Results 1 to 2 of 2
Thread: Corrado swap to MK2
  1. Member FLYGTI216's Avatar
    Jan 19th, 2003
    Cleveland my Friend
    03 GLI VR6, 1985 GTI chump car racer!!
    04-17-2012 07:40 AM #1
    I was wondering what was needed for a front Corrado swap into an MK2? I did do a MK3 front brake / knuckle swap onto it. So do I just need front calipers, carrier brackets and pads? Or do I need to get the whole knuckle and all the brake set up from the Corrado?
    Thanks in advance
    JK
    Mar 23rd, 2008
    N/A
    N/A
    04-18-2012 12:29 AM #2
    Quote Originally Posted by FLYGTI216 View Post
    Thanks in advance
    JK
    If you already installed the steering knuckles from a MKIII ABA car, to convert to Corrado G60 front Girling 54 11.0" 4-bolt calipers, all you need is the Corrado G60 11.0" calipers and caliper carriers, brake pads, and 4-bolt 11.0" rotors. It's a bolt-on job. Use your existing flex hoses, and remove the short metal line adapters that are attached to the Corrado G60 calipers.
