), reclassified the two roof strips as "trim." And "trim" is not covered by the warranty.
    cheers
    You don't own a TT, you support it: 2001 LZ7W coupe; REVO chip; Forge hoses and DV relo; MadMax DV; Modshack VTDA; BlueFlame Catback, OSIR corners, Forge bling, H&R, Bilsteins, DEFCON2, 986 seats, 18in OZ Vela II; OEM TTQS alcantara steering wheel, knob, ebrake; OEM: BBS RS IIs; roof rack; trunk rack; phone bracket; trunk mat; all weather floor mats; 4-piece Votex kit. My Mods here: http://public.fotki.com/TTQ2K2/. 2007 3.2 S-Line A3.
  11. Member
    Sep 11th, 2011
    Mk1 TT 225
    04-17-2012 12:13 AM #11
    cheers
    Well thats not very kind of them. I have the same problem with my roof rails.
    Nice TT btw OP.
  12. Semi-n00b cdlynx's Avatar
    Mar 11th, 2012
    NE, Ohio
    04-17-2012 01:20 PM #12
    I get avg mpg: 25-32 (when I can read the distorted display) like 'Forty-six and 2'.
    I have a nice 10 mile commute: start out with ez run of 35 mph (speed limit through town) out of the drive for first 2 miles, then I can take back windy roads and click through the gears.....or head out on my personal mostly open 'autobahn' until I arrive for a 45/35 mph for a mile cool-down until I get to work. ck stuff online for 8-12 hours and repeat in the opposite direction.
  13. Member PLAYED TT's Avatar
    Oct 17th, 2010
    Reading, PA/ Williamsport, PA
    A German thing, and a not so German thing
    04-17-2012 08:35 PM #13
    OMG a 225 Papaya? I want it now? I'll trade him for my AG
    But seriously congrats OP
    Slammed Radio Flyer---flickr---My Build Thread 99% of you are idiots therefore I hate you
    Quote Originally Posted by Marcus_Aurelius View Post
    How much lower can you go when you're already scraping stuff??? Soon you'll have the first subterranean vehicle if you keep chasing that goal
  14. Senior Member idwurks's Avatar
    Oct 25th, 2003
    Hill Valley Skyway
    Time Machine
    04-18-2012 03:44 PM #14
    Quote Originally Posted by Mantvis View Post
    Ill take the radio!
    Time to mod it! :p
    And I will wait patiently in second spot if Mantvis is not interested.
    Ian
    Hella4 | GermanPlates | ADstudio Custom Banner Ads | Audi TT Bild | Need Retargeting or Display Advertising?
  15. 04-18-2012 04:32 PM #15
    Ill take the radio!
    Time to mod it! :p
    Quote Originally Posted by ttwsm View Post
    Quote Originally Posted by idwurks View Post
    Ian
    Damn, I guess I priced it too low , anyone want to make a higher offer? and sorry idwurks your in the third spot...
  16. 04-18-2012 07:25 PM #16
    So at work today I was pumped when I got the email from Crutchfield saying my head unit was delivered and I could't wait to get home and install it. Here's my car in the lot at work from my boss's office window (edited with Finger Focus iPhone app)
    Finally I got home and was greeted by a big box of all my supplies for installation. I brought the box out to the car and got to work. First I disconnected the ground lead from the battery per the instructions. Then I used the radio removal tools to take out my stock unit and disconnected all the plugs. Here's all the stuff:
    This radio is exactly what I wanted and it's less than $100! It doesn't have a CD player but it has bluetooth, aux input and front a back USB ports. There's also a mic input on the back and an included microphone for handsfree bluetooth phone calls. Now i just have to figure where to wire it inconspicuously... any thoughts?
    So the trouble started when I compared the wiring harness included with my Crutchfield order. The Bose speaker leads plug didn't fit in the top part of the adaptor so I called tech support for help. They explained that the Bose amp doesn't play nice with after market accessories so I'll need to run new wires to the speakers!! I have no clue how to do that, and can't afford to pay a pro after spending all my money on the car!!
    So after a few minutes on hold they give me another option. I can use a different wiring harness to connect directly to the Bose amp. They've stopped recommending this adaptor because it apparently gives off a lot of noise. I was smart enough to mention a ground loop isolator to help cut out the noise and they agreed to send me two of those as well. Crutchfield support was pretty great and they're sending me the new adaptor and 2 GLIs for free and not even requiring me to send back the old one! The biggest issue when I get the new parts is going to be squeezing all this stuff in the dash...
  17. Member ttwsm's Avatar
    Feb 27th, 2011
    Minneapolis
    2005 TT 225Q
    04-18-2012 08:01 PM #17
    Ian
    Yer in third place, man! Third!
    Also, I've never regretted ordering stuff from Crutchfield. I'll pay a little extra for a place that takes care of their customers.
  18. 04-18-2012 09:37 PM #18
    I'm not even paying anything extra! This head unit is incredibly inexpensive.
    Use my this code for this sweet deal prdrh-kg6jw-5piaq
  19. Member exboy99's Avatar
    May 14th, 2002
    Long Island
    2004 TT 225 quattro coupe
    04-18-2012 10:54 PM #19
    welcome to your new obsession.
    looks great.
