VWVortex.com - OEM 2012 Beetle turbo boost gauge retrofit?
    Results 1 to 9 of 9
    Thread: OEM 2012 Beetle turbo boost gauge retrofit?
      May 8th, 2011
      Charlotte, NC
      VW Scirocco 1982 (SOLD), 3000 GT VR4 (SOLD) Golf R, sold, Alfa Romeo 4C
      04-17-2012 09:43 AM #1
      Need the parts # for the beetle triple dash gauges and has anybody attempted to install it? thanks
      Golf R CW 4 door base | APR flash 2, Forge WINtake, Scorpion DP, Powdercoated stock wheels black gloss, Soundaktor Delete, H&R Super Sport Springs, Painted brake calibers (yellow).
      2013 JSW-S , 2.5L , manual , CW , Carbonio , H&R springs , VMR v710 black, Tint , (wife)
      Aug 29th, 2010
      Morgantown, WV
      2012 Candy White Autobahn GTI
      10-16-2012 02:13 AM #2
      2012 CW GTI 6MT Autobahn // APR Stage II Software // APR Downpipe // Milltek Resonated Cat Back // VWR Intake // APR Stage II Intake // AWE Turbo Outlet Pipe // Audi S3 Intercooler// South Bend Stage II Endurance Clutch // SPM Full Aluminum Mount Kit // Diesel Geek Sigma 6 Short Shift Kit
    3. Semi-n00b vwgli_12's Avatar
      Sep 19th, 2011
      Sheboygan, WI
      2012 GLI 2.0T Autobahn Pkg
      10-17-2012 03:10 PM #3
      The part # for the triple gauge set up for a 2012 Beetle is 5C5 919 527 C with a retail price of $710.00 . I havent tried at all and I probably wont for that price.... good luck!!
    4. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      MK7 GTI, 90 Corrado 16vt
      11-07-2012 06:26 PM #4
      Quote Originally Posted by vwgli_12 View Post
      Im looking into sourcing a euro version that is $399.00
      Sep 18th, 2006
      NK, RI
      NOW - 2013 GLI / THEN 2010 GTI
      11-07-2012 06:37 PM #5
      hope it actually is accurate if installed in another car -
      http://forums.vwvortex.com/showthrea...-the-gauge-pod
      lololol 24 psi?!
    6. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      11-08-2012 05:45 PM #6
      Quote Originally Posted by TurboR850 View Post
      lololol 24 psi?!
      Thats wild. Im sure its relative to the signal you send it. If you use the proper sending unit you can get it to read whatever you want.
      Apr 11th, 2009
      Norcal - Bay Area
      1999 Miata, 2004 Miata
      11-08-2012 11:04 PM #7
      Quote Originally Posted by Paul@DeutscheAutoParts View Post
      It just reads boost off CAN. The sensor reports absolute pressure, not relative, so subtract 14.7 and you have actual boost
    8. Banner Advertiser Paul@DeutscheAutoParts's Avatar
      Oct 26th, 2012
      Charlotte NC
      11-11-2012 07:32 PM #8
      I suspect you could put a clamping diode in place to make this read true boost
      ShopDAP.com ---------Deutsche (DOY-chuh) Auto Parts----------All VW part numbers are searchable on our site.
      Follow us on Instagram-------- Twitter --------Facebook--------- YouTube
      May 17th, 2012
      Dur'm NC
      2012 Turbo Beetle
      11-12-2012 10:14 AM #9
      Somebody in the Beetle forum tried to retrofit it into a Turbo Beetle (ie the car it was designed for), and gave up even with that. Some of the early Turbo Beetles didn't ship with the gauges (VW had some supply issues I guess), so somebody tried to get the parts and install it after the fact. I believe they found that they didn't have the correct wiring, and it was going to be a _lot_ of work to get it in. Suspect you're going to have a hard time cramming it into a golf R.
      GTarr
