This weekend I got fed up, with the HPA mount, and trying to get the stock lower mount pressed in, and I ended up cutting a 1mm gap int the pastic ring, so the mount would depress itself enough for it to be pressed in. My upper subframe dogbone mount/bushing was never messed with, so it is in there good. The lower one appears to be sitting in there well (and is bolted to the upper one at 100nm, as per VWs spec). Finally my car feels back to normal again, and it is a pleasure to drive...
However, I am worried that because I cut the lower mount, that it may not be doing it's job as well as it was designed to, and may be causing more engine movement then the car was designed to handle, and therefore could be causing strain on other components. Basically the lower mount is not longer as tight against the subframe as it should be.
I took videos of how the engine moves now during startup and after throwing a few revs at it. Does this seem like normal engine movement?
http://www.youtube.com/watch?v=GT3IqwzjR7g&feature=plcp
http://www.youtube.com/watch?v=Zlg5CFaRPhc
My only option now is to take my car into VW, have them drop my subframe, and press in a new upper and lower mount/bushing. I have no idea how much this will cost, plus I don't know what they could screw up as a result of them lowering my subframe, plus I am sure they won't replace the TTY bolts... But maybe it is fine as it is, what do you guys think?