  20. 04-20-2012 09:55 PM #20
    Something is definitely wrong with my car. I tried to accelerate quickly today and the RPMs spiked without too much speed. It smelled like my clutch was burning... Does this mean I need a whole new clutch?
  21. Member
    Mar 2nd, 2009
    Philly
    82 Jetta Coupe, 91 Suzuki VX800
    04-21-2012 07:41 PM #21
    Sounds exactly like you need a new clutch
  22. 04-22-2012 01:53 PM #22
    Im definitely dropping the tt off with the mechanic Monday. I'm guessing he'll quote me for a new clutch kit. Here are a few choices I found online. Any reccomendations for the best value? Would spending an extra $100 really make a difference?
  23. Semi-n00b cdlynx's Avatar
    Mar 11th, 2012
    NE, Ohio
    04-22-2012 02:21 PM #23
    also consider this kit which also includes fllywheel + throw-out bearing and install acces.
    http://www.ecstuning.com/Audi-TT_MKI...utch/ES263786/
    I went with this kit + flywheel that was also needed and have been very satisfied!
  24. 04-22-2012 02:44 PM #24
    Quote Originally Posted by cdlynx View Post
    Does the flywheel chatter?
    Sachs Clutch Kit w/o the flywheel is only $280.
    Hopefully my mechanic has some good news for me, maybe I don't have to replace everything...
  25. Semi-n00b cdlynx's Avatar
    Mar 11th, 2012
    NE, Ohio
    04-22-2012 02:57 PM #25
    all quiet and smooth with no chatter.....don't forget to allow for throw-out/release bearing even if you don't need flywheel.
    I needed flywheel, so went with this complete kit and saved $ with free shipping from ECS
  26. 04-22-2012 03:38 PM #26
    Good to know, if I need a flywheel too maybe I'll go with that kit. I didn't realize the stock dual mass flywheel was so expensive. $755 for the clutch kit and flywheel...
    Explain what you mean by allowing for the throw-out/release bearing? Please excuse my ignorance..
  27. Semi-n00b cdlynx's Avatar
    Mar 11th, 2012
    NE, Ohio
    04-22-2012 03:54 PM #27
    allow = $.....you'll want to replace this bearing once you are doing clutch disc and pressure plate service anyway.....your mechanic will probably explain/recommend this anyway if it is necessary to do clutch replacement. good luck and hope your tax refund is on the way already!
  28. 04-23-2012 05:38 PM #28
    My mechanic called, I have to replace everything, including the flywheel...
    I wasn't planning on this and can't afford it...
    I was quoted $1700. $620 for parts (single mass flywheel). I hope it doesn't rattle... Anyone know what the weight of the "stock" conversion kit is? I don't understand why they call it stock if it's single mass...
  29. 05-05-2012 01:32 PM #29
    So I sold my MK4 Golf and transferred the title near Lancaster. I took an awesome route home. If your at the Sonic on 23 and head east take 401 to Malvern. It was a fun road, windy and through the woods. Hardly any traffic at 7pm either.
    When it started getting dark and I put my headlights on I got this message on the dash:
    Worst luck ever, things keep breaking on my new car. See the rest of the technical info in this thread.
  30. 05-06-2012 01:09 PM #30
    Welcome to TT ownership
    Naw, once you sort out the glitches you'll love the car again.
    bulbs are cheap enough to replace and at 7 years old it's probably time to replace the headlight bulbs anyway.
  31. 05-06-2012 09:39 PM #31
    Quote Originally Posted by Neb View Post
    It's not the bulbs. I changed them yesterday.
    All three taillights plus my instrument cluster backlights are out.
    It's sorta feeling like this..
    Quote Originally Posted by BigBlackTiTTy View Post
    people who buy the tt, love the tt. its kinda like that high maintenance super model girlfriend. you know shes a little f**ked in the head, and has a few daddy issues. her brain is kinda small, and you gotta spend a few bucks on her bday, xmas, anniversaries and every other time you make her mad and forget to tell her how beautiful she looks, just to keep her happy. the thing is, we all know this and dont care.
    For now I don't mind spending the $$ cause I'm smitten.
  32. 05-07-2012 12:28 AM #32
    awesome ! glad to hear it. post pics or it never happened
  33. 05-07-2012 08:52 AM #33
    Have you checked the simple things like fuses and grounds?
  34. Member lostorbit's Avatar
    Dec 19th, 2004
    Chattanooga, TN
    2003 TT quattro, 1978 Westfalia, 1982 Rabbit Diesel
    05-07-2012 08:56 AM #34
    I just put that radio in my Mk2 Jetta, it's very nice especially for the price.
  35. 05-08-2012 06:22 PM #35
    All three driverside running tailights are out. When brake lights are on, the bulbs work again, except for the smaller side light (which is not burnt out)
    I've ruled out bulbs and fuses. Where are the ground connections?
    It definitely happened (my TT love affair that is)
    Quote Originally Posted by lostorbit View Post
    It looked nice, I never got to use it. I didn't feel like going through the hassle of wiring it up to the Bose system so I returned it. The crutchfield guys said even if I do everything right it might still give off feedback/noise so I figured it wasn't worth the effort. I think I'll end up getting a DICE or comparable iPod interface for the stock unit as soon as I finish fixing all these issues that keep coming up!
    BTW I had a flat tire the other day too
